Old 11-15-2008, 06:12 AM   #251
korhan
Member#: 103202
09 sti09&00gc8
black&grey
are you still using vf35? if yes change the turbo.
korhan is offline   Reply With Quote
Old 11-15-2008, 08:38 AM   #252
treystoys
Member#: 97436
03 toyota tundra
gray..missing my WRX's :(
The turbo your using may have alot to do with the peak rpm your car pulls too. Even with a stock location 30r style turbo (mine has a 2.5" inlet) my car really peaks out at around 7500 or so. If your still using the vf turbo then thats probably why the car peaks so quickly...a frien of mine around here with a swapped ver 8 bugeye wagon says the same thing...I think he had the twin scroll vf37 and he says it'll rev to 8k, but falls off quick at 6500.
hope that helps
Trey
treystoys is offline   Reply With Quote
Old 11-15-2008, 08:58 AM   #253
Special
Member#: 145585
2002 S202 11.4@123.6
Yellow
Hi, thanks for your help. I am using the Dom 3 with the 2.5 inch inlet. I shift at 7,000rpm as it doesn't make sense going any higher; you can feel the car losing power.
Special is offline   Reply With Quote
Old 11-15-2008, 12:22 PM   #254
treystoys
Member#: 97436
03 toyota tundra
Yeah, I'm actually using the dom 2.5r, and have often thought the smaller inlet on these turbos has to be choking it off some...I've even thought of going to the dom 4 for that reason alone...lol
ttyl
Trey
Old 11-15-2008, 04:13 PM   #255
Special
Member#: 145585
Yellow
Yeah, it must be the smaller inlet holding it back. It is unfortunate as I was really hoping for it to pull hard to 8,000rpm.
Old 11-15-2008, 06:18 PM   #256
korhan
Member#: 103202
09 sti09&00gc8
black&grey
we are using dom3 with samco turbo inlet, samco maf hose and aps 70mm cai and this inlet setup really improved the top end also the header effect very much.
Old 11-16-2008, 12:27 PM   #257
Special
Member#: 145585
Yellow
I also have the 70mm CAI, and I have the Fujitsubo equal length headers. It must be the AVCS that needs to be tuned for it to pull hard higher up.
Old 11-16-2008, 03:02 PM   #258
treystoys
Member#: 97436
03 toyota tundra
Unless the factory purposely keeps the cams from reaching high lift for a reason, I doubt the avcs has anything to do with the top end pull. The avcs set up on our cars is a bottom end thing...I'm pretty sure by the middle of the power band (or round abouts) they are finished their advancing, and reached 0* advance which is high lift mode. I've just always understood the intake cam only avcs set ups are for low end. If I'm wrong, I will be the first to do some cam tuning! I still think the limits some of us are seeing is due to the turbo. I'm very close to going to a dom 4 or one of the atp stock location 30r's.
Almost forgot, I run an s203 ecu on my car...I'm gonna check out the cam tables from the stock rom and see how the factory has the cam advance.
Trey
Old 11-16-2008, 05:26 PM   #259
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
S203 AVCS map doesn't have the "emmisions hole", goes up to 45* and drops more at higher RPMs
RA-R has identical AVCS map fyi
Hyper is offline   Reply With Quote
Old 11-16-2008, 05:48 PM   #260
treystoys
Member#: 97436
03 toyota tundra
Actually looking at the stock rom it has a 45* hole at the 2.20 and higher load columns in the 28-3200 rpm columns the rest of the lower load and lower rpm table is at 40.08*
Old 11-17-2008, 12:12 AM   #261
Special
Member#: 145585
Yellow
I have an S202 but took out the ECU and now run an Autronic SM4. The strange thing is I don't remember the car dying off after 7,00rpm as it does now, or maybe it is more noticeable cause I am running a bigger turbo. I know Clark has talked about AVCS tuning search for "Tuning AVCS", and he can tune the cars to pull strong all the way to 8,000rpm, but he says you need a good dyno and need to really know what you are doing.
Old 11-17-2008, 03:51 AM   #262
GTScoob
Member#: 68602
02 STi Wagon
Yeah, that AVCS tuning thread makes my head hurt but he made some good points about retarding AVCS at higher revs to flatten out the power and hold more up to redline.
GTScoob is offline   Reply With Quote
Old 11-17-2008, 08:35 AM   #263
ottawarex
Member#: 111248
2004 WRX
Anyone know what this ticking is?
http://www.youtube.com/watch?v=OrVjqr_0fyk
Good compression, 5% leakdown on 1 cylinder. Hyper suggests it could be a faulty injector, and also has been thought to be a valve adjustment. Any other suggestions to check?
ottawarex is offline   Reply With Quote
Old 11-17-2008, 05:05 PM   #264
korhan
Member#: 103202
09 sti09&00gc8
black&grey
i will look,
1- compression
2- rod bearings (check the oil for metal parts)
3- coils and injectors both fauly injectors and coils are making a that type of sound
Old 11-18-2008, 08:35 AM   #265
ottawarex
Member#: 111248
2004 WRX
Originally Posted by korhan View Post
i will look,
1- compression
1- Compression: ~145-~155 on all cylinders.
2- Rod Bearings: Will check tonight/tomorrow for the metal parts. Weren't any at the 1st oil change.
3- Coils: Have swapped 2 coils with no change. Will try other coils.
3- Injectors: Unplugged injectors (one at a time). Seemed a bit quieter. Will check with stethoscope tonight.
Thanks for the help!
Old 11-18-2008, 08:43 PM   #266
gogetr
Member#: 178631
02 shatdan
that sounds like my car did before the #2 cylinder decided to implode. mine was finished by hydrolocking it.
thankfully insurance is taking care of it. it should be back anytime now.
v7 207 is in, heads were saved(didnt think it was possible by they way the plug looked), ported & polished, ported vf39.
anyone have any idea how the vf39 will do with that?
gogetr is offline   Reply With Quote
Old 11-18-2008, 10:26 PM   #267
Honest Bob
Member#: 94698
2005 30R Wagon
subscribed!
Honest Bob is offline   Reply With Quote
Old 11-19-2008, 01:26 AM   #268
Clark Turner
Member#: 178047
02 WRX STI Spec C
Make sure its not the timing belt tensioner. Most of these import motors are crash motors. Its common for them to take a hit. The Idlers and or Tensioners can go bad. The tensioner makes exactly that noise when its failed.
Clark
Old 11-19-2008, 09:00 AM   #269
ottawarex
Member#: 111248
2004 WRX
Clark
Thanks for the suggestions everyone. I'll check the tensioner Clark, thanks.
Old 11-19-2008, 07:10 PM   #270
treystoys
Member#: 97436
03 toyota tundra
Thats funny, cause now that i think about it, my tensioner was locked solid when my ver 8 arrived too.
Trey
Old 11-23-2008, 10:28 AM   #271
korhan
Member#: 103202
09 sti09&00gc8
black&grey
did you find the reason ottawarex?
Old 11-24-2008, 08:31 AM   #272
ottawarex
Member#: 111248
2004 WRX
Didn't find the reason yet. Still have to check the tensioner. If that doesn't work, will check the valve clearance. Thx for the help.
Old 11-28-2008, 09:53 PM   #273
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Not to hyjack the thread from the current ticking questions but:
I'm really starting to dig into the perfect turbo setup for autox/HPDE. I've got a basically stock Ver7 Spec-C RA Limited (crappy inlet since the stock was broken, and a catted turbo back) running the stock turbo (vf30). It dyno'd at 280/260 whp/wtq respectively on Buschers Mustang dyno. Full boost is right around 3800 rpm on an ecutek tune (I think the BPV gasket is leaking hence the slightly slower spool).
I was thinking about possible twinscroll setups that are starting to hit the market. I was really interested in Full-Race's 30r twinscroll until they discontinued it (I know they say the 35r twin scroll is pretty much the same, but I don't think they took the 2.0 into consideration). Now I'm back to the drawing board. Looking at a possible 3076 with the .82 hot side, but I'm really trying to keep full boost at or under 4k rpm (I have the 6-speed so the gear ratios are pretty decent to keep the car around this on an autox course). I know a few people have gotten the single scroll 30r to hit full spool at 4k, but I'm curious what the setup was/is. Quickest possible spool with serious HP (350-400 on 93 no meth) is the goal.
Granted there are no definite lists since every engine is different, but just wanting some good information from other ej207 owners on setups that produce these results.
subydude is offline   Reply With Quote
Old 11-28-2008, 11:43 PM   #274
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
IMO, if you are planning to autox, definietly dont get the 30r or even the 35r, you will never be able to use any of the powerband available. your vf30 is fine, a 16g would fit the purpose too.
Old 11-29-2008, 12:10 AM   #275
subydude
Member#: 80649
I agree that it would be hard to use a 35r single scroll on an autox, but since I have the 6-speed it's rare for me to go under 3,500 rpm on any corner. Hence the reason I'm looking for something that can hit full spool very close to 4k. I'm sure with some left foot braking I can minimize the loss of speed in the very tight corners, and the extra power in the long sweepers/straights would be very handy!
While the vf30 produces decent power, it's a rather unresponsive turbo due to the thrust bearing design. Plus it has a on/off switch personality that's hard to live with when you're trying to turn corners smoothly I win my class 9 times out of 10, but every time I'm at an event with a nationally prepped SM car I'm always 2-3 seconds behind. Just trying to narrow that gap a bit
The 16g was an option, but if I'm going to do the setup I'd like (EWG, injectors, headers, and a few other goodies) I would rather shoot for something that comes on boil around the 4k mark, that makes upwards of 350whp with good response to the throttle pedal and will keep going till 7500 rpm or later.
Please don't take this as dismissing advice, but the word "never" shouldn't apply when it comes to cars Either way, I've got all winter and next summer to research/work on driving skills more. It's not till winter of 2009/2010 that I'll do the swap.
ej207 owner wants opinions adbramsay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-26-2011 08:29 PM
Ej207 V6 AndrewFD3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-03-2010 05:53 PM
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? L'frise Private 'Wanted' Classifieds 7 06-03-2010 10:24 AM
08 ej207 JDM dual AVCS heads on a built v7 ej207 icev7 Built Motor Discussion 17 02-21-2010 04:21 PM
Ver 8 EJ207 Owners Check In spoolinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 10-17-2005 02:56 AM
