Notices
Old 11-08-2006, 07:11 PM   #1
mdd1986
Member#: 83450
2000 Audi S4 Stage 3
Default P0137 code
I keep throwing this code with my catless exhaust. I have the ap so it can not be from being catless. Does this mean that my o2 sensor is shot. Also any1 know where i can get an o2 sensor for cheap?
mdd1986 is offline   Reply With Quote
Old 11-10-2006, 04:20 PM   #2
BuffaloUPSGuy
Member#: 89427
2005 Legacy GT STi
Regal Blue Pearl
Stage 1 or 2? Stage 1 won't kill some of the codes that stage 2 does (if I remember correctly from my setup).
BuffaloUPSGuy is offline   Reply With Quote
Old 11-10-2006, 06:16 PM   #3
hulkSTi
Member#: 96355
2005 STi
i thread that code and one of my wires in the o2 was bad. i just fixed the wire and it was good to go
hulkSTi is offline   Reply With Quote
Old 11-10-2006, 06:19 PM   #4
TMessick
Member#: 882
2004 WRX Wagon
very blue
P0137 = downstream O2 sensor shorted low. Basically means your rear O2 is reading like 0 volts. Most likely cause is the rear O2 signal wire shorted to ground, although it's also possible that you have an issue with the rear O2 sensor. Check your wiring before you go replacing stuff..
TMessick is offline   Reply With Quote
Old 11-10-2006, 06:57 PM   #5
hulkSTi
Member#: 96355
2005 STi
yep, mine had a bad wire.
Old 11-16-2006, 01:48 PM   #6
mdd1986
Member#: 83450
ok thx i will do that
Old 08-21-2008, 11:03 AM   #7
rhinotech
Member#: 144880
03 Civic
Rollin' hard...
bump this thread....
I have this code.. will this make the car run funky?
rhinotech is offline   Reply With Quote
Old 08-21-2008, 11:28 AM   #8
Haelan
Member#: 151045
2013 Subaru STI
CBP
P0137 — O2 SENSOR CIRCUIT LOW VOLTAGE (BANK 1 SENSOR 2)
FAIL SAFE
Sub feedback control: Not allowed
I'm not sure what 'sub feedback control' entails. I'm interested to learn something new if someone else knows the answer.
Edit:
Google to the rescue.
"A sub-feedback control is performed, by which the
upstream-side target air-fuel ratio is corrected so that the air-fuel
ratio detected by the downstream-side exhaust gas sensor becomes equal to
a downstream-side target air-fuel ratio."
Sounds to me like the rear O2 readings are used as correction values for the front O2 readings. Though that goes against what everyone here on NASIOC states that it won't change performance. It could theoretically make your car run slightly richer or leaner during closed-loop fueling. Again, this is only in place for emissions, but the rear O2 does seem to have an effect.
With P0137 enabled there is no correction based on the rear O2. If anything I would think the car would run better.
Please chime in if I'm off base here....
Haelan is offline   Reply With Quote
Old 11-28-2008, 02:21 PM   #9
IH8-V8
Member#: 69655
I am wrestling with the P0137 code as well on my 2004 STi. Prior to upgrading my "firmware" on my accessport v2 I never had a problem. I recently upgraded my firmware, and now whenever I drive on the highway, like clockwork, 20 min into the drive my CEL (and also my cruise control light) starts to flash. It is always a p0137 code. I read in previous posts a few months back that not all stage 1 mapping deletes this code. So, I went with a stage 2 map and I am still having a problem. I am actually going outside now to check my o2 wiring based on the suggestions above. Bottom line, I need to get this figured out ASAP---I am due for a NYS inspection!!! If anyone has any thoughts I am willing to try anything...
IH8-V8 is offline   Reply With Quote
Old 11-29-2008, 06:10 PM   #10
SuperHawk
Member#: 1036
2006 WRX Wagon Ltd.
If you look at the codes that should be inhibited in the map notes from Cobb that is one of them. If you have an aftermarket tune from another tuner then they need to inhibit the code. I had the same problem after someone custom tuned my car they forgot to inhibit the CEL codes.
So if you have an access port down load the latest version of the map that you are using and just re-flash the ecu!
Dennis
SuperHawk is offline   Reply With Quote
Old 11-30-2008, 11:11 AM   #11
prwatts
Member#: 194393
Dennis
Sorry to be dumb - where are the O2 sensors and how many are there?
prwatts is offline   Reply With Quote
Old 11-30-2008, 11:52 AM   #12
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
Dude fill out your profile and read the newbie FAQ's !
ASU is offline   Reply With Quote
Old 11-30-2008, 04:23 PM   #13
SuperHawk
Member#: 1036
2006 WRX Wagon Ltd.
The one that causes this problem is in the down pipe.
Old 06-03-2016, 12:12 AM   #14
DasSubiNewbi
Member#: 448219
Default Talked to Cobb.
Dennis
Cobb doesn't inhibit the codes. I didn't have problems until after I had the recall reflash. I'm at day one trying to figure it out. Any direction would be appreciated.
DasSubiNewbi is offline   Reply With Quote
Old 06-03-2016, 04:13 PM   #15
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
P0137 is the downstream O2 sensor which isn't used to monitor AFR's but only to monitor the health of the Catalytic converters of which you have none. Something else is going on to give you this code rather than a Cataytic converter specific code but regardless, the trouble codes related to the rear O2 sensor will need to be disabled entirely if you're catless as there's no need for a rear O2 sensor to sniff out if you're non-existant catalytic converter is working or not.
Cobb should have a way to disable to code for Catless vehicles. I'm open-source so I can't help you in that regard but start there, don't worry about replacing the sensor until the code disabling options are confirmed, the sensor is doing nothing for your car otherwise.
BrandonDrums is offline   Reply With Quote
Old 06-03-2016, 04:24 PM   #16
Davidbag001
Member#: 366632
2013 wrx hatch
dmg
Check the wiring harness where it goes from the o2. Sensor over the driveshaft shaft I would be willing to bet it's rubbed through ask me how I know
Davidbag001 is offline   Reply With Quote
Code P0137 and P0140 jonpark Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 09-02-2010 06:47 PM
check engine light code P0137 o2 sensor circuit low voltage bank 1 sensor 2 duque Engine Management & Tuning 1 05-09-2010 01:43 AM
Codes P2096 & P0137 SLCDUB Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-04-2007 11:15 PM
P0137 Check engine light code 03WRX83 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-15-2003 06:56 PM
P0137 CEL Code ?? KanosWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-27-2003 07:59 PM
