#26 |
Member#: 7194
MAIC
Vehicle:2005 05sti gt3076 .82 ftw |
#27 |
Member#: 141720
South East
Vehicle:2007 WRX Wagon black pearl |
very nice. however i wonder how close it is to the axle by the way it is not "parallel" to the main pipe.
T |
#28 |
Member#: 25413
Tri-State
Vehicle:2009 junior screwed! |
Yea these pics don't mean much w/o actual in-car fitting.
#29 |
Member#: 170602
Vehicle:6sp 35r Wrx On three cylinders |
If your on a stock turbo as it seems no need for ewg. It will however be super loud if you do get one and will make a tad bit more power with your setup but you should get tuned with the ewg. Oh yeah btw it doesn't have to make noise unless you want it to!
#30 |
Member#: 150747
SCIC
Vehicle:70 GDG / CLS55 AMG 5 Coronas Advan RS wFc#70 |
![]() Picture of the Gimmspeed products. EWG kit with 38mm Tial. Also Gimmspeed exhaust manifold w/ crosspipe. ![]() Video on UR EWG kit on Mr.11.7 downsti car. Thats how loud it is and when you not on freeway like at locate with lower gears it will be even louder since no wind noise and such. So expect to be louder than that. http://videos.streetfire.net/video/B...-vs_120202.htm |
#31 | |
Member#: 41735
TXIC
Vehicle:Just / Yourself NOW! |
#32 | |
Member#: 155450
Vehicle:2007 FXT WRB |
#33 | |
Member#: 155450
YES!!!! that is EXACTLY how it should be done. Well, almost. I would put a flex in the up pipe and make the re-entry a bit more gentle, but thats fairly gentle as it is. I am going to just say it flat out, this is the best recirculating EWG kit I have seen to date. Period. These guys did it right. Its a pity that is isnt for a normal bolt on turbo though. Maybe they make one? |
#34 |
Member#: 143149
Tri-State
Vehicle:07 WRXtra especial CGM |
How does placement of the external waste gate in relation to the flow of exhaust through the upipe come in to play? See how the waste gate is inches away from the main pipe and at an angle which could cause a pressure wave in the pipe... " Y " . I wonder if making the waste gate tube point in the opposite direction(down 180 degrees) would net any gains.. or be harmful?
#35 | |
Member#: 116583
Tri-State
Vehicle:2006 WRX Crystal gray metalic |
When will this be available I would like to pruchase one? shoot me a PM |
#36 |
ok heres a question
if i wanted to plumb back with a catted dp would it have to come back in after cat or before? or would it be better should i say |
#37 |
Member#: 141720
South East
Defiant. I was specificialy referring to the following part:
Bringing that flow back into the turboback negates the benefits of the EWG essentially making the TBE perform as if it were larger (because it doesnt have to flow as much, it flows easier) (yes that is a REALLY bad explaination and I am sure will lead to people misunderstanding it, if I think of a better way to word it, I will edit it) I suppose the points of it "increasing TBE size" in that wording eludes to that being the ONLY benafit to adding an EWG. Maybe disagree was incorrect, and rather clarify would have been more appropriate wording. To the above poster as far as where to plumb it back... lets just use the cobb downpipe for an examlpe. you would want to plumb it in right before the cat. (there is no more space AFTER the cat). where the APS has a cat much higher in the downpoint, you would want to plumb as close to the flange as the bolts will allow. If there is a downpipe that has enough space to plumb back in either before OR after then it is your choice, plumbing after the cat would bring a "possible" advantage over before.... but honestly if everything else is covered then you are really talking about fractions of HP. |
#38 | |
btw i have a shorty dp with a cat |
#39 |
very interesting stuff going on in here. im deff thinking of this setup (38MM EWG sitting in garage right now)
#40 |
Member#: 88273
Vehicle:2003 STi 2.0L Blue |
going to all the trouble of installing an EWG just to overcome boost creep is a lot of effort and $
boost creep occurs when the boost controller opens the wastegate and it is not venting enough exhaust gas through it, thereby driving the turbine harder and creating more boost usually iboost creep is going to happen when you push up the flow on a turbo with a relatively small hotside coupled with larger size compressor ie. increasing boost is pushing the exhaust flow up simple fix for this is to a/ increase the A/R of the turbine housing b/ increase the flow area of the internal wastegate and improve the inflow area with a die grinder ie. if the internal wastgate flow area is 25mm dia you can increase it to 26mm (the flap still makes a positive seal and you have increased the wastegate flow capacity by approximately 10% you also need to increase the size of the spring in the wastegate actuator otherwise the increased surface area may allow the wastgate to open earlier than wanted c/ both a/ and b/ d/ install a turbo that doesn't have boost creep issues if you have a more greatly size mismatched turbine/compressor then maybe an external wastegate is what is required... |
#41 | |
not when done properly . grimmspeed has made the change quite affordable. besides the up-pipes they sell have the option of a block-off plate for if and when the customer decides to go back to using an IWG on their turbo. as long as ur boost control system is in good order, and ur tune is good to go, switching wastegates should not be that big of a deal. (as long as you keep the IWG that your turbo initially came with) |
#42 |
to add to that when u have a dump tube pointed to the ground and AWAY from close suspension parts, you decrease the chances of having soot everywhere. besides you could always have it re-circ'd if u feel like spending the money to do so.
#43 |
#44 |
yea that would suck if they failed lol
#45 |
Member#: 48048
SCIC
Vehicle:size 13 boots |
#46 |
Member#: 99442
International
Vehicle:2006 SGM STI I'm on CORN YO! |
I run a EWG for my DD. It's only loud for everyone else on the road
Inside it's not any louder than most after market eshausts, and it's only loud when you get on it. With my wife in teh car I can drive around with out it opening and it's just fine. But yes it will scare people next to you when you push the pedal to the floor ![]() |
#47 |
i want to run one so bad
#48 |
Member#: 191212
MWSOC
Vehicle:2007 Forester XTi 18G/Spearco/DW/EWG=350whp |
Grimmspeed how long more for the EWG 44mm setup?
#49 |
Member#: 136396
MWSOC
Vehicle:96 L 10 Genesis 99RS |
