Old 09-27-2004, 07:36 PM   #1
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
Default Fast Turn Signal
i was just messing around, looking at my lights...
the car was off, with the key out, in reverse... i don't know if this has anything to do with it...
but i put the key in, turned it to AUX(radio on, nothing else) and put the turn signal indicator to the left... i didn't know they wouldn't go on.
so then, with the indicator stick still down(left turn signal position) i turned the key....
THE SIGNAL'S BLINKING REALLY FAST!!!!
i thought, whoa... is this how you change signal speeds? did i blow a fuse?
so i looked... all four signals still work and both left and right signals blink really fast...
did anyone else know this? did i in fact blow a fuse?(all lights still work)
Handsdown is offline   Reply With Quote
Old 09-27-2004, 08:32 PM   #2
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
double checked... they still are fast and they still light up everywhere!!!!! this is awesome. totally JDM.
Old 09-27-2004, 08:41 PM   #3
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
I think that that means that one of the bulbs are burned out. They do that to tell u in other cars but I dont know about subaru. Do you mean they still light up as in there are no burned bulbs, if so double check.
Trunk_Monkey is offline   Reply With Quote
Old 09-27-2004, 08:53 PM   #4
N'CTRL
Member#: 29871
2OO2 ~WRX~ Macadamia
Metallic
I think you just gained 5hp.
N'CTRL is offline   Reply With Quote
Old 09-27-2004, 09:12 PM   #5
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
so do i!!!
all the bulbs work, i double checked.
Old 09-27-2004, 11:51 PM   #6
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
triple checked... no blubs are out, but i'm worried because...
I CAN'T REVERSE THE PROCESS. i tried everything, they won't blink slow again. can anyone help?
Old 09-28-2004, 07:04 PM   #7
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
no one knows?
i'd really like to be able to make them go regular again...
i've quintuple checked, NONE of my bulbs are out(not even brake lights)
i did take off the third brake light(my stock spoiler has one in it) but that was a good week before this happened...
anyone? bueller?
Old 09-28-2004, 07:19 PM   #8
nqwan
Member#: 2916
02 duburu arr exu
from what i understand the lights will blink fast if the circuit doesnt sense enough resistance from the bulb. this is why a lot of led turn signals make them blink fast. mine blink fast atm cause i rewired my parking lights (smaller bulbs) to be my turn signals.
nqwan is offline   Reply With Quote
Old 09-28-2004, 07:29 PM   #9
zomba_830
Member#: 55221
2002 WRX silver
Are the indicators on the cluster also blinking fast? I'll assume they are.
Have any bulbs been replaced recently?
zomba_830 is offline   Reply With Quote
Old 09-28-2004, 07:42 PM   #10
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
the indicators on the cluster are also blinking fast.
the bulbs are mostly new bulbs... the reverse lights, rear turn signals, front parking lights, and headlights have all been replaced.
the rear turn signals are LED, that's probably what's going on. thanks nqwan!!!
warning (hazards) still blink at the regular speed...
Old 09-28-2004, 08:48 PM   #11
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
It's definitely the LED bulbs. Their current draw is way less than the original bulbs so it causes the high blink rate, same as if a bulb is burned out. There are two solutions- one, add huge resistors in parallel to each LED bulb to normalize the current, two, get an electronic blinker module that doesn't depend on current for its flash rate.
Old 09-28-2004, 08:58 PM   #12
Handsdown
Member#: 29355
2003 GD6 Hate chall
but i'mma maintain
eh... fast flash is alright. rather than get resistors i'll just put in the stock bulbs if it gets annoying.
but thank you!!! the information is invaluable.
Old 12-03-2008, 09:23 AM   #13
highvoltz
Member#: 83743
2009 WRX Premium
Dark Metallic Grey
Same problem on my 09 WRX. stock bulbs. Blinks fast on dash and the actual bulb. Just made the call to have them check it out. I noticed condensation in the housing, I'm thinking that has something to do with it. 700 miles on the car, hopefully simple fix.
highvoltz is offline   Reply With Quote
Old 12-03-2008, 09:53 AM   #14
subaru3169
Member#: 55252
* pullup bar *
what happened with handsdown was that he put leds though, not regular bulbs.. mulder explains it
but for your car with stock regular bulbs..
subaru3169 is offline   Reply With Quote
Old 12-03-2008, 10:20 AM   #15
gte123v
Member#: 114481
2006 Sti
Adding resistors in PARALLEL actually increases the current, I think you meant in SERIES.
gte123v is offline   Reply With Quote
Old 12-03-2008, 11:03 AM   #16
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
No - read what you quoted again - an LED draws too LITTLE current, a resistor in parallel acts like a dummy filament to make it look like a regular bulb
This has no relevance to highvoltz's case which is either a blown bulb or a faulty flasher unit or wiring
UkNuck is online now   Reply With Quote
Front turn signal, brake light, and running light won't turn off Floor it Electrical & Lighting 0 06-27-2009 10:34 PM
Help: Right turn signal flashing twice as fast... Silver04DE Electrical & Lighting 10 09-09-2004 09:06 AM
Turning the side marker light into a turn signal romanom Interior & Exterior Modification 3 03-20-2002 08:48 AM
('93-'01) WRX turn signal bulb size?????? BkylnWReX Impreza Forum 0 06-02-2001 05:19 PM
Message Board Statistics All times are GMT -4. The time now is 10:48 PM.
