Old 12-07-2008, 07:33 PM   #1
lagodcm
Member#: 164038
2013 WRX STAGE 2
Ice Silver
Default Turbo oil suppy...No Filter in Banjo bolt?
Doing my 20g install....I can't find a filter anywhere. Is it the oil line from turbo directly to the block that should have the filter
lagodcm is offline   Reply With Quote
Old 12-07-2008, 08:32 PM   #2
gtasti
Member#: 152036
2004 Sti
ya pretty sure its that line
the one line coming off the top of the turbo to the block
gtasti is offline   Reply With Quote
Old 12-07-2008, 09:32 PM   #3
lagodcm
Member#: 164038
2013 WRX STAGE 2
Ice Silver
Yea, There was no filter in the bolt....
Old 12-07-2008, 10:14 PM   #4
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
my 06 wrx didnt have the filter either. forcedperformance said they have seen some 06's without and some with it.
woodys77 is offline   Reply With Quote
Old 12-08-2008, 02:00 AM   #5
lagodcm
Member#: 164038
2013 WRX STAGE 2
Ice Silver
When I took the bolt out I looked in the hole with a mirror/flashlight...I saw something that look brass like, but that was in the bolt hole....I stuck a screwdriver in there and nothing felt loose.
Old 12-08-2008, 01:35 PM   #6
lagodcm
Member#: 164038
2013 WRX STAGE 2
Ice Silver
I called my dealership....The guy looked up 06 wrx in his computer for the filters and nothing came up. I guess they were never there.
Old 12-08-2008, 09:17 PM   #7
woodys77
Member#: 192147
2007 STI EfiLogics
i pmed you i hope it helps. !!!!!!!!!!!please dont forget to oil the turbo before you start the car!!!!!!!!!!!!!!!!!.
Old 12-09-2008, 07:41 AM   #8
Woodward
Member#: 102424
2003 Tundra
GrEy
There was a bulletin or something about these. I know Subaru was removing them bc they were causing problems and starving turbos.
Woodward is offline   Reply With Quote
Old 12-11-2008, 09:02 AM   #9
pjm
Member#: 73755
05 STI
I just ran into that bulletin somewhere on the internet. Sorry I don't have the link. I don't recall where I was.
Woodward is right on. Starving turbos was the issue. The bulletin listed VIN patterns for determining whether you had the filter or not. If I remember right, they dropped the filter for STI's after April of 2005. I don't remember if it was the same for WRX's, though.
pjm is offline   Reply With Quote
Turbo Oil Feed Line Filter emsfd125 Newbies & FAQs 4 01-03-2010 07:50 PM
Turbo Oil Supply Line Filter Ques. e[tx] Newbies & FAQs 3 07-18-2008 10:53 PM
IMPORTANT:filters in banjo bolts k mier Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 05-07-2007 06:10 AM
Help! No filters in oil lines! cheek_FXT Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 03-01-2006 04:52 AM
Oil feed line, what size banjo bolt for the block? CMJ Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-14-2005 09:42 PM
