Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 12-29-2008, 05:36 PM   #1
klenboy
Member#: 130521
2006 Subaru STi
Default 06 STI: Stock VF39, TMIC, 91 Pump
Mods:-
APS 70mm CAI
APS Turbo Inlet
Perrin EL Header
Perrin Catless DP
Greddy SP2
Hallman RX Pro MBC
Walbro 255
DW 650cc Injectors
Tuned by Ed @ EQ Tuning
The car just pulls hard especially at midrange. Driveability is superb! The car was tuned using Opensource (I believe) and using Ed's road dyno software. Just wanna say thanks Ed for a job well done!
klenboy is offline   Reply With Quote
Old 12-29-2008, 05:44 PM   #2
Steve.804
Member#: 68647
07 STI
Rotated 35R Jorge Tuned
Nice curves and impressive torque! Ed's software reads low so it makes your numbers even more impressive for 91oct.
Steve.804 is offline   Reply With Quote
Old 12-29-2008, 05:52 PM   #3
SpADeZ_WRX
Member#: 160871
Man thats one bad ass VF39 Tune on Pump gas.
299WHP Nice!!
Usually I only see mid 270s or 280s on his software on a vf39 on pump.
Guessing colder temps helped hehe
Enjoy the POWER
SpADeZ_WRX is offline   Reply With Quote
Old 12-29-2008, 06:32 PM   #4
06subie_WRx
Member#: 197860
2006 wr-sex
blue
impressive numbers
06subie_WRx is offline   Reply With Quote
Old 12-29-2008, 06:56 PM   #5
Boxer112
Member#: 78751
2015 WRX STi
Crystal White Pearl
get some E85 in that thing and a retune.
Boxer112 is offline   Reply With Quote
Old 12-29-2008, 07:07 PM   #6
Boosted WRX STi
Member#: 116731
2003 KB Cobra
Sweet numbers and nice curves.... 355wtq is sweet esp on a VF-39! Enjoy!
Boosted WRX STi is offline   Reply With Quote
Old 12-29-2008, 07:13 PM   #7
subenerd
Member#: 72630
2004 STi
355 ft-lbs on the road dyno software
Most torque Ive seen on his software on 91 from a vf39 is ~ 330....thats with similiar mods minus the headers and injectors. Do the headers and bigger injectors make that much of a difference?? Is the car a factory freak?
Awesome numbers regardless.
subenerd is offline   Reply With Quote
Old 12-29-2008, 09:04 PM   #8
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
The headers do make a big difference, especially in the mid range. FYI, it was also around 35F during the tune, so that helped the numbers a bit .
Remember I don't use any correction factors, so the numbers represent the car's actual on road performance at the time of the tune. For the record, this is the most power I've seen out of a VF39 on 91 Octane period. I chalk it up to a good setup and the nice cold air.
-- Ed
Old 12-29-2008, 09:32 PM   #9
CatfaceType-R
Member#: 81102
^^^very impressive
another awesome tune from eqtuning
CatfaceType-R is online now   Reply With Quote
Old 12-29-2008, 10:12 PM   #10
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
He doesnt have enough injector to run E85.
cucamelsmd15 is offline   Reply With Quote
Old 12-29-2008, 10:41 PM   #11
Prevent
Member#: 149114
He'd need atleast 720cc's or maybe even 816cc...
What were your injector IDC"s ?
Prevent is offline   Reply With Quote
Old 12-29-2008, 10:42 PM   #12
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
He needs 860ccs as minimum
Old 12-29-2008, 11:01 PM   #13
HSBabyFace
Member#: 130204
06 WRX IAG Built
FOR SALE!!!
Damn thats a lot of torque. I may need to get some headers now. Nice numbers
HSBabyFace is offline   Reply With Quote
Old 12-29-2008, 11:18 PM   #14
cucamelsmd15
Member#: 122980
Most definitely bare minimum.
On 816cc's my IDC's were well over 90% at sea level.
In retrospect, I would have much rather had something larger. More boost/timing/tuning and more headroom is always better.
Old 12-29-2008, 11:18 PM   #15
sleepersti04
Member#: 146554
2004 STi WRB
30R
looks smooth all the way
sleepersti04 is offline   Reply With Quote
Old 12-30-2008, 12:05 AM   #16
klenboy
Member#: 130521
2006 Subaru STi
You'll have to ask Ed as I didn't ask him (perhaps he may chime in). All I know based on the logs that I saw on his laptop was that peak boost was 19PSI and A/F was around 10.8:1. Thanks for the comments and suggestions guys!
Old 12-30-2008, 01:54 AM   #17
swiftwrx1
Member#: 72352
06 E85 v-mount
wht/bronzse WFC#555
he still can push E85 with those injectors. just cant run gobs of boost. run the same amount of boost and he will still see better numbers
swiftwrx1 is offline   Reply With Quote
Old 12-30-2008, 07:46 AM   #18
cucamelsmd15
Member#: 122980
Um, no. Same boost will leave him out of injector. Sure, he can run E85 if he wants to run 12psi.
Old 12-31-2008, 07:54 AM   #19
downsti
Member#: 63179
2006 Stock Turbo STi
11.7@113mph-115.6mph VF39
congrats to the owner for the new found power,
and once again another badass work from ED @ EQ-Tuning
major props man
this is the highest number vf39 on pure 91 octane on your road dyno ed
if phung could trap 109 - 110mph on stright 91 with only 277whp
i wonder what this car could do haha
downsti is offline   Reply With Quote
Old 12-31-2008, 12:14 PM   #20
WagonGGA
Member#: 134481
08/4 Subaru
Legacy Spec B/Forester XT
Nice Numbers, Now take it to the Track and see what it does!
WagonGGA is offline   Reply With Quote
Old 12-31-2008, 07:11 PM   #21
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Definitely can't run the same boost levels with the same injectors...
The a/f on this tune was set around 10.7:1 and we were seeing IDC's around 80%.
-- Ed
Old 12-31-2008, 07:18 PM   #22
tux121
Member#: 162942
2006 STi Black&Gold
Stage 2
If the AFR was at 10.7@WOT this was a very conservative tune.
tux121 is offline   Reply With Quote
Old 12-31-2008, 07:36 PM   #23
cucamelsmd15
Member#: 122980
For 91? Id call that about right actually.
Old 12-31-2008, 07:36 PM   #24
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
A/F isn't the only thing that makes a tune conservative or aggressive, but you're right, this tune was not what I'd consider aggressive. This car made amazing power very easily so there was no reason to push it too hard.
-- Ed
Old 12-31-2008, 07:37 PM   #25
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yep, most of my 91 tunes are around 10.5-10.8 depending on the car and application.
-- Ed
Fs- Tx: 06 Sti: Stock Hood, Lambo Kit armyssoldierboy Exterior/Styling 4 10-27-2010 02:46 AM
06 STi stock exhaust,TMIC, anf VF39 breathinez Engine/Power/Exhaust 22 10-18-2008 06:18 PM
FS: 06 STI goodies - VF39, TMIC, Brembo, Seats, Control Arms and stuff ProdriveRex NWIC Private Classifieds 15 09-25-2007 07:18 PM
06 sti: Where is the fuel pump? derekok Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 02-13-2007 09:42 PM
Stock VF39 , TMIC, 17 inch BBS Wheels (silver) for sale !!!! Maxspeed23 Private 'For Sale' Classifieds 27 11-04-2005 12:50 PM
