Old 10-08-2008, 08:37 PM   #51
chanders
Member#: 131319
2003 JDM STI
Hey guys, I bought the 05 manual shift boot but it does not have an opening at the top to go pass the "reverse lift" on the STI shifter. Anyone know how to get the 05 boot to work with the sti shifter?
chanders is offline   Reply With Quote
Old 10-25-2008, 08:16 PM   #52
chansaephanh
Member#: 159024
04 Wrx
JBP
is that all the parts needed to do this swap?
chansaephanh is offline   Reply With Quote
Old 10-26-2008, 01:07 AM   #53
abgusaf
Member#: 143122
07 WRB STi
in the werks
you should just have to cut alittle off the top soo it will slip over it then maybe sew it back for a clean look
abgusaf is offline   Reply With Quote
Old 10-26-2008, 01:17 AM   #54
russelljackson
Member#: 192071
2005 Wrx Wagon
Originally Posted by abgusaf View Post
No everything has to be replaced
Very Very easy upgrade tooke me maybe 45mins, everythings bolts right up
heres mine 02 wrx
Just as a reminder make sure to buy a new shift boot, this is an old pic, but as you can see that was the old sti shift boot
is it possible to swap the actual a/c and heater knobs with the 05+ ones?
russelljackson is offline   Reply With Quote
Old 12-28-2008, 10:18 PM   #55
TXwrxWagon
Member#: 191557
2004 WRX Wagon
WRB not so minty fresh
Anyone know if the Armrest extension for the '04 will work on the 05-06 console armrest?
I found most of everything needed for under $200 shipped.
Rob
TXwrxWagon is offline   Reply With Quote
Old 12-29-2008, 01:11 PM   #56
Hando567
Member#: 153595
2006 Impreza WRX STI
SGM
no it will not. I have an arm rest extension for the 05-07 console if you want it. It does not have the hinge that connects the extension to the console though. Other than that it is perfect.
Hando567 is offline   Reply With Quote
Old 12-30-2008, 12:22 PM   #57
vms150
Member#: 172917
2004 WRX
I see that you need the bezel from an 06 TR so the early style hvac fits, I might seem dumb for asking but what does TR mean?
vms150 is offline   Reply With Quote
Old 12-30-2008, 03:59 PM   #58
abgusaf
Member#: 143122
07 WRB STi
in the werks
dont quote me but i beleive it means "tuner ready"
Old 12-30-2008, 05:17 PM   #59
Kiel
Member#: 133439
Sonic Yellow - Stage Taxi
I quoted you, because you're correct.
Kiel is offline   Reply With Quote
Old 12-30-2008, 08:45 PM   #60
mannyOlicious
Member#: 173829
04 dom3 +meth pyah
09 triumph daytona 675
lol^^^
ok so according to what i have read from above... I cant use the e-brake from my 04, I have to either bend it or replace it with the 05+ one, correct?
also, I will need the radio bracket thing so my radio will sit. what if I am using a double din.... would i still need that bracket?
mannyOlicious is offline   Reply With Quote
Old 12-31-2008, 01:02 AM   #61
yaya20
Member#: 130354
2011 535i
Originally Posted by mannyOlicious View Post
lol^^^
I don't think you could bend your 04 handle to fit. Most people use the 05+ handle, but still have to bend it a little to make it sit evenly in the ebrake opening. I believe some people have kept their 02-04 brake handle, but changed the top trim piece to a rhd drive version.
As for the radio bracket, I'm pretty sure you'll need the 05+ bracket. If you use the stock 02-04 radio mounting brackets the radio will not be aligned properly and you won't be able to fit the tr bezel, because the radio will sit too high.
I tried to use the 02-04 brackets with my oem double din and I encountered this problem.
yaya20 is offline   Reply With Quote
Old 12-31-2008, 01:05 AM   #62
abgusaf
Member#: 143122
07 WRB STi
in the werks
^^^correct you need the 05+ bracket
Old 12-31-2008, 01:13 AM   #63
F ur PONY
Member#: 198773
1997 GC8
oh im tackling this install on sunday... im picking up the full console. I guess i will be needing the radio bracket as well? any pics of it?
F ur PONY is offline   Reply With Quote
Old 02-27-2009, 05:41 AM   #64
02wrximpreza
Member#: 151601
2002 WRX-Cobb Stage2
how much work is it to swap the 02-04 a/c and heater controls for the 05+ ones? What's exactly involved to do so?
02wrximpreza is offline   Reply With Quote
Old 03-04-2009, 10:35 PM   #65
vms150
Member#: 172917
2004 WRX
I've got all the parts for this swap sitting in my room. I am only missing a couple of brackets (according to the seller) Pictured are the 2 brackets I have. This big one and the one on the bottom of the storage area of the console. What brackets do I still need so I can get the part numbers off that first post and order them? Thanks for the help.
Old 07-02-2009, 02:35 AM   #66
FTL83
Member#: 142267
2006 tacoma
white
this thread is beautiful! I'm going to call Mill and see what it cost for the whole kit!
FTL83 is offline   Reply With Quote
Old 07-02-2009, 07:42 AM   #67
SMP
Member#: 206350
2004 PSM WRX
VF30
Does anyone have the part number for the radio bezel for manual controls ( 06 WRX TR )
SMP is offline   Reply With Quote
Old 07-21-2009, 04:00 AM   #68
BuyMeAnEnergyDrink
Member#: 195504
2004 OEM+ WRX Wagon
SRR
Three questions for anyone who has done this. I have a full 05 STI center that I'm installing in my 04 wrx.
1) Is it okay to unplug my security box so I can remove my e-brake?
2) I have the 05+ climate control knobs. Is it a plug and play with my 04 harness or will I need to mess with that as well?
3) And does anyone have any pictures of where hey re-located their side mirror adjustment button?
BuyMeAnEnergyDrink is offline   Reply With Quote
Old 07-21-2009, 04:37 AM   #69
evo 3ater
Member#: 133765
06 sti
black
you can not use the sti knobs or radio bezel you must have the 05-06wrx TR bezel,us 04 guys use a cable style hvac controls and 05 06 use electronic controls that has servos and multiple climate sensors its nearly impossible to switch over thats why we use every thing but the bezel and knobs
evo 3ater is offline   Reply With Quote
Old 07-22-2009, 01:19 AM   #70
BuyMeAnEnergyDrink
Member#: 195504
2004 OEM+ WRX Wagon
SRR
bump for last post help.
Old 07-22-2009, 11:40 PM   #71
evo 3ater
Member#: 133765
06 sti
black
im doing this conversion on my 04 wrx this weekend. I found some one with wrecked 05 wrx tr and sold me the complete center console with brake and brackets and vent for 200 shipped. if you look under (car part out for sale) I always see the wrx tr in their thats the place to get these pieces
Old 07-25-2009, 11:56 PM   #72
evo 3ater
Member#: 133765
06 sti
black
I did the swap it was quite easy an straight forward the only other bracket you need is the one that goes bellow the air bent it small little brackent but you can still do the swap if you dont have it your air vents will just slide in and out by hand
Old 07-26-2009, 10:39 PM   #73
STREETFAME16
Member#: 82224
PICS????
STREETFAME16 is offline   Reply With Quote
Old 07-27-2009, 11:41 AM   #74
Phreaker
Member#: 169914
2017 WRX Premium
2011 MBP Forester XT
1) yes, the ebrake has to be slightly modified to work (its covered in one of the many posts)
2) not plug and play, unless you have a master's in electrical engineering then its not worth attempting.
3) 05+ door cars, mine still hasn't been moved all the way over due to me being super lazy.
If you want to see mine / need a hand with your install let me know.
Phreaker is offline   Reply With Quote
Old 07-27-2009, 04:54 PM   #75
Ride1226
Member#: 201483
2010 WRX
WRBM
Man I wanna do this now. If anyone has the full package hit me up.
Ride1226 is offline   Reply With Quote
04 to 05+ center console swap mgsm666 Subaru Conversions 2 11-19-2012 09:42 AM
04 to 05 center console??? reddrex Interior & Exterior Modification 18 11-16-2012 04:28 PM
04 to 05 center console mbaker Interior & Exterior Modification 2 05-06-2009 02:39 PM
For those 02-04 who wants newer center console fluxcapacitor SCIC Private Classifieds 13 01-31-2008 10:55 AM
02-04 center console to 05+ center console swap? Wrx1234 Newbies & FAQs 2 04-15-2007 05:25 AM
