Old 12-31-2008, 08:38 PM   #1
suberdave
Member#: 101865
88 GL-10 STi
Default Dyno #'s EJ20G with ViPEC
finaly got some numbers with the ViPEC.
had some cracked coiles and a few other small issues, then with the weather i couldnt get back to Drift Office till today to get my "Final" tune.
here is the setup:
96 EJ20G TD05h
FMIC
STI injectors and coil packs
blitz boost controler set to ~16PSI
full 3" trubo back exhaust
Blue is With the Z4 ECU
RED is with the ViPEC
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 12-31-2008, 09:12 PM   #2
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Very nice. Out of curiosity, what TBE are you running?
beaviscih is offline   Reply With Quote
Old 12-31-2008, 09:51 PM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
What did you pay for the vipec?
reddevil is offline   Reply With Quote
Old 12-31-2008, 09:54 PM   #4
suberdave
Member#: 101865
88 GL-10 STi
I am running a Ebay bellmouth downpipe, and i made the rest from 3" exhaust tubeing i found...
paid $1600 for the V2 WRX Plun in play.
-=Suberdave=-
Old 12-31-2008, 10:25 PM   #5
subaruwrx
Member#: 1818
03 1996 Impreza Wa
Soon to be a v3 STI
want to sell your Z4?
subaruwrx is offline   Reply With Quote
Old 12-31-2008, 11:01 PM   #6
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
wow... nice... 35hp gain on a tune...
future plans?!
azn0boi04 is offline   Reply With Quote
Old 01-01-2009, 12:13 AM   #7
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Would it be fair to say that 95% of the power gain was going from 11 to 16psi?
-Rob
rob is offline   Reply With Quote
Old 01-01-2009, 01:05 AM   #8
suberdave
Member#: 101865
88 GL-10 STi
-Rob
well since the baseline run was also at 16PSI that will have nothing to do with it.
the Z4 ECU that i got with the engine was set at 15PSI. that is what it has been running since i installed.
this is all in the tune...
-=Suberdave=-
Old 01-01-2009, 01:20 AM   #9
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Rob... any dyno #'s on your chipped setup? I would love to see how it fares against the Z4 and vipec... I believe you said you are at 16.5 psi. I ask because I am still looking into either chipping or full em and staying with the td05.
blkgm8 is offline   Reply With Quote
Old 01-01-2009, 01:28 PM   #10
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Arrow
-=Suberdave=-
Oh, ok cool, but that brings up more questions
Any WB data?
The Z4 was chipped to get over the boost cut?
Are those the '04 STi injectors? Was the Z4 running those injectors and if so, was it tuned for them?
blkgm8: No numbers from my setup. I won't think about hitting the dyno until I finish the 550 injector tune. Maybe next time Dave heads to the dyno, I can work something out for him to swap out ECUs for a comparison...
-Rob
Old 01-01-2009, 01:46 PM   #11
suberdave
Member#: 101865
88 GL-10 STi
Any WB data?
the wideband on the Dyno was not reading correctly, but i do have a WB in my car and it was logging durring the pulls. it was logging 11.5:1 -12.0:1 under full boost. if we went any ritcher than that it started to loose power.
i dont know anything about this ECU, whe i got the engine with the factory boost reg and sol hooked up it ran at 15-15.5 PSI, and it went Pig ritch 10.0:1 AFR under full boost.
they are 04-05 STI Injectors, they were not in the car with the Z4 ECU. when i installed the ViPEC the 440cc's were at 100-110%DC. so i got something a little larger.
-Rob
i did not show the boost line due to the fact that it lookes like crap. im sure i have a wastgate issue or something. but thats not that big of an issue, due to the fact that i have a VF34 that will be going on soon. along with a new engine and other goodies... but probably not till this summer...
-=Suberdave=-
Old 01-01-2009, 04:58 PM   #12
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
-Rob[/quote]
That would be a nice comparison... One more question... Suberdave... When using the 04 sti 550's. I am assuming you are using some sort of rail modification. Such as the collar adapters, or some other rails, Or... are you somehow getting them to work with the factory 20g rails?
I know this has been beatdown in the injector fits thread, but Just wanted to know if someone actually does have sti 550's working in a stock rail.
Old 01-01-2009, 06:40 PM   #13
DSM_Outback
Member#: 56345
93 Swapped L
Green
I know the graph says uncorrected but what was the correction factor really?
DSM_Outback is offline   Reply With Quote
Old 01-01-2009, 10:16 PM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
I was kind of wondering the same thing. Or just some baseline data like what stock USDM 2.0l WRX's or 2.5l STi's put down on this same dyno would be helpful.
I'm still scratching my head on the 1.1bar Z4 ECU. That's what you'd expect from an STi ECU, not a stock sedan ECU. Are you sure that ECU isn't chipped? Have you ever cracked open the case?
Old 01-02-2009, 12:42 AM   #15
suberdave
Member#: 101865
88 GL-10 STi
i will try to get some more data this weekend... corrected data and boost lines.
the boost is not as stable as i would like to see. but it peaks right around 16PSI.
i have cracked open the ECU, from what i can see its not chipped...
-=Suberdave=-
Old 01-02-2009, 01:00 AM   #16
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Old 01-02-2009, 11:23 AM   #17
suberdave
Member#: 101865
88 GL-10 STi
i used these adapters from Carl Davey, with the stock EJ20G Rails...
http://www.fecker.co.uk/scooby/product.php?id=2
-=Suberdave=-
www.suberdave.com
Old 01-02-2009, 08:26 PM   #18
suberdave
Member#: 101865
88 GL-10 STi
corected numbers with boost line...
red = ViPEC
Blue = Z4
-=Suberdave=-
Old 01-03-2009, 01:57 AM   #19
suberdave
Member#: 101865
88 GL-10 STi
[quote=Matt Monson;25025308]I'm still scratching my head on the 1.1bar Z4 ECU. That's what you'd expect from an STi ECU, not a stock sedan ECU. QUOTE]
max boost registered at 18.72 PSI and as you can see on the graph, it never hit any kind of fuel cut...
-=Suberdave=-
Old 01-03-2009, 02:38 AM   #20
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Fuel cut defenser on the MAP signal? Some funny business is going on with your stock ECU
Back to the tune....where would you say you found the most power on top, fuel or timing? Have you looked your MAF voltage? I bet you are pretty close to the flow limit.
-Rob
Old 01-03-2009, 12:10 PM   #21
suberdave
Member#: 101865
88 GL-10 STi
no FCD on my MAF, wiring is all stock.
found more power with timeing in the mid range, witch translated to more power in the top end also. if we added fuel, the power dropped. not a lot but enough to make it unnessacery to add any more.
i just looked at one of my older logs. with the ViPEC, TPS 100%, RPM 8640, Iinector DC 86%, timing 20.2, MAF 4.75v. so yeah it is maxing out the MAF.
this is with the ViPEC not the Z4, but i would assume it would be about the same... good thing the ViPEC uses primarerly MAP not MAF.
-=Suberdave=-
Old 01-06-2009, 12:15 AM   #22
DSM_Outback
Member#: 56345
93 Swapped L
Green
-Rob
I know you weren't asking me but it seems the EJ20G loves timing up top.
Old 01-06-2009, 04:31 PM   #23
xlur8ed
Member#: 147812
1998 2.5RS
Brilliant Red
interesting....
xlur8ed is offline   Reply With Quote
Old 01-13-2009, 08:17 PM   #24
DRKRYD
Member#: 83482
2000 jdm V2 WRX
blue ridge pearl
Default Congrats!!
Nice numbers...! But im here to help...a lil. I have a close setup to yours as in i have a 95 v2 wrx motor w/td05. Now i also have a Z4 ecu, and my boost peak is the same as yours somewhere in the region of 16.5-18 psi. So use that info if ya need it for reference. Setup in installed in a 2000 coupe. and im keeping and eye on this to see what kind of gains come out once your fully tuned and dialed in.
DRKRYD is offline   Reply With Quote
Old 01-13-2009, 08:20 PM   #25
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
Is your Z4 chipped?
mustang dyno #'s to dynojet #'s team trucha racing Proven Power Bragging 15 01-09-2008 02:11 PM
what kind of dyno #'s are people putting down with a 16g?? Berts_Wrx Proven Power Bragging 3 10-03-2007 02:57 PM
Accesport Dyno #'s on a 06 STOCK STI!-By Gadiel - Great #'s diplo12 Proven Power Bragging 12 01-10-2007 09:56 PM
What are your dyno #'s with one hi flow cat? SupaSizeFries Proven Power Bragging 16 04-05-2004 02:50 PM
