Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 12-30-2008, 09:56 PM   #1
weston666
Member#: 198759
Default subaru baja misfiring and backfiring under accelertation
2003 Subaru baja 100k miles on it.
The car will run perfect under hard acceleration untill I drive it for about 5 minutes, then when i give it more than Half throttle it will start to stutter, backfire and miss on Cylinder 3, I have tested the spark plug wires, looked at the spark plugs, installed new fuel filter, and put in a new throttle body with the 3 sensors, As to no avail. I was also thinking maybe it has a bad fuel injector, but that wouldnt explain why it runs perfect when its cold. Has anyone had these same problems? thanks.
weston666 is offline   Reply With Quote
Old 12-30-2008, 11:14 PM   #2
weston666
Member#: 198759
anyone?
Old 12-31-2008, 12:29 AM   #3
Buck Rogers
Member#: 139234
05NA Lifted Baja MT
Brilliant Silver
Plugs / gap ? And if the plugs are original, than definitely change them
Buck Rogers is offline   Reply With Quote
Old 12-31-2008, 12:34 AM   #4
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
Outback Sport
ecu reflash........ one of my friends had the same prob with a 03 wrx took it to the dealership and presto prob solved. could be wrong though, im just guessing
Baja820 is offline   Reply With Quote
Old 12-31-2008, 12:58 AM   #5
weston666
Member#: 198759
what could be wrong with the ecu????
Old 12-31-2008, 04:37 AM   #6
BajaSleeper
Member#: 186725
2006 Baja Turbo
Are you running higher boost with a boost controller?
BajaSleeper is offline   Reply With Quote
Old 12-31-2008, 07:53 AM   #7
jeromes
Member#: 192299
2011 Forester XT
Exclamation Mass Air Flow Sensor
Could be the Mass Air Flow Sensor. I have a 98 Forester that had about the same symptoms before the MAF failed completely. It had about 150K miles on it.
jeromes is offline   Reply With Quote
Old 12-31-2008, 09:47 AM   #8
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
2003 baja ...
there was nol turbo option...
holland_patrick is offline   Reply With Quote
Old 12-31-2008, 10:04 AM   #9
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
Outback Sport
Dunno...... like i said, my friends 03 wrx started having the same issue one night took it to the dealership the next morning (they actually had to reflash the ecu twice) and it fixed the prob.....just a weird glitch or something.
Old 12-31-2008, 12:58 PM   #10
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
You could try an ECU reset, but I suspect you've probably already done that with all of the work you've already done! Disconnect your battery for a few hours then reconnect.
But I doubt that would help - that really sounds like a sensor problem.
You mentioned a new throttle body with 3 sensors. Which sensors were replaced?
moonzie is offline   Reply With Quote
Old 01-01-2009, 12:25 PM   #11
Hawk296
Member#: 14555
1995 Impreza L
Baja
I agree, change the plugs/wires if you haven't done that yet. Have you checked Camshaft/ crankshaft position sensors? They seem to go bad regularly.
Hawk296 is offline   Reply With Quote
Old 01-01-2009, 07:57 PM   #12
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Hawk - is that on both SOHC and DOHC motors?
Old 01-01-2009, 08:34 PM   #13
Hawk296
Member#: 14555
1995 Impreza L
Baja
In my experience, I have had to replace both of those sensors on Non-turbo DOHC and SOHC engines.
Old 01-11-2009, 01:29 AM   #14
Emsanon
Member#: 152508
2003 Baja
Good ol' Classic Yellow!
I've never run into an issue with it backfiring when I accelerate just when I coast downhill. My '03 pops, I guess it's afterlighting, when I coast because of a lack of back pressure to the engine which I still haven't fixed yet.
Emsanon is offline   Reply With Quote
Old 01-11-2009, 02:45 AM   #15
SoundgardenSuby
Member#: 161524
2013 2.5 FXT
plugs, wires, coilpack, get them replaced, reflash ecu, done.
SoundgardenSuby is offline   Reply With Quote
Old 01-12-2009, 10:36 AM   #16
onslot19
Member#: 191753
2003 Baja, legacy ss
Baja Yellow & black trim
hey the same problem happen to me three months ago. the spark wires looked ok but i decided to pull them out again and look closley and there was a small crack on the boot of cylinder 3 spark wire try the same you might be in good shape
onslot19 is offline   Reply With Quote
Old 01-12-2009, 05:53 PM   #17
dioncgy
Member#: 199941
I am experiencing exactly the same symptoms. In the summer I had the 96000Km service(so new spark plugs and wires). Even before that, I noticed that quite randomly, but never when cold, I couldn't accelerate normally after stopping at a light. I could not predict though when it would happen. Last month it was worse and worse, the frequency of loosing power at lights or after reducing speed was higher, and finally it started to misfire and backfire when I insisted on pushing the gas pedal to get higher than 1000-1500 rot/min on tachometer. I cannot elaborate technically as I am not that qualified. I was able to start just fine at -25C. But after the engine got warmed, it started to stutter. It has periods of running perfectly at high speed e.g 110Km/h, and then stutter. At such high speed it seems to be better because it just recovers quickly, but at low speed, especially when idled, it is just like not all the cylinders work. It helps if I keep it on park at lights and push the gas from time to time when I fill it starting to stutter so that I get more than 2000 rot/min. I suspect some kind of a clot along the gas tract from the tank to the engine. But that might be of course over-simplistic. I also considered that the air/gas ratio not right, as I get a strong smell of unburned gasoline. I booked a service next week. I also need to replace the muffler, which I new I should for few months already.
dioncgy is offline   Reply With Quote
Old 01-15-2009, 02:14 PM   #18
BrunoShield
Member#: 155944
2003 Baja
Black Granite Pearl
My 03 NA/Auto Baja does the same thing as long as the temps are below 0C. Stumbles, won't idle properly, strong smell of unburned gas. I turn off the car, sometimes it dies completely and on restart it's fine. It acts like the injectors are on full bore and it's running on two cylinders. It only happens in cold weather, and only after it's been parked all night. If it was a '68 Dart I'd suspect the choke but fuelies don't have one. It's done that since I bought it almost two years ago. Whatever it is, a restart has cured it every time so far.
BrunoShield is offline   Reply With Quote
Old 04-01-2009, 04:26 PM   #19
weston666
Member#: 198759
Turns out the #3 spark plug wire was toast. Good call you guys
Engine Misfiring and backfiring when i push the gas pedal more than half way weston666 Service & Maintenance 8 01-03-2009 10:44 PM
Genuine Subaru Painted Front and Rear under Spoilers and sideskirts LangstonSubaru Exterior/Styling 65 06-25-2004 10:37 PM
Cat Back and misfire or backfire scoobieREX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 04-24-2003 04:03 AM
Subaru Announces Pricing on 2003MY Baja Sport and Two All-New 2003MY Outback Models Jon [in CT] News & Rumors 1 03-06-2003 12:32 AM
Detroit Autoshow and Subaru Baja Matt South East Region Forum 8 01-09-2002 11:47 AM
