Old 11-06-2008, 11:25 PM   #51
Platinum Coan
Member#: 173708
1997 SVX LSi
Bordeaux Pearl
Can't wait to see more of this, I would love to have some options for quality suspension upgrades for my '97 SVX! I'll be watching this one closely...
Platinum Coan is offline   Reply With Quote
Old 11-11-2008, 05:11 PM   #52
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
transmission mount is definitely something to look at i ripped apart 2 on my 94 ls (fwd)
Old 11-12-2008, 03:19 PM   #53
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I recently got a 4.44 final 4eat from the junk yard and it had a unique (to me) transmission mount design.
The mount was essentially normal except a stud extended from the upper plate (that touches the trans) and through a large hole in the lower plate (that touches the cross beam). The end of the stud had a large flat face with a bushing on it. Under normal conditions it made no contact with the lower plate but under extreme torque it would limit the distance the transmission would move!
Perhaps you could use something similar?
ciper is offline   Reply With Quote
Old 11-17-2008, 06:23 AM   #54
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Bump for update!
BeBop86 is offline   Reply With Quote
Old 11-17-2008, 09:46 AM   #55
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
See post #47. Economy sucks right now.
Old 11-17-2008, 07:28 PM   #56
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
Don't tell me you're going under
Old 11-17-2008, 10:42 PM   #57
Turn in Concepts
Member#: 93646
Many Track Records
No foreseeable plans for that, but as things get tight fun projects get put to one side.
Old 01-02-2009, 04:03 PM   #58
Ricter
Member#: 18619
'05 WRX Wagon
Subscribing in case there are ever any further updates.
Just got my SVX a few days ago.
Ricter is offline   Reply With Quote
Old 01-03-2009, 12:27 PM   #59
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Congrats. Hope you enjoy it. You'll find it's VERY comfy to drive, but really lacking on a take off. From a moving point you'll see a whole different machine though. Check in over at www.subaru-svx.net You'll find a lot of info and support if you need any.
-Gaddis
Seraphinwolf is offline   Reply With Quote
Old 01-03-2009, 10:12 PM   #60
Storm
Member#: 5218
96L Most Over-
Developed Beater
My 96 Brighton had the same type of mount. Trim the top ears off an STI tranny mount and it'll sit down in the crossmember.
Jay Storm
Old 01-26-2009, 03:26 PM   #61
Turn in Concepts
Member#: 93646
Many Track Records
So a quick update for folks watching this. Suspension bits are still in an untouched state. Economy sucks too much to go off and work on that when we have more pressing parts we're working on.
The alternator went out on the SVX on Friday so replacement (Bosch remanu) went in today. While we were in there I went ahead and threw in a Kartboy crank pulley. Saves 2 lbs.
Old 02-25-2009, 07:05 PM   #62
cozykat
Member#: 160387
'93 SVX (Red)
'11 STI (WRB)
bump. so i can stay updated. currently i'm rebuilding my eg33 so i understand tight budget.
cozykat is offline   Reply With Quote
Old 02-25-2009, 09:01 PM   #63
Turn in Concepts
Member#: 93646
Many Track Records
Update - I have an idler pulley dying. I hope it's one for the accessory belts. I REALLY need to get into there and see if I can replace it. If not the whole pulley then we've got a shop up the way that's pretty good about matching up bearings if you can press them out.
Old 02-25-2009, 09:28 PM   #64
sicksubie
Member#: 101206
1992 Built, S/C'd,
6MT SVX #122 400whp
Still very interested in seeing where this goes...
sicksubie is offline   Reply With Quote
Old 03-14-2009, 08:53 PM   #65
iluvdrt
Member#: 46248
2012 outback 2.5
sky blue
I dont know if he will help (I am sure he would) but Cris (greenmarinesvx) has quite a bit done to his SVX. I believe he has coilovers, a 5 spd conversion and an ECU upgrade which netted him some better MPG's (oooh) and about 10hp/tq, and it it was fairly inexpensive. IDK what else he has done though,....oh he has a sweet sounding exhaust(FWIW)
iluvdrt is offline   Reply With Quote
Old 03-14-2009, 09:54 PM   #66
Ricter
Member#: 18619
'05 WRX Wagon
Too bad he doesn't have an SVX anymore.
Old 03-15-2009, 12:03 AM   #67
sicksubie
Member#: 101206
1992 Built, S/C'd,
6MT SVX #122 400whp
Yeah he sold it a while back...
Old 03-15-2009, 07:32 AM   #68
Turn in Concepts
Member#: 93646
Many Track Records
We know Chris. I didn't know he sold it though.
Old 03-15-2009, 09:35 PM   #69
iluvdrt
Member#: 46248
2012 outback 2.5
sky blue
Yes, I think he got an 06 STi.
Regardless the knowlege is still there, and thats what is needed.
Old 06-27-2009, 05:43 PM   #70
flystiguy14
Member#: 74416
91 SS leggy
pearl white
whats going on with this?
flystiguy14 is offline   Reply With Quote
Old 06-27-2009, 11:36 PM   #71
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Economy sidelined that's what up with it. My car is further along than this one! And I avoid spending money on mine to finish my Impreza.
-Gaddis
Old 06-30-2009, 05:48 PM   #72
Turn in Concepts
Member#: 93646
Many Track Records
-Gaddis
Bingo. right now it's serving daily duty going back and forth from home to the shop, and from the shop to UPS and USPS.
Old 07-01-2009, 07:21 AM   #73
Seraphinwolf
Member#: 150922
97 OBS EZ30R
You forgot the "in style" part. But yeah you gotta get something done at some point. Stock suspension parts suck the big one. That's why I finally had to go to a full coilover set up.... and cause I basicly had no top spring perch left on the rear pass side.
-Gaddis
Old 07-01-2009, 01:39 PM   #74
cozykat
Member#: 160387
'93 SVX (Red)
'11 STI (WRB)
I recently got a hold of 3 stock 2004 sti struts (the 4th was broken in half). The bolt patterns appear to match up to the SVX. I just need to think about what to do about top mounts and springs. I am hoping only slight modifications are needed because in real weight comparisons, my SVX weighed 3630 with me in it and the 04 STI weighed 3500 with driver. I'd rather replace my struts with an adjustable strut (like Tokico D-Spec) than coilover because the coilover ride quality just sucks imo. They are too firm for daily driving and I don't track my SVX.
p.s. I love the Tokico D-Specs. We have been driving around in them and they are awesome. thanx TiC.
Old 07-01-2009, 03:47 PM   #75
Turn in Concepts
Member#: 93646
Many Track Records
don't forget how the endlink attaches to the front strut. You CAN rework it though to make it attach to the control arm if you have a welder handy though.
Project SVX Hites General Community 63 03-03-2009 04:50 PM
It's just after 3am and I just finished installing the TiC rear diff race bushings prototypeWRX Texas Impreza Club Forum -- TXIC 14 02-02-2007 07:02 PM
Has anyone tried the TiC Klunk Killer yet? Greg B Transmission (AT/MT) & Driveline 14 10-04-2005 01:28 AM
project SVX-T could still be alive kastle SVX Forum Archive 2 02-12-2001 12:01 AM
Message Board Statistics All times are GMT -4. The time now is 02:26 AM.
