#1 |
Member#: 47145
MWSOC
Vehicle:2005 LGT 5MT VF52'd SWP |
For those of you who know me, I sold my beloved WRX back in October & picked up a bone stock 2005 Legacy GT 5MT sedan w/ just under 60k miles on it.
I started a thread a few places documenting the modifications, logs, graphs, etc of my modding and tuning, people seemed to enjoy it. Figured I'd post it up here as well. Just a few FYIs. I only run (non-E10) 93 octane, AFRs are in the 11.2-11.4 neighborhood via LM-1 on all but the 100% stock graph. Other than the 100% stock graph, all graphs are peaking at just under 17psi. My STG1 map is posted over on Romraider, although I have not had any feedback from anyone else after running it. I am very near sea level. I do all my own tuning via ECUFlash & Romraider. 100% OEM Mapping, 100% bone stock 2005 Legacy GT w/ just under 60k miles. ![]() Testes1010 STG1 map(tuning + Hallman PRO MBC, no other mods) ![]() OEM mapping vs. Testes1010 STG1 map(21whp/28wtq gain over stock mapping) ![]() graphed log of above post: http://img132.imageshack.us/img132/2950/11132008it5.gif Testes1010 STG1 Map w/ Magnaflow CBE vs. STG1 map w/ OEM CBE (13whp/18wtq gain over stock CBE) ![]() Testes1010 STG1 Map w/ Magnaflow CBE vs. 100% stock OEM Mapping (34whp/46wtq over stock CBE/stock mapping) ![]() Testes1010 STG1 Map w/ Magnaflow CBE, both graphs. ![]() Log of above: http://www.box.net/shared/ixkkbmrqvm logged graph of the above: http://img528.imageshack.us/img528/9062/11182008ob5.gif Crucial P&P&C manifolds, UP, DP, RP & V1 Grimmspeed xpipe. ![]() ^above STG2 Mods w/ STG1 Map w/ Magnaflow CBE vs. STG1 Map w/ Magnaflow CBE(+17whp/+11wtq peak, although there's ~25whp/~20wtq gain at redline). ![]() STG2 Mods w/ same STG1 Map vs. Stock(+51whp/+57wtq max). ![]() logged graph of the above: http://img216.imageshack.us/img216/7...stg1mapds9.gif Compiled: ![]() Enjoy, Jeremy
#2 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
nice documentation.
i especially like the cbe vs cbe plots.....really shows people that the total system effects the backpressure and just getting an elephant d*kic downpipe doesnt give you all the gains. also, those crucial coatings look good and an excellent wrap job on the other pieces. you already know what turbo im gonna suggest ![]() 49 lb/min+ the links to the log arent working for me......what were the idc's on the final setup? |
#3 | |
Member#: 47145
MWSOC
If I was going to really upgrade I'd definitely do a SZ49, Frank50 or the sorts. I never even got a chance to really do any major logging after the Up/DP/etc install other than just seeing the gains w/ boltons. I believe during just the STG1 & CBE it was in the lower-to-mid 70% IIRC. |
#4 |
Member#: 47145
MWSOC
#5 |
Member#: 36033
SCIC
i like it....
#6 |
Member#: 47145
MWSOC
#7 |
Member#: 148219
MAIC
Vehicle:ex FXT. 6spd, IAG built, 35r Jorge tuned |
that is truly awesome
#8 |
Member#: 103232
Tri-State
Vehicle:MY05 GDA, MY04 FXTI 2.5ltr,PPG,Front LSD,4.44 |
+1 Let them talk. Maybe its not pretty but its efficient.
I was sorry to see the wrx go but you have a great platform. Cant want to see what happens down the road. |
#9 |
Member#: 180861
Vehicle:2005 wrx vf34 ppg's 93/E85 PhatBotti Tuned!!! |
How did you wrap the aluminum pans around the pipes to make it look good? Seriously.
#10 |
Member#: 97436
South East
Vehicle:05 WRX/ver8 207/ 4.44fd/rotated3076/FJblue |
Nice thread, love the graphs and descriptions of mods and gains.
Also love the wrap job. I actually did an upipe a few years back with many layers of folded aluminum foil, went that route after regular heat wrap fell apart. I put that foil on with the uppipe about 2 years back, and you know, I went rotated a month or so ago, and when I pulled the turbo and upipe off, the foil was still in excellent shape, dirty yes, but still sound as when I did it. By the way, you say your looking for a turbo, the one I removed from my car was a Blouch dom 2.5r with about 2000 miles on it. PM me if you might be interested! ttyl Trey |
#11 |
Member#: 139385
heck those pans are a great idea. looks similar to some factory heat shielding I have seen
nice write up, impressive as always |
#12 | |
Member#: 47145
MWSOC
That was my inspiration, many of the factory manifolds(non-subaru) come with crinkled alum heat shields, a bit nicer looking than mine but mine only cost <$10 including the ss wormclamp I picked up to secure the pans. |
#13 |
Member#: 41754
Vehicle:03 wrx gt35r, 2.5L, meth |
WHOA. That heatshield idea is pretty tight - I'm gonna go do that like this weekend
#14 |
Member#: 50891
MAIC
That's a pretty cool DIY heat shield.
Since you had already wrapped the pieces you could also use Taylor Reflective Heat Tape. It goes for around $30 for 20ft. It withstands 1100F continuous radiant heat and 500F direct contact. Adhesive backed, easy to cut and easy to wrap. I used it on an intake tube years ago and it was still on after I sold the car. Just a suggestion. |
#15 |
Member#: 47145
MWSOC
I done something similar on my wrx to protect the MAF from radiant heat w/ DEI or Thermotec adhesive backed thermal barrier.
#16 |
Member#: 47145
MWSOC
Should have a VF52 here by Friday.
#17 |
Member#: 127740
MWSOC
Vehicle:2006 FXT-Mine 2007 FXTi-Her's |
Nice job, semi local guy
#18 |
Member#: 94752
MWSOC
Vehicle:2003 wrx wrb |
That is ghetto!
#19 |
Member#: 47145
MWSOC
#20 |
Member#: 3956
Vehicle:2000 Turbo Legacy GT Titanium |
#21 |
Member#: 47145
MWSOC
#22 |
Member#: 133692
SCIC
Vehicle:2003 Chevy Z06 Black/Black |
#23 |
Member#: 47145
MWSOC
^ I'll see what I can wring out of the stock fuel system w/ a slight increase in fuel pressure, by then, it'll be time for tax return.....
#24 |
Member#: 48586
MWSOC
Vehicle:2003 WRX Sedona Red Pearl |
Lookin good Jeremy
#25 |
Member#: 50891
MAIC
| Thread Tools | |
| Display Modes | |
| FS: 2005 LGT 5MT - 4.11 Final | kpluiten | Drivetrain | 40 | 09-09-2010 10:42 AM |
| FS: (UT) APv1 for a 2005 LGT 5MT | keithk831 | Legacy Specific Parts | 1 | 03-31-2010 06:17 PM |
| Feeler: Possible trade - 2005 SWP LGT 5MT for 02-05 WRX/WRX STi | getawaydriver | Private Vehicle 'For Sale' Classifieds | 9 | 08-25-2008 01:35 PM |
| FS: 2005 Legacy LGT 5MT wagon | dashwort77 | Private Vehicle 'For Sale' Classifieds | 4 | 10-16-2007 10:59 AM |
| FS: 2005 LGT 5MT AccessPort w/TDC map | StopSweatinMe | Tri-State Area Private Classifieds | 7 | 04-25-2007 08:21 PM |
