![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 199244
Vehicle:2008 WRX World Rally Blue |
What would be the best size rim and tire combo to put on my 08 wrx wagon.I was thinking an 18x8 or 18x7.5
#2 |
Member#: 184206
SWIC
Vehicle:2013 X1 sDrive 28i gray |
Ok. . . you are going to need to classify what you mean by "best"
its a rim. . . yeah a very straight forward part, but what are your goals with said part? just looks? better grip what? personally go wider, they give more grip, look better. . . pain is tyres are more expensive. next time you thread . . . be specific, no more whats the best ![]() |
#3 |
Member#: 149317
Vehicle:2006 B7 Audi A4 2005 kawasaki zx6r |
Depends on what you are looking for. If you want lighter wheels go with 17x8. If you want looks go with 18x8. If you do either of them with 235/40 tires you won't have to roll/cut your fenders.
#4 |
Vehicle:OK Houston we have an Uncle |
wheels
WHEELS cars have WHEELS and 17x8 is just great |
#5 |
Member#: 169250
Vehicle:2001 Schweizer 300CB (wirlybird) |
Whatever is just barely big enough to fit around your brakes, anything larger is for people who have a small penis and feel the need to compensate.
#6 |
Add Lightness
Moderator Member#: 13699
Vehicle:2007 Lotus Elise (From General) |
TAWRX,
Please fill our your profile (especially your location). In the blue stripe on the top of the page, it's user cp. Wheels are a very individual choice. For me.....I know how many times I "find" a pothole and say out loud "boy....I'm glad I've stuck with 17's" because any 18 would be bent. I'm sticking with 17's on my LGT in a 7" width with a bit of offset go get them more outside the car. This also works well for track. To stay in class, I gotta stick with 17x7 and the offset can't be more than 5mm from stock. There ya go. jack |
#7 | |
the op has an 08 which is TOTALLY 100% DIFFERENT THAN YOUR CAR IF YOU DO NOT KNOW -DO NOT POST |
#8 |
Member#: 172486
Vehicle:95 V4 STi-RA swap Stage 49.8 |
Some people go with 18 because they are getting a big brake kit and requires a large wheel. However, those people I know usually have Volks because they are light.
Moar tire=moar grip. That doesn't mean put a 255 tire on a 7.5 inch rim. |
#9 |
Member#: 168840
TXIC
Vehicle:2008 WRX Sedan Satin White Pearl |
Look ma, theyz spinningz theyz spinningz!
#10 |
Member#: 199244
To be more specific. The rim i am currently interested in is by axis wheels, the widetrack. It is an 18x8...Will this work?
#11 | |
Member#: 106116
Vehicle:2006 WRX Ltd Wagon CGM, VF39 Brentuned |
EDIT: Just FYI, I run 17" x 8" rims on my summer wheels. Come May they will have 235/40 17 tires. Last edited by kilfarsnar; 01-06-2009 at 11:58 AM. |
#12 |
Member#: 194302
International
Vehicle:2007 wrx red |
i have same care and i go 17"-8" ET48 225/45r17 re070
PS anybaby no 235/45r17 is rubbing on WRX2008? need fander roll or no?? |
#13 |
Member#: 106116
#14 |
wheels have rims
cars have wheels road wheels and steering wheels kiddies think cars have 'rimz' because their bicycles have rimz |
#15 |
Member#: 184206
SWIC
^now youre just gettin grumpy
discounttire sells rims lol i think at this point the words are interchangeable maybe im way off base lol |
#16 |
Member#: 64219
Vehicle:2011 Outbackness 2008 Legacy NA Hellastock |
I recommend 17" for the best daily-drive setup. I've had 18's previously, and would not go back. Just a bit harsher....
#17 |
Member#: 187912
VIC
Vehicle:04 psm wrx wagon 1000 hp |
![]() lol just kidding, get 17x8. u need some rubber |
#18 |
Member#: 172486
#19 |
Member#: 37359
Vehicle:2003 WRX |
#20 |
Member#: 149317
Well ok don't get all riled up his profile wasn't filled out, my bad. Op you have to factor in offset also.
#21 |
Member#: 106116
#22 |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
no
the rim is the outer part of the wheel to which the tire is mounted the rim has a certain profile including a bead seat to hold the tire in place in the case of bicycles a wheel is built by lacing a rim to a hub with spokes in the automotive case the whole wheel is cast / forged or pre-welded The Wheel and Tyre Bible is an excellent resource for further information. Now let's get back on topic ![]() |
#23 |
Member#: 159271
RMIC
Vehicle:2013 VW Golf R '95 Escort Rally-X beater |
good explanation UkNuck.
OP, you need to be more specific as to what your reasons are for changing wheel size. example: I went from stock 17x7.5 +52 offset (stock) to 17x8 +48 offset I wanted: wider wheels so I can mount wider tires, slightly wider track and didn't want to worry about rubbing either the struts or the lip of the fender. I got all that and am now just waiting for summer/my stock tires to wear out so I can fully justify putting on 235/40 summer tires ![]() |
#24 |
Member#: 91423
HIIC
Vehicle:2004 PSM STi on Meth Tuned by Chris Black@AMS |
i also wanted a wider stance with more grip. I went with 18x8.5 SVN's w/ a +48 offset. I needed to roll my rear fenders to get those damn 255/35/18's in there
#25 |
Member#: 101220
SCIC
Vehicle:MY05 imprezaRS riding on open diff |
just get 18x9.5 or 10
be hella flush put 235-245 on those suckers and call it a day oh yeah don't forget to roll/pull front and rear fenders |
| Thread Tools | |
| Display Modes | |
| 18x8 size rims. What size tires fit on this? | nos | Tire & Wheel | 13 | 05-05-2013 07:51 PM |
| Best Size Tire for a 18x7.5 Rim.. 02 WRX Sedan | turbobird14 | Tire & Wheel | 3 | 05-01-2008 04:14 PM |
| What is the best size rim that can make your rim flush with the fender? | Stanley Park Rex | Vancouver Impreza Club Forum -- VIC | 12 | 04-06-2007 02:58 PM |
| what size rim is the best 17 18 or 19 | sigma pi | Brakes, Steering & Suspension | 19 | 03-06-2003 07:50 PM |
| What size rims are the best? 17 ? or 18 ? | OreO | Interior & Exterior Modification | 5 | 12-10-2002 11:03 PM |
