Old 12-29-2008, 11:56 PM   #51
Battlesnake99
Member#: 163066
08 2.5i sedan
first: 2009 = 2008 for you
second: http://wrxfanatics.com/blog/2008-parts/full-parts-list/ (most of those suspension parts will work. ask first about the front sway bar though sedans are shorter than the wagons (like in your case))
third: do a search. for basic stuff, try high flow air filter or the hybrid intake depicted in this thread (for the love of god do not install a cold air kit), 2.25/2.5" exhaust, lightweight crank pulley, lighter wheels, better tires, and remove some weight. thats all you can do now for staight line performance, however if your bold you can look into open source tuning (tactrix cable + ROM Raider (no maps really available yet for 08-09)) or the N/A accessport thats coming out, the new delta cams coming out, and headers/ high flow cat. past that your looking at port & polish, big valve jobs, full heads, internals, basically as high as you want to go. be warned that you can spend a good $5k just on the engine, and still have much less horsepower than a stock STi.
hope this helps
Battlesnake99 is offline   Reply With Quote
Old 12-30-2008, 06:54 AM   #52
lawnwrangler
Member#: 198659
2009 imp out sport
sage green metallic
Thumbs up '09 Impreza Tips Reply
Thank You. I thought 2008=2009 but I never got any confirmation. I will look into that website and the other tips you gave. Do you think the horsepower gains and fuel efficiency are worth the cost? Or am I beating a dead horse?
lawnwrangler is offline   Reply With Quote
Old 12-30-2008, 08:13 AM   #53
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
Originally Posted by Zac86 View Post
you're supposed to keep your stock airbox and snorkus, thats why you're getting bad readings.
i intentionally tried to make a short ram intake instead of a hybrid to see what kind of results i got. as it stands right now williaty's observations on older models still applies to the 08-09 as well. i can think of no other reason why i'd still be getting check engine lights at low rpms or at idle other than a large spike in the maf readings. the car is brand new, so it's safe to rule out a bad o2 sensor and i've sealed everything with silicone and even moved the maf around.
my little experiement seems to suggest that the spike at low rpms still exists and as such i'll be converting to a hybrid setup. i think it's important for people to actually go out and try it instead of just assuming.
gains are worth the cost to an extent. bolt ons will produce noticable gains for reasonable costs. if you REALLY want to save money you could even try and find a used exhaust, just make sure it's stainless steel. hybrid intake, exhaust, headers, light weight pully, etc are all worth it. for suspension some stiffer springs and a sway bar are definitely worth it. i have also found that a short throw shifter and new shifter bushings are a worthy investment as well. be patient, do research and shop around a lot.
for a better answer i'd need to know exactly what your goals are. also, fuel efficiency tends not to increase with more mods for me because I love the sound it makes
bcware is offline   Reply With Quote
Old 12-30-2008, 10:26 AM   #54
Battlesnake99
Member#: 163066
08 2.5i sedan
the best value: sway bars. IIRC, your car has NO rear swaybar. bumping this up to a 19mm one is night and day. seriously, it changes it from "lifting up the back of the car" to "carries speed through the turn"
Old 12-30-2008, 10:36 AM   #55
cthomasset
Member#: 189435
2008 2.5i
So true. I just put the OEM WRX bar on my 2.5i last month. Night and day stuff.
cthomasset is offline   Reply With Quote
Old 12-30-2008, 01:45 PM   #56
lawnwrangler
Member#: 198659
2009 imp out sport
sage green metallic
Cool
My goals are to increase horsepower, added torque, increase fuel efficiency if possible, and tighten up the suspension for a more stiff and sporty ride. I am already considering sway bars both front and rear, short throw shifter and intake. anybody know anything as far as chips go? do they void the warranty?
thanks.
Old 12-30-2008, 01:57 PM   #57
Battlesnake99
Member#: 163066
08 2.5i sedan
'chips' dont work, they just make your engine run pig rich. if you want a 'tune' then your options are:
Piggyback (Perfect Power 6, maybe Pro Sequential ECU)
Reflash (the N/A accessport that's coming out in Feb., or maybe the I-speed if they work on our model)
Open Source (buy a tactrix cable, use RomRaider, and tune it yourself or have someone else make a map for you)
Old 12-30-2008, 07:58 PM   #58
KingHardcor
Member#: 186952
'08 2.5i
I've got the waggon. If I put one in would the cross-bar go across the top of the floor in the rear or under it? I'm having trouble picturing it and wondering if it interferes with anything.
Thanks.
KingHardcor is offline   Reply With Quote
Old 12-30-2008, 09:35 PM   #59
Calum W.
Member#: 181932
2008 Impreza 2.5i
I have a feeling you're thinking of a strut tower brace, a very different component.
A sway bar (or stabilizier bar) mounts in four location, two to the body that allow the bar to bend, and a connection to each sides suspension. The sway bar transfers spring tension from one side to the other, allowing the car to have it's springs and dampers setup to keep the tires on the road (read soft) and still limiting body roll.
Calum W. is offline   Reply With Quote
Old 12-30-2008, 09:52 PM   #60
KingHardcor
Member#: 186952
'08 2.5i
You're right, I was thinking of something else.
I know what it is now that you descride it. Thanks.
Old 12-30-2008, 11:08 PM   #61
cthomasset
Member#: 189435
2008 2.5i
Originally Posted by RaceFaceXC View Post
is that snorkus a simple shape or does it have channels and ducts inside the outer shell? its hard to tell from the pic... almost looks like a milk jug. just curious what changes were made between 07 and 08. do you have any pics of the rest of the stock intake?
I finally took some time to take the milk jug off. If you are wondering what that is, look for the pictures on page 2 of this thread.
It really is just a milk jug. This is no snorkus, in fact I think we should call it the milk jug. It has no channels/ducts or anything that would lead to believe it has a purpose other than noise reduction. That being said...
I took mine off and drove around for a few days. Not cool; you get some crazy noise going up from ~2000rpm through to 3000rpm - 4000rpm depending on engine load. The sound finally levels out in the upper rpms. Its so loud in the cabin that I could hear it distinctly from my cat back exhaust. Thats really saying something. Its not a awesome noise either, I remember doing a Ganz flow intake (straight tube to air box) on my brother's old 2001 RS, that sounded cool. This just sounds weird, and the sounds kinda vibrates too...However, I didn't notice any negative side effects, no bogging or hesitation in the low rpms.
I put that sucker back on after a couple days because I just could not stand it any longer.
Old 12-31-2008, 12:36 AM   #62
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
there is just no logical scientific reason why it wouldn't suffer from the same problem as the 05-07's. you should do a test with logs.
Old 12-31-2008, 12:58 AM   #63
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
there is a logical reason to doubt it. some obvious changes have been made to the intake system and possibly some subtle ones. the symptoms i got certainly do support the existence of the same problem in the newer models. there really wasn't anything to lose in testing a short ram intake because it can easily be converted to a hybrid. at the very least i've collected some, hopefully, useful observations that allow us to say more definitively that the problem has carried over rather than just assuming.
i would log if i owned the hardware, but i was under the impression that it wasn't available for the 08+ yet. is that right?
Old 12-31-2008, 03:34 AM   #64
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
the hardware is available, its just that no n/a owner with an 08/09 has sent the RR guys a image of their rom to disassemble as far as I know. So until they get a rom to take apart, they wont have any def's for the 08/09 n/a ecu's.
Old 12-31-2008, 11:25 AM   #65
Battlesnake99
Member#: 163066
08 2.5i sedan
i think RomRaider supports the 08 4EAT ECU... go check the list thouhg im not sure.
Old 01-06-2009, 05:19 PM   #66
Biesty
Member#: 181973
Default I did this as well.
After seeing this post I tried this as well and so far so good. I have a 2005 Subaru Outback 2.5i, bought the intake kit listed and installed it a few days ago. only took about 30 minutes. The 05 only has 2 hoses instead of three so I used one more vacuum cap from the set of 3 on the 3rd hole and then clamped it. I also used the hoses that came with the kit and they fit so I did not have to use 3 brass hose barbs and 8 clamps to connect the hoses together. I only had to use 5 clamps and one brass hose barb. The clamps that came with the original intake did not seem as good as the new ones so I used the ones.
$62 for the intake kit.
$2.29 for the vacuum cap
$2.99 for the hose clamps
$1.09 for the small vacuum cap hose clamp
$13.98 for 2 Silicone couplers
$2.99 for the brass hose barb
$85.34 Total for a new intake system.
I'm having trouble posting the pics (I'm new) but when I figure it out I'll put them on.
I already have a K&N air filter in there so that doesn't count. I drive from SB to Mammoth almost every weekend and so far I have been averaging 27.9mpg (5 trips) round trip driving at around 70-75. Hopefully this will add a little MPG to the drive.
The car seems to drive easier and accelerates faster than it did before. The 2.5i had a pause when you punched it where you would hear the car rev up and then it would accelerate. Now it seems much more instantaneous. There is almost no increase in noise either but I like the new sound better than the stock intake sound.
Hopefully the check engine light won't come on and this will be my new set up.....well except for smog checks ;-).
I'll keep everyone posted on what happens.
Biesty is offline   Reply With Quote
Old 01-07-2009, 12:29 AM   #67
ronoverdrive
Member#: 181743
2008 Impreza 2.5i
dark M. Gray
Yeah it supports the Automatic 08 2.5i. If I had access to a Tactrix 2.0 cable I'd copy my rom and send it in. Sadly no one near me as far as I know has a Tactrix 2.0 cable. Though I'm hearing rumors in 2 or 3 months we'll have an NA Cobb AP or something similar which I might hold out for.
ronoverdrive is offline   Reply With Quote
Old 01-07-2009, 03:31 PM   #68
Battlesnake99
Member#: 163066
08 2.5i sedan
those rumors would be started by me I talked to Sean S. of Rallitek and he and Surgeline Tuning are working on a 2006+ (maybe 05 too) N/A Acessport.
but yeah right now im saving up my money and waiting to see what happens with this raptor supercharger kit. Supposedly, its like 2 hour install, made to be as reliable as possible, and gives around 217 hp and 250 ft-lbs at the crank with very little lag...
if that doesnt work out, my other plans are the tactrix cable/ LC-1 wideband and do a real tune, or maybe those delta cams that are coming out
Old 01-07-2009, 07:24 PM   #69
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
you're going to hold out for a $600 very limited, off the shelf only image flashing device instead of using a fully customizable, better fit to your specific car, weather, fuel, elevation, etc, user customizable solution with way more and oodles better support community than the AP? All I can ask is, "Why?" it can do DTC reading/clearing, too boot. if you dont mind plugging in spreadsheets to graph data, the tactrix cable w/ RR is really like a MODIS with even more usability.
Old 01-07-2009, 11:37 PM   #70
ronoverdrive
Member#: 181743
2008 Impreza 2.5i
dark M. Gray
Because the AP can also be custom tuned for one. For another I can swap maps based on what I'm doing on the fly without dragging my laptop (I don't own a Netbook, I own a full blown bulky 17.1" screen multimedia laptop) in the car since the Tactrix 2.0 cable does not do flashing from a MicroSD card yet last I checked. I'd like to be able to switch maps based on what gas type I'm using for the day (87 daily driving, 91/93 for the track/autox days) and be able to put the car into vallay(sp?) mode when I bring it into a non-dealer shop for work. Plus RR doesn't support my 5spd 2008 2.5i yet. If they add support for my car and the ability to flash with a PocketPC or Android phone before/if the AP comes out I'll most likely hop on that.
Old 01-08-2009, 08:29 PM   #71
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
You value convenience as much as i value everything being perfect for my car. But i hear you on the laptop thing, i have a fairly large, super heavy laptop.
Old 01-09-2009, 08:16 PM   #72
obs2008
Member#: 163068
08 outback sport
i talked to raptor, they said no go on the 08 cause of the ETC
obs2008 is offline   Reply With Quote
Old 01-09-2009, 11:50 PM   #73
tdhardy
Member#: 199711
Cool
Does anyone know if this intake should fit on the 2.2L ej22 N/A engine? I have a 97 Impreza Sport and it's hard to find anything in the way of performance parts for it.
tdhardy is offline   Reply With Quote
Old 01-10-2009, 12:28 AM   #74
VIsubi
Member#: 187834
06 2.5i impreza
Red
Well I sent Tim a photo of my 06 2.5i ECU and still waiting on a reply but idon't see why this wouldn't work on the 2.5i's. the raptor SC kit that is..becaue Ithink the 05's where still drive by wire if I'm not mistaken I could be wrong in this but if this is possible I'll be ordering my kit very shortly. As well as accessport...this should be good with keeping her as close to N/A as ican get with bolt on.
VIsubi is offline   Reply With Quote
Old 01-10-2009, 09:30 AM   #75
obs2008
Member#: 163068
08 outback sport
hmm yeah let us know what he says as i dont think there is much if any difference between the 06 and 08 n/a set up
Cold Air Intake on 2008 2.5i AlexU Newbies & FAQs 12 04-22-2012 12:48 PM
Hybrid intakes for the 2.5i '08+ Rotten Tomato Normally Aspirated Powertrain 2 03-10-2010 09:57 PM
87 octane ECONO / STG1 maps and agressive throttle mapping for 2008 2.5i. Rallitek.com Normally Aspirated Powertrain 0 09-15-2009 02:47 PM
Floor LED usable for 2008 2.5i???? jbd0419 Interior & Exterior Modification 4 02-22-2009 10:14 PM
Maintenance Interval Question for 2008 2.5i c-four Impreza Forum 5 07-11-2008 09:54 PM
