Go Back   NASIOC > NASIOC General > Warranty Issues & SOA Problems
Old 09-05-2002, 03:50 PM   #1
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Default Trouble/Warranty Denial Report Thread: Interior
I had a discussion with Nick a few weeks back, and in an effort to consolidate the troubles people are having with their cars, which will in turn make the issues more apparent and/or harder to ignore (not to mention making this forum neater ) we decided to make sticky threads where people can report their troubles and/or denied warranty stories by problem area, much akin to my http://www.deniedmywarranty.org website, only with a much larger audience. SOA knows about I-Club.com and Deniedmywarranty.org, but the lack of coordination of trouble reports here on I-club (of course it's going to happen... a 'net forum is a stream-of-consciousness kind of thing) and the lack of the sheer number of them on the Deniedmywarranty.org site makes the actual impact far less than what it could be. We decided to utilize these stickied threads to organize and emphasize what is going wrong. I want to emphasize that these threads are not solely for Impreza WRX owners, nor just Impreza owners. We want to hear from everyone in these threads who is having issues. You can use these stickied threads to report warranty denials or simply to say that something's broken that you didn't submit for warranty repair. To keep these threads neat, there will be a standard format used, as found below (I will place an example reply below this post):
Name:
Make:
Mileage:
Time Out Of Use:
Problem And Likely Cause:
Modifications:
Submitted For Warranty Work (Yes/No):
Reason Given For Denial:
Your Story:
Replies deviating from this format will be deleted, no questions asked... sorry, but this has to remain neat and easy to read to be effective. In addition, please do not use this as a chance to bitch about a dealership or SOA- keep it professional and to-the-point, and this will help us all out in the long run .
Brian
http://www.northursalia.com
http://www.imprezamods.com
http://www.scoobymods.com
North Ursalia is offline   Reply With Quote
Old 09-05-2002, 03:51 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Make: 2002 Impreza WRX
Mileage: 100's of stage miles
Time Out Of Use: 1 week
Problem And Likely Cause: Broke right rear suspension hitting a rock
Modifications: Mods that could have contributed to the issue (ie: my turbo blew and I have aftermarket boost control). Please be honest- it helps nobody to say "it just happened."
Submitted For Warranty Work (Yes/No): Yes
Reason Given For Denial: Fill in only if above was "yes" and you were denied warranty coverage
Your Story: I'm a driver for Rally Team USA... it goes without saying
Old 09-09-2002, 03:10 PM   #3
Wheels
Member#: 5410
2008 BMW 335XI
Mileage: 30.2k
Time Out Of Use: 0
Problem And Likely Cause: Hole in carpet round dead pedal (caused by spounge compression under carpet when clutch pressed and causing carpet to pull on corner causing wear (that will teach me for shifting correctly )
Modifications: at the time none
Reason Given For Denial: wear and tear
Your Story: What can i say soa want me to take it to dealers till i find one who will fit it. The also refused me seeing there rep.
Wheels is offline   Reply With Quote
Old 09-10-2002, 06:21 AM   #4
Wheels
Member#: 5410
2008 BMW 335XI
Mileage: 30.2K
Time Out Of Use: 18 hours +
Problem And Likely Cause: Front drivers Window clunking when going up or down (Window regulator lose due to movement in interdoor panel)
Modifications: None
Your Story: 3 times it came losse on the drivers door. Now I need to have the rear pasanger window looked at as its developing the same problem.
Old 09-10-2002, 06:24 AM   #5
Wheels
Member#: 5410
2008 BMW 335XI
Mileage: 30.2k
Time Out Of Use: Nil
Problem And Likely Cause: Broken dash cup holder (cup holder broken for the second time. First time it broke because the pin holding the spring is hollow and snapped off I glued it in and now I am waiting to take it in to have it repaired).
Modifications:
Submitted For Warranty Work (Yes/No): Waiting
Old 09-10-2002, 06:31 AM   #6
Wheels
Member#: 5410
2008 BMW 335XI
Make: 2002 Impreza RS, WRX
Mileage: 7,600
Problem And Likely Cause: Broken glove box relase handel (broke on opening both have snapped in the same place. on both cars)
Modifications: N/A
Old 11-08-2002, 10:38 PM   #7
tdman77
Member#: 9832
2004 STI
[b]Name: TommyD
Mileage: 24K
Time Out Of Use:1.5 hours
Problem And Likely Cause:Fan only works in #4 position
Modifications:None
Your Story:Check the fuse and it was good. They ended replacing the blower motor. Works just fine now. Great service!!
tdman77 is offline   Reply With Quote
Old 11-27-2002, 09:12 AM   #8
bliu
Member#: 5268
03 Honda Blue Egg
Toyota Silver Shoe
Mileage: 26K
Time Out Of Use: will have been 10 days when i get it back
Modifications: BOV, ALK
Reason Given For Denial: N/A
Your Story: It clunks pretty consistently when going down, but doesn't happen when going up. Car is currently at dealer getting fixed. Edit: dealer says it is now fixed. Other probs (see drivetrain warranty thread) are still in the works.
bliu is offline   Reply With Quote
Old 12-12-2002, 12:18 PM   #9
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Mileage: 13000
Time Out Of Use: 0
Problem And Likely Cause: Hole in driver side carpet. Wear and tear that should not be seen in a car that had 11,000 miles on it when the hole was 1st noticed.
Modifications: N/A
Submitted For Warranty Work (Yes/No): No
Your Story:
jblaine is offline   Reply With Quote
Old 12-29-2002, 02:03 AM   #10
wolf8314
Member#: 9185
2012 Toyota Tundra
Mileage: 10,000
Time out of use: 3 hours
Problem: Fabric on drivers seat fraying
Mods: None that would cause this
Submitted for warranty work: Yes
Reason for Denial: Normal wear and tear
Story: Noticed fabric coming apart. Took car into dealer, they at first denied service claiming it was normal wear and tear. Explained that car only had 10,000 miles on it and if this was normal than "Pigs could fly". Seat cover was replaced under warranty.
wolf8314 is offline   Reply With Quote
Old 01-02-2003, 09:44 PM   #11
Big Joe
Member#: 3722
2002 WRX Wagon
Make: Subaru
Mileage: 30000 something
Time Out Of Use: 3 hours
Problem And Likely Cause: Driver side window stuck open, window regulator loose
Modifications: None
Submitted For Warranty Work (Yes/No): YES
Your Story:
My window started with loud screaching noises at the corner near the mirror. After a while it would not close at the top, window was out of alignment and prevented the door closing. The very top of the window was touching the upper part of the door seal, thus the door not closing. I had to leave a 1/2 inch gap of the window open at the top in order to close the door.
Now the funny part. While coming home from work in dowtown L.A., a homeless person in a wheel chair was asking for money at the stop light. The first car gave money, being New Year's eve and in the spirit of giving, I opened my window all the way down and handed him some change. Light turns green, he says "happy new year and thanks!", I lift up on the window button, and it's stuck! What the ?
Props to Renick Subaru for fixing this quickly and according to the service advisor it was the first Subaru they had problems with the window.
joe
Big Joe is offline   Reply With Quote
Old 01-12-2003, 09:38 PM   #12
buymeasti
Member#: 24091
Default Re: Trouble/Warranty Denial Report Thread: Interior
Make: 2003 WRX
Mileage: 6000
Problem And Likely Cause: Shift knob rattle due to STi Short shift kit
Reason Given For Denial: Says its normal due to harder bushings in the STi short shifter causing excess vibration
Your Story: Dealership was very nice, took knob off the shifter shaft, inspected the knob, says the knob is not broken and that the rattle (which only rattles when the knob is on -- when I drive with the knob off there is no rattle) is normal sue to STi ssk assembly. But, nobody else I knows has this rattle with the factory knob and the STi ssk. Suggested to try an aftermarket knob, or bring it back if noise got worse. All I was expecting was a new knob...but couldnt convince them to give me one...
buymeasti is offline   Reply With Quote
Old 02-15-2003, 01:10 AM   #13
ratboy
Member#: 4619
Make: 2002 WRX
Mileage: 17K
Time Out Of Use: N/A
Problem And Likely Cause: Drivers window sceeches when being opened and closed. Window out of alignment? I've already had them replace the window seal for a wind noise. I've asked to have it fixed three times.
Modifications: none
Submitted For Warranty Work (Yes/No): yes
Reason Given For Denial: not denied, just not fixed yet.
Your Story: screeches almost everytime I roll it up or down.
ratboy is offline   Reply With Quote
Old 02-15-2003, 01:35 PM   #14
TSReynolds
Member#: 21015
2002 Impreza WRX
Make: 02 WRX
Mileage: 6000
Time Out Of Use: 1 day
Problem And Likely Cause: Wind noises rushing by window when closed all the way. Screeching of all windows when going up.
Modifications: Tinted windows
Your Story: They said I had a defective window pannel and they fixed it. They also had to change all of the weather stripping because that too was defective. I still can kind of hear the wind noise. The screeching is gone. They tighted the back window so much that it has now peeled my tint off. Thanks guys! You turn one problem into another!
TSReynolds is offline   Reply With Quote
Old 02-15-2003, 01:37 PM   #15
TSReynolds
Member#: 21015
2002 Impreza WRX
Make: 02 WRX
Mileage: 200 at the time
Time Out Of Use: 2 hours
Problem And Likely Cause: The front passenger side electric door lock switch jammed into the carbon fiber trim and did not work.
Modifications: None
Your Story: Got the car. 3 days later I had the problem. They fixed it though
Old 02-27-2003, 01:10 PM   #16
Subareese
Member#: 21124
World Rally Blue Pearl
Default Air vent problem
Make: MY01 Impreza 2.2L
Mileage: 250 at the time
Time Out Of Use: 4 hours
Problem And Likely Cause: The fan does not seem to blow air out of the air vent on the center console closest to the steering wheel.
Modifications: PDM CAI, WRX rims and tires.
Reason Given For Denial: Not Denied
Your Story: I have had this problem ever since I got the car, I have taken it in 2 times, both times they haven't fixed the problem. The last time the tech told me that this is normal and that there is nothing to fix. I don't believe this but what can I do. I know I won't be buying a car from Melody's Subaru in Kirkland, WA ever again, and I would highly discourage anyone else from going there.
Subareese is offline   Reply With Quote
Old 04-01-2003, 09:36 PM   #17
DisturbedKayos
Member#: 24612
1999 2.5RS
silverthorn
Make: 1999 Impreza 2.5RS
Mileage: 76,400
Time Out Of Use: 0
Problem And Likely Cause: Drivers seat fabric seperating on the door side. Foam padding on right of drivers seat by center console gone and metal seat frame poking me in the side.
Modifications: exhaust and lowering springs
Reason Given For Denial: SAS extended warranty does not cover interior or exterior pieces
Your Story: went into dealership to have some other work done and asked the service advisor about the seat. he wrote my repair order up and ordered the seat back material since it was SOP. parts dept. called me when it was in and i made another appointment to have it installed. when i got there they told me that it wasnt covered by warranty and that if i wanted it to be fixed i would have to pay for it myself. i think if i pay $2000 for a FACTORY EXTENDED warranty that it should cover everything like the NEW CAR warranty does.
DisturbedKayos is offline   Reply With Quote
Old 04-16-2003, 02:28 AM   #18
kamui
Member#: 35325
2002 wrx impreza
black/blue
Make: 2002 impreza wrx sedan
Mileage: 240 mi
Time Out Of Use: 3 days
Problem And Likely Cause: battery leaked, acid sprayed around a few areas. ate some of the tubing and paint
Modifications: none
Reason Given For Denial: no answer yet
Your Story: i recently bought the car but after checkin under the hood, i saw the battery wet. realizing it cant be water i looked closer and it was battery acid. it ate up a lot of stuff. some paint got eaten down to plastic. its at the dealers, a subaru rep was supposed to se how much damage there was and the cause so they can see if warrenty will cover
(sorry i seem to have put this in the wrong section)
kamui is offline   Reply With Quote
Old 04-29-2003, 09:07 PM   #19
mikev123
Member#: 9154
Make: 2002 WRX
Mileage: 31000
Time Out Of Use: 8 Hours
Problem And Likely Cause: Misaligned window, Broken window regulator
Modifications: TurboXS Stage III
Reason Given For Denial: None
Your Story: Window was out of alignment for a few weeks, I was planning on getting it looked at next week. Yesterday it went down (fast) and it stayed that way. Subaru of Wilton CT (where I bought it, excellent dealer) was nice enough to repair it under warrantee without an appointment no questions asked. According to the service manager I was the first one to have this problem with a WRX at their dealership.
mikev123 is offline   Reply With Quote
Old 07-31-2003, 10:14 AM   #20
tux
Member#: 40949
2015 fxt
bl ack
Make: 2003 WRX
Mileage: 14000
Time Out Of Use: 2 Hours
Problem And Likely Cause: Window Grinding (up or down) when hitting bump, and horrid squeeking when in motion - no clue on cause
Modifications: none
Reason Given For Denial: Subaru Dealership said it was normal and all WRX did it (and my service manager's wrx does it)
Story: I started happening 3 days after i bought the car last august
tux is offline   Reply With Quote
Old 01-29-2004, 10:58 AM   #21
wrx_snobordr
Member#: 49343
02 wrx
Make: 02 wrx
Mileage: 18k
Time Out Of Use: n/a
Problem And Likely Cause: trunk clunks arround??
Modifications: removed silencer, tein springs
Submitted For Warranty Work (Yes/No): waiting for appointment
Reason Given For Denial: n/a
Your Story: every time i make a turn or stop at a light my trunk makes a weird clunking noise, i checked and nothing seams loose in the trunk itself so i really cant figure it out. the problem started at about 15k and when we changed my springs we checked all the bolts and they were good so im pretty confident its nothing with the suspension. will update when they have a look
wrx_snobordr is offline   Reply With Quote
Old 02-06-2004, 09:30 PM   #22
kochj23
Member#: 32806
2003 WRX Sedan
Make: 2003 WRX
Mileage: 12000
Time Out Of Use: 45 minutes
Problem And Likely Cause: Front left bolt fell out of the seat rail for the driver's seat, making the car rather diffcult to drive.
Modifications: HKS HiPower Cat Back, Injen CAI, other various stereo and minor mods.
Reason Given For Denial: No denial given, they fixed it in 30 minutes.
Your Story: I dropped the car off at Thousand Oaks Subaru and they had it fixed within minutes. I am going to have to bring it in again though, the seat is starting to wobble and I can tell it is loosening up.... Maybe get some lock tight on it this time around.
kochj23 is offline   Reply With Quote
Old 03-07-2004, 08:54 PM   #23
SubaSonic
Member#: 11365
02 N/A, A/T Wagon
Sedona Red Pearl
Default 2.5 T/S Coil pack failure caused by moded sparkplug
Mileage 69k Miles
Time Out: 24 Hrs
Problem and likely cause: Several miles after complety filling tank, (Needle was bouncing on E) car started missing and running rough. I was thinking crappy fuel and dumped a can of Fuel Injector cleaner in tank. That mostly cleaned up the missing, running rough. 2 days later 1 cylinder isnt working when I started car. Had car towed to dealer. Dealer says coil pack and 1 sparkplug wire failed.
Mods: Funny that was the first thing outta the service writers mouth. WRX front brakes, drilled and slotted roters, Master cylinder support bracket, Under drive pullys, WRX side skirts, WRX steering wheel, Swaybar links.
Submitted for warenty claim: Yes, Paid for the extended waranty
Reason for refusal: Dealer claims Bosh sparkplugs are a "mod" ( same as stock only Bosh brand) and refuses to honor extended waranty.
My story: I almost fell out of my chair when told Bosh sparkplugs were being considered a mod. I said in certain terms to fax me the service bulleten or page of service manual to support their claim (I have service manual and know whats there) Several hours later I was fax'ed a page from a owners manual that has recomended sparkplugs and a handwritten statement that his mechanic was looking for this information. I was charged for a tune-up, fuel filter, aircleaner (the one in car 2-3 months old and not dirty when car left at dealer) 4 spark plugs and 4 wires I asked for 3 more wires when called by service rep thinking my other 3 sparkplug wires were near death
SubaSonic is offline   Reply With Quote
Old 03-07-2004, 10:40 PM   #24
kochj23
Member#: 32806
2003 WRX Sedan
Make: 2003 WRX
Mileage: 13000
Time Out Of Use: 1.5 hours
Problem And Likely Cause: Front left bolt fell out of the seat rail for the driver's seat AGAIN one month after getting it fixed.
Modifications: HKS HiPower Cat Back, Freedom Design FSTB, PSI^3 SECS ECU Monitor, Injen CAI, other various stereo and minor mods.
Reason Given For Denial: No denial given, they fixed it in 1.5 hours. This time they pulled the driver's seat to get at it.
Your Story: Last month, almost to the day, I had this very same problem. I suspect that it wasn't properly addressed the first time around. I am going to be rather PO'd if this happens again.
Old 05-04-2004, 11:22 AM   #25
TurboRoo
Member#: 53299
2015 Don't forget
a towel!
Make: 2003 Impreza WRX
Mileage: 18000
Problem And Likely Cause: Problem: Scratched driver's side window. (Original thread about it here.) Cause: According to dealer, dirt on window stabilizer pads.
Modifications: Stock
Your Story: Got the car used about three months ago. I didnít notice it when I got the car. I noticed a few weeks ago that the window had scratches on the outside. See above link to the original thread about it. I had the dealer look at it when I took it in for the cruse control fix. They said it was probably caused by dirt on the stabilizer pads and they could replace it once under warranty. It took about a week for them to get the parts in. I then made an appointment and they replaced it under warranty. They said that the cost of parts and labor for this would be around $400 if I had to pay for it.
TurboRoo is offline   Reply With Quote
Trouble/Warranty Denial Report Thread: Body/Exterior of Vehicle North Ursalia Warranty Issues & SOA Problems 140 07-12-2016 10:53 AM
Trouble/Warranty Denial Report Thread: Drivetrain (Engine, Tranny, Diff, Etc.) North Ursalia Warranty Issues & SOA Problems 2969 07-11-2016 05:52 PM
Trouble/Warranty Denial Report Thread: Electrical (Lighting, ECU, Sensors, Etc.) North Ursalia Warranty Issues & SOA Problems 110 03-12-2016 01:48 PM
Trouble/Warranty Denial Report Thread: Braking System North Ursalia Warranty Issues & SOA Problems 83 05-03-2015 08:24 PM
Trouble/Warranty Denial Report Thread: Suspension North Ursalia Warranty Issues & SOA Problems 52 08-13-2014 06:05 PM
