Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 07-21-2008, 10:35 PM   #276
whitefro420
Member#: 61322
2004 Forester XT
why is this not a sticky? thats ridiculous.
whitefro420 is offline   Reply With Quote
Old 07-21-2008, 11:43 PM   #277
dub c
Member#: 145069
Keep It Sleazy
that is ridiculous!
It used to beee.
This info is major.
dub c is offline   Reply With Quote
Old 07-22-2008, 12:11 AM   #278
irascible
Member#: 159454
2006 WRX CGM
6SPD Cornfed GT30R
Originally Posted by dub c View Post
that is ridiculous!
It used to beee.
This info is major.
+1234567 etc
irascible is offline   Reply With Quote
Old 07-24-2008, 08:59 AM   #279
blackburn_wrx_2005
Member#: 106306
2003 WRX
yellow
wow that was like the answer to life right there! that has anything and everything you could ever ask about turbos!
blackburn_wrx_2005 is offline   Reply With Quote
Old 08-03-2008, 10:12 AM   #280
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
Needs an update for the 2008 STI turbo and soon, once we know the specs, the 2009 WRX turbo, which subaru says will be different from the <'09 cars.
2008 STI:
vf48: 250-325 hp. This appears to be an update to the vf43. It has a P18 exhaust housing and a slightly smaller compressor housing. The spool-up may be slightly faster than a vf43.
Frank
Frank A is offline   Reply With Quote
Old 08-22-2008, 12:06 PM   #281
unclemat
Member#: 114530
2005 LGT 6MT wagon
unclemat is offline   Reply With Quote
Old 08-22-2008, 02:45 PM   #282
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Nice to see more twin scroll options from IHI
chrisarella is offline   Reply With Quote
Old 08-22-2008, 02:49 PM   #283
dub c
Member#: 145069
Keep It Sleazy
Please sticky WRXRallyBlue's turbo list!
Thats a lot of work and its gonna get lost.
Old 08-22-2008, 02:56 PM   #284
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Originally Posted by JDMraR View Post
very good info!
does anyone know whats the difference between the pe1825 and zerosports ar25 turbos?
thanks.
Sorry, I just saw this...
As far as I know the Zero/Sport A/R25 was a PE 1825f sourced directly from Power Enterprises. Z/S may have upgraded the actuator and/or ported it but not much else if anything.
And good luck finding either of them... EDO is their North American distributor and they tell me no more to be had in the world. I even had a buddy in Japan scouring the aftermarket shops in Tokyo and nothing. If anyone finds any LMK... willing to good money for one.
Old 09-08-2008, 08:02 PM   #285
XmikeX
Member#: 184768
05 WRX
toasted white
nice write up help clear alot of questions only onem ajor question is between a 16g and an 18g and WHAT company to go with there are good and bad reviews on all companies i jsut need a reliable good turbo for a 05 WRX
XmikeX is offline   Reply With Quote
Old 09-08-2008, 09:57 PM   #286
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
How about ATP? Their hybrids seem to spool at least as fast or faster than the other Garrett-based ones...
Frank
Old 10-10-2008, 10:22 PM   #287
wronskij
Member#: 186795
Thank you for the info
wronskij is offline   Reply With Quote
Old 10-26-2008, 03:07 PM   #288
tseitz123
Member#: 174346
Thanks for this list!
tseitz123 is offline   Reply With Quote
Old 10-30-2008, 03:22 PM   #289
ShadowIMg
Member#: 31519
2012 Torque Egg
2001 2.5RS Coupe
This could use some update love for the new IHI turbos.
ShadowIMg is offline   Reply With Quote
Old 11-06-2008, 06:49 PM   #290
Big-T
Member#: 160690
2004 sti
wr blue pearl
very useful....i was unsure wat turbo i was gonna go wit but i think im gonna go wit the gt30r after reading up
Big-T is offline   Reply With Quote
Old 11-09-2008, 11:52 PM   #291
Mortal2None
Member#: 190077
2006 Subaru LGT BP
Any news on what a VF47 is? (yet another VF38 replacement?)
Mortal2None is offline   Reply With Quote
Old 11-17-2008, 06:16 PM   #292
Tom2008
Member#: 194539
Default Good Info
Nice thread!
Tom2008 is offline   Reply With Quote
Old 11-18-2008, 12:34 AM   #293
J-rad
Member#: 194623
2002 WRX Sedan
Hey all, newbie to the site, nice thread
J-rad is offline   Reply With Quote
Old 12-02-2008, 06:35 AM   #294
subsecret
Member#: 195826
2001 JDM STI V7 WRX,
VF series turbos are rebuildable as long as the shaft and exhaust turbine are still intack and not bent which is contrary to what everyone says. I have a hybrid VF36 it runs a P20 exhaust housing from a VF22 to convert back to single scroll to fit my headers that has been honed out and hi flowded, the up pipe side of the turbine housing is now the same size as the factory gasket (52mm i think) it has a back cut turbine a evoIII big 16G compressor wheel nissan pulsar GTiR wastegate actuator (12 pound factory spring rate) brass bearing casings inside the roller bearing cartridge instead of polyamide to stop the center bearing failure that all VF turbos are prone to and so i don't have to run it water cooled. At 18psi on a factory version 7 engine STD pink sti injectors and a reflash this setup makes more than 235kw at the wheels (320whp) all the way to 8250 rev cut, it comes on full boost around 2600rpm and i reckon with a set of injectors and a retune i could squeeze another 5psi out of it safely. I got this done extremely cheap way cheaper than any new turbo of equivalent size and spool, food for thought.
subsecret is offline   Reply With Quote
Old 12-03-2008, 12:41 PM   #295
Evilchargerfan
Member#: 183529
i wanna help teh
haters ... love life ...
BY FAR.... the best write up EVARRR!!!
Evilchargerfan is offline   Reply With Quote
Old 01-04-2009, 11:24 PM   #296
diabetk
Member#: 199013
2002 Impreza WRX
white
Thanks!! This gives me some different options to look at now!
diabetk is offline   Reply With Quote
Old 01-08-2009, 01:07 PM   #297
hammrdwn510
Member#: 199526
2007 UGM WRX TR
stg II vf39'd brok'D
Definetly some great info. When the time comes, it will be green all the way!! Puff Puff Pass anyone??
hammrdwn510 is offline   Reply With Quote
Old 01-09-2009, 03:31 AM   #298
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Uhhh, that's what your motor says about 3k miles into the Green, when the ringlands go and she pops.
Audiosavvy is offline   Reply With Quote
Old 01-11-2009, 06:11 PM   #299
Shop7STi
Member#: 193041
74 Pacer
poo brown
Some of the flow rates don't seem to match with the hp ratings. The SBR GT-12 is rated at 55 lb/min but only makes about as much power as a 20G rated at 44 lb/min? Maybe SBR just makes really inefficient turbos or perhaps the numbers need to be looked into a little more.
Shop7STi is offline   Reply With Quote
Old 01-12-2009, 06:53 PM   #300
The Evil Twin
Member#: 57861
2007 LGT
OBP, 04 STi (traded)
Check some of the threads on here about the SBR turbos...not living up to their hype in many cases. Sorry for the OT.
The Evil Twin is offline   Reply With Quote
Subaru Wagons listed first on 10 Used Cars that Seem to Last Forever pepperjack News & Rumors 74 07-14-2015 07:07 AM
is there a Subaru turbo list? housedj General Community 8 03-18-2009 12:48 PM
subaru forum list 949 General Community 10 11-01-2005 11:32 PM
Subaru wish list carrera News & Rumors 9 06-19-2002 08:45 PM
('93-'01) Subaru Mailing List rubadub Impreza Forum 3 08-18-2001 02:40 PM
