Old 01-23-2009, 05:09 AM   #1
Livebytheseven
Member#: 192006
2005 STI
Aspen white & carbon
Default Wet Sanding Tips
Hey guys, I have a terrible oxidized CF hood and trunk. I'm going to try to wet sand and clear coat them but ive never wet sanded anything in my life.
im not even sure how to do it, how much water, what grit, or even how hard i should press....
anyway i'm also going to do a DIY debadge of my front top grille (2005 sti) and I was told i should wet sand the paint to give it a nice smooth finish. anyway, is there a wet sanding "class" forum around here somewhere
Thanks in advance!
Livebytheseven is offline   Reply With Quote
Old 01-23-2009, 10:02 AM   #2
TexSurfer
Member#: 76072
You could read 'how-to' info all day, but in the end no amount of book knowledge is going to help you. You need to practice wet sanding before you get anywhere near your paint. So I'd suggest getting a junk hood or something and working it out first before you touch your own. Just google wet sanding or color sanding you you'll find plenty of info.
TexSurfer is offline   Reply With Quote
Old 01-23-2009, 10:50 AM   #3
blackcompany
Member#: 143158
2007 STI
UGM
lots and lots of water, newspaper grit, no pressure. search search, practice practice.
blackcompany is offline   Reply With Quote
Old 01-23-2009, 11:04 AM   #4
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
wetsanding is not very hard....its gonna take a lot of time to damage paint by wetsanding with 2500 grit. thats like the equivalent to rubbing newspaper on your car...just keep the hood wet and dont apply any pressure. just lightly back and forth (NO CIRCLES) evenly. follow up by polishing to make sure you got rid of all the oxidation. then wetsand again and get it cleared.
Le Saboteur is offline   Reply With Quote
Old 01-23-2009, 01:00 PM   #5
TexSurfer
Member#: 76072
LOL! Are you kidding me? The physical task may not be "hard", but this isn't something to take lightly. First off 2500 = newspaper is making me laugh! Rub your arm with 2500 and newspaper and see how you feel afterward. Weather it be 2000 or 600 you can do plenty of damage in no time if you don't know what you are doing. Thats why I said practice > than theory.
Old 01-23-2009, 01:51 PM   #6
CGM6
Member#: 146911
ALOT of water, keep adding water, don't use pressure and keep your strokes even and consistent
And what ^ said.
Grit will depend on alot of things, things that are hard to say without seeing the product, knowing the goals, etc. Alot of times some wet sanding and buffing will bring life back into damaged clear coats
CGM6 is offline   Reply With Quote
Old 01-23-2009, 05:23 PM   #7
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
that would explain it.
Old 01-23-2009, 06:25 PM   #8
JohnMartin
Member#: 199154
Default yup
Oh yeah
JohnMartin is offline   Reply With Quote
Old 01-24-2009, 01:55 AM   #9
Livebytheseven
Member#: 192006
2005 STI
Ok thanks guys. I've just read that buffing with an orbital polisher would do the trick, then I heard it wouldn't, then i read on here that wet sanding is the best way to go...
no idea. i just gotta get this thing clean, clear, and shiny!
thanks for the help!
Old 01-26-2009, 09:51 AM   #10
TexSurfer
Member#: 76072
Might help if you post picks of what you are working with.
Wet sanding = oops! SCoach Interior & Exterior Modification 9 12-26-2004 04:29 AM
had car wet sanded Chris Morgan Newbies & FAQs 7 01-16-2004 12:44 AM
Wet sanding and buffing subieworx Interior & Exterior Modification 12 01-14-2004 10:53 AM
wet sanding? krzyxkrean Legacy Forum 6 11-17-2003 01:02 AM
How to wet sand? RedlineRex Car Care & Detailing 7 02-06-2002 05:29 PM
