Old 11-17-2008, 08:17 AM   #26
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Originally Posted by Board Dad View Post
I have looked all over and found photos, and part numbers for the remote entry, and security module. I am certain that my car had these to begin with, as there is a logo about factory security. I don't have a keyless entry remote provided with the car when I bought it, and there is a horn under the hood (which has had wires cut to it) I already bought a new remote (hoping that it would just program, and go) Now I don't want to buy anything I don't need, but the symptoms are this: I can only lock/unlock driver door with key, or the tab next to inside door handle. The buttons on driver or pass. side un/lock all 3 other doors though. I am wondering if this sounds like someone has made changes on purpose, or if this car was a victim of a crime sometime way back? I saw the mention that a security module would be found under the armrest, so I will look there in the morning. Any help or guidance would be sweet.
The info in this thread is for the GD (bugeye and later) models and doesn't apply to your '00 which had a different alarm. The module won't be under the armrest so don't bother looking for it there.
Given your description of cut wires, this isn't something we can easily diagnose for you over the Internet. Your best bet is to take the car to a dealer or independent Subaru shop and have it evaluated.
Mulder is offline   Reply With Quote
Old 11-25-2008, 03:40 AM   #27
Big_M_Slim
Member#: 165491
Sedona Red
so if one were to hypothetically arm the system and then lose the fob, one could use the valet key to start the car and disarm the system by turning it in the ignition three times? (in theory of course...)
Big_M_Slim is offline   Reply With Quote
Old 11-25-2008, 12:18 PM   #28
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Yes, either the valet key or master key
RexyGirl is offline   Reply With Quote
Old 11-30-2008, 09:52 PM   #29
Musicalpa
Member#: 196036
2009 Impreza Outback
Silver (two tone)
I have a 2009 Impreza Outback Sport (love it). On Saturday I had the dealership put in a shock sensor, but I am not convinced it is sensitive enough. A car this morning backed up against my car and then moved forward an inch and parked it there (security camera recording) and it never went off. Later I kicked the front bumper and again nothing happened. Where is the shock sensor located for this vehicle so that I can adjust its sensitivity.
For my vehicle, is the shock sensor number:
H711SAG010
407BB12
If so, I have photos of this sensor and the circuit board, showing where the potentiometer is for adjusting sensitivity. I just can't find the darn thing. I've looked under the passenger and driver seat, and under/behind the glove box and do not see it.
If the part number is different than above, can you give me a part number to look for a photo of the sensor?
Musicalpa is offline   Reply With Quote
Old 12-01-2008, 09:52 AM   #30
RexyGirl
Member#: 63616
with mods :)
H711SAG010
407BB12
The sensitivity of the alarm needs to be set by the dealer using the computer. Seeing that the dealer just installed it, take it to them and ask them to lower the number on the setting to make it more sensitive. From the factory they are set dead in the middle on number 5. But, be prepared, if you turn it too low, it will become a royal pain in the butt.
Old 12-01-2008, 12:00 PM   #31
Musicalpa
Member#: 196036
Silver (two tone)
I did find the shock sensor today. It is located on the driver side of the dash board. You open the driver door and pop off the side panel of the dash board and it is right there. You are correct that the dealership has to adjust it (unfortunately). It would be much easier if this was more user friendly. It does not have a potentiometer. Instead it has three tiny dip switches and a port for plugging in a device (probably the computer that makes the adjustments to the software for sensativity). There are no other adjustments on the circuit board. I have pictures of the entire locating and disassembly process but don't know how to upload them to you.
Old 12-01-2008, 08:37 PM   #32
reddoak
Member#: 147628
2011 MAN-WAGON
For the "Sonic" alarm:
Move the gearshift up, down, left, then right. A chime will sound. Then hold down the "A" button and start.
The JDM version goes Up, down 3 times, then left and right.
Pretty detailed write up, it actually is a lot more clear than the owner's manual.
reddoak is offline   Reply With Quote
Old 12-01-2008, 10:20 PM   #33
RexyGirl
Member#: 63616
with mods :)
I think you have been playing too many video games!!
Old 12-02-2008, 06:42 PM   #34
hannibal1
Member#: 164465
04 WRX STI
stg2+intake=292whp,350tq
i have the 05 style and the 04.from each i have 2 keyless entry, i recode easch ones of these and and now i unlock/lock both cars with one keyless
why this happend,i thought that i can use 05 style on both cars each and just for extra keyless 04 style,but now all mixed ,unfortunately i guess i will recode again both styles like before
hannibal1 is offline   Reply With Quote
Old 12-03-2008, 09:53 AM   #35
hannibal1
Member#: 164465
04 WRX STI
hmm i reprogram the controls like original but when my car is next to my sisters imperza i can unlock/lock with one of my keyless entry both cars,the 2nd one is fine-work only on my car,any ideas why this happen about those controls why they have been mixed and unlock/lock both cars with one remote,do i need to get unplug the battery and then plug back after 1min
Old 12-10-2008, 02:57 AM   #36
Evil_Toaster
Member#: 181757
2005 Forester
I love you! I love NASIOC!
Evil_Toaster is offline   Reply With Quote
Old 01-04-2009, 01:11 PM   #37
Mattoichi
Member#: 199158
2000 Impreza RS 2.5
94H Red Mica
Default 2000 RS - Keyless Entry Flashing without alarm - Help
Hi. Have a 2000 RS 2.5.
I don't have the alarm upgrade, just keyless entry AND (bad news) we lost both of our keyless remotes. I have the flashing lights problem and obviously can't use a remote to disable it. For the time being, I have disconnected the keyless entry control box under the dash just to stop the flashing and relay click.
Is there any other reset means aside from going to a dealer? Since I don't have the alarm upgrade, I don't have the reset switch. I could order a replacement keyless entry remote but I wonder if I would be able to program it while the system is in this flashing re-set mode. Ideas?
Separately, anyone know a good source for turn signal relay switch? It's about $100 at the Advance to order. Junk yard didn't have a Subaru close enough to my model, either.
Mattoichi is offline   Reply With Quote
Old 01-04-2009, 01:16 PM   #38
Mattoichi
Member#: 199158
2000 Impreza RS 2.5
94H Red Mica
Hey Mulder.
I have a 2000 RS. I disconnected the wiring harness to my remote keyless entry control box. It's behind the fuse box under the lower dash on the driver's left. I disconnected it myself because I also don't have the keyless entry remote, and without having that, I couldn't reset the flashing lights that happen when you change the battery or do certain other electrical things. Now that I have it disconnected, I also can use the door lock button for all the doors but not the driver's door. Seems maybe yours is disconnected also, and with no keyless remotes, maybe it was done for the same reason. As for the alarm wires, I don't know, but maybe they were cut by an owner with some problem related to this re-set issue. Feel free to contact me if you have a question about the wiring for that box or how I got to mine, etc.
Old 01-04-2009, 01:24 PM   #39
RexyGirl
Member#: 63616
with mods :)
If you have the factory alarm upgrade, you have a reset switch. It is located on the drivers side, left of the steering wheel, at the bottom of the dash trim. It looks like a little top hat if it is not in the hole in the trim. In your owners manual, there is a picture of where it is located. You need this button to not only reset the alarm, but to program any remotes you may purchase.
If you have an aftermarket alarm, this button may or may not have been intergrated into the system.
Old 01-04-2009, 01:29 PM   #40
Mattoichi
Member#: 199158
2000 Impreza RS 2.5
94H Red Mica
Hey Rexy.
Thanks for the quick answer. I had read your earlier quotes about reset/etc. However, as you see, I do not have the alarm upgrade. I only have standard keyless entry and no remote (one stolen with wife's purse, other lost.) Is there any owner reset for my problem?
Old 01-07-2009, 10:30 AM   #41
CarlZap
Member#: 168700
2002 Impreza WRX Wag
Default Thank you....
...for sending this info out again.....I remember seeing it a while back but couldn't find it today......thanks gain
CarlZap is offline   Reply With Quote
Old 01-19-2009, 12:21 AM   #42
Jagular1785
Member#: 194452
The Mr.
Wizard
I have a 97 Outback sport, and I'm not sure on exactly what security features I have. I have the keyless system and the lights flash but no horn chirp. I have noticed a black box in the engine bay that has a 4 wire connector coming out of it and it has a loop of wire going to two of the the wires coming out of the box. Its mounted on the firewall wall, on the drivers side. There's another 4 wire connector that fits into the box's connector. plug it in, and the starter is disabled. My question is: is this the immobilizer for the alarm system, and if so, how do i get it to work? Right now i have the loop in the connector in, and I use an aftermarket fob for the keyless entry, if that helps (although the factory fob does not make a difference in its working).
Jagular1785 is offline   Reply With Quote
Old 01-23-2009, 06:08 PM   #43
4subbySti
Member#: 194141
2004 Sti/Sti
Java Black Pearl/PSM
is there a reset button on a 2004 sti??
i have another question too.
my car when i bought it it didnt come with a remote, so i never used the alarm. a couple weeks ago my car got broken into and they broke my ignition and everything. they didnt take it though. now i bought a new ignition switch from a junkyard and they gave me the factory remote. is there a way to program this on my car??
4subbySti is offline   Reply With Quote
Old 01-23-2009, 07:16 PM   #44
RexyGirl
Member#: 63616
with mods :)
Yes, it is described in the first post of this thread, as long as it is a factory remote. You actually have one of the easier remotes to program.
There is no reset button for your car. To reset it, the battery has to be disconnected.
Old 01-23-2009, 09:29 PM   #45
4subbySti
Member#: 194141
2004 Sti/Sti
thanks alot i really appreciate your help!
Old 01-26-2009, 01:05 PM   #46
snorekl
Member#: 78139
2005 Saab 9-2X
Red
One of my remotes stopped working months ago and I lost the other this weekend, so here's my question. Are these people for real in terms of getting a replacement remote?? Are they new or used???
The dealer wants north of $100 for the remote fob. I almost passed out. I found these guys while searching the part number on the back and now I see that these guys are part of the advertisers.
snorekl is offline   Reply With Quote
Old 01-26-2009, 05:23 PM   #47
b0red@werk
Member#: 24773
2005 WRX STI
Is my car still in valet mode?
When disarmed, it goes blink, pause, blink.
When armed, it goes blink blink, pause, blink blink, pause.
b0red@werk is offline   Reply With Quote
Old 01-27-2009, 09:47 PM   #48
Demon2003
Member#: 129983
2007 STI
Ok so i opened the tear drop remote (07 sti) i assume that the letters in the 8 charter code i just translate to hex? mine is xxxBBxxA so this means when entering B into the door i press 11 times and 10 times for A?
Demon2003 is offline   Reply With Quote
Old 01-27-2009, 10:25 PM   #49
RexyGirl
Member#: 63616
with mods :)
Yes, you are in valet mode
Old 01-27-2009, 10:25 PM   #50
RexyGirl
Member#: 63616
with mods :)
Are you calling a Subaru or Saab dealership?
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 08:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 09:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 07:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-21-2002 11:51 PM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 01:01 PM
Message Board Statistics All times are GMT -4. The time now is 02:11 AM.
