Old 01-25-2009, 06:36 PM   #1
chad1043
Member#: 105818
2006 Impreza WRX TR
WR Blue...
Default Hard Water Spots...
I live in a house with well water and although it is fine for everyday drinking and such, I have had a hard time getting a good wash from my hose. I get white spots and cannot get away from them.
Does anyone have any good suggestions on how I can still wash my car at home?
Thanks,
Chad
chad1043 is offline   Reply With Quote
Old 01-25-2009, 07:26 PM   #2
kpag
Member#: 199984
2008 WRX
You can always buy water filtration systems but they can get expensive ($300+). The best thing to do is to constantly keep the car wet, don't let the water dry up before you are finished. A few tips to accomplish this... wash early in the morning while it's still cool out; during the California summers I will get up at 7AM on Saturday mornings to wash my car. Next, wash in the shade or even in your garage if possible. Finally, make sure you continually spray the car down with water. Wash a couple panels and then soak the car down. Just keep it wet and don't let the water dry on the car. Afterwards, make sure you dry it all up quickly. If you are getting hard water spots you are taking too long and letting the water dry up, don't allow this happen and you shouldn't have a problem with spots.
kpag is offline   Reply With Quote
Old 01-25-2009, 07:29 PM   #3
Magic Marker
Member#: 181568
2011 3.6R Legacy LTD
Steel Silver Metallic
The cheapest way to get filtration would be to get this. I've had it before and it actually worked pretty well filtering out any minerals in the water.
Magic Marker is offline   Reply With Quote
Old 01-25-2009, 07:31 PM   #4
chad1043
Member#: 105818
2006 Impreza WRX TR
WR Blue...
Thanks guys!
Old 01-26-2009, 11:43 AM   #5
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....the following is the inline water filtration system I have (from Autogeek):
http://www.autogeek.net/deluxe-filter-system.html
The water in my area is also hard. I mounted these two to the fence in my backyard which is close to the side door of my garage. I use quick-connects so I can tap into the filters when I wash my vehicles and then unhook the hose(es) when I'm done. The cost is $140 and the soft water filter can be rejuvenated with sodium tablets (a pack is included).
btw, to further help eliminate the possbility of water spots, I wash my vehicles inside my garage. I'm lucky since I have great drainage and enough room. THe filters do a great job. Any spots I might get now are easily removed (not like the hard crusty ones I would have had before).
Old 01-27-2009, 12:41 PM   #6
jooboy
Member#: 138709
11 MDX Tech (CBP)
06 Honda S2K (LBP)
A possible quick fix is to make sure not to let the water dry before you get a chance to dry it with a MF towel. Make sure you wash in the shade, the water will take longer to dry.
jooboy is offline   Reply With Quote
Old 01-27-2009, 03:57 PM   #7
Chris_Lee
Member#: 110667
2006 WRX
I owned a black car before and the Mr Clean set-up is worth it's weight in gold. I just hated having to buy replacement stuff.
Chris_Lee is offline   Reply With Quote
Old 01-27-2009, 10:57 PM   #8
ewreck31
Member#: 192483
mbp
find some dealership that has Zep products and the acid degreaser is safe and works really good
ewreck31 is offline   Reply With Quote
Old 01-28-2009, 12:03 AM   #9
kpag
Member#: 199984
2008 WRX
If the water spots have already etched into the paint then this will do nothing. If they have not yet etched into the paint then this isn't even necessary.
how to get rid of hard water spots imprexaRS03 Car Care & Detailing 15 05-13-2009 03:54 PM
hard water spots need help (I did search) blackout801 Car Care & Detailing 15 10-10-2008 10:57 AM
Help! Hard water spots on wheels *pics* TigsteRz Car Care & Detailing 10 09-08-2008 02:09 AM
Removing Hard Water Spots From Windshield/Glass?? mnm3_8 Interior & Exterior Modification 20 12-04-2005 02:25 PM
Hard water spots on paint lushboy Legacy Forum 15 09-09-2002 08:29 PM
