#51 |
Member#: 184772
South East
Vehicle:2004 Crazy Slow WRX World Rally Blue |
I have a 04 STI, does my upgraded alarm have a starter cut if the alarm goes off? Where is the module, my alarm is not sensitive at all, takes me three or four hard bump to get it to go off. Interested since i just bought it and if not i might put a kill switch in.
I know the 05 come stock with a immobilizer. Im so afraid someone will steal my new baby.
#52 |
Member#: 198861
SCIC
Vehicle:2004 WRX PSM |
anyone know where i can get a cheap oem alarm?? i think i might have everything wired up cuz i see the horn but i dont have a remote (i bought the car used).
#53 | |
Member#: 63616
South East
Vehicle:1996 Volvo 850 Turbo with mods :) |
#54 |
Member#: 63616
South East
The module for the alarm should be under the drivers side dash. Just because you don't have a remoted doesn't mean you have to buy a whole system. If there is already one in the vehicle (I can check and see if it was factory installed) you just need to get a remote and have it programmed. THe horn is also used with the keyless entry system to let you know you have locked the car, it doesn't mean you have an alarm
#55 |
Member#: 78139
MWSOC
Vehicle:2005 Saab 9-2X Red |
I checked both places. I did some research and the FCC ID of some older Subaru models match the SAAB ID. The idea being that the Subaru models are cheaper than the ones at SAAB.
So, need to know if that place is decent (saw some carping online about them) and whether if the FCC ID matches, it will work with my SAAB even though it's a Subaru remote. |
#56 |
Member#: 63616
South East
If they look the same, they should work. Do you know anyone that has a Subaru with a remote like yours? You could try theirs to be sure.
#57 |
Member#: 184772
South East
Ok with my 04 sti if it goes off can some one steal it? I mean if they unplug it then they could steal the car right? I think im getting a better alarm.
#58 |
Member#: 63616
South East
#59 |
Member#: 148737
TXIC
I have a quick question- my remote's panicking option works from like, 30 feet away. But sometimes, locking and unlocking the car I need to be 10-15 feet away, and sometimes it doesn't respond until I press it like 3-4 times in succession. Faulty remote, bad batteries, need a reprogramming?
#60 |
Member#: 159835
NESIC
Vehicle:07 WRX TR BLACK |
I tried to do the " the horn no longer beeps/chirps when i unlock/ lock car" and it didnt work. Anyone else knows how to make it beep again.
#61 |
Member#: 148737
TXIC
i just did it...open the door, press both buttons on the remote for 3 seconds.
#62 | |
Member#: 63616
South East
#63 | |
Member#: 63616
South East
Your system does work as described in the very first post. Your owners manual will tell you how to get it out of valet mode. I have not mastered how to do that one yet Try section 2-8 |
#64 | |
Member#: 78139
MWSOC
Also, I figured that FCC ID would be a better indicator of frequency match than shape of the fob. |
#65 | |
Member#: 63616
South East
Does your remote look like the one in the first post of this thread? (button colors might be gray) http://forums.nasioc.com/forums/show...ht=2004+remote Last edited by RexyGirl; 01-30-2009 at 02:43 PM. |
#66 | |
Member#: 78139
MWSOC
Can someone give me the FCC ID off the back of one of the 2004 WRX remotes that look like this one: ![]() Last edited by snorekl; 01-31-2009 at 08:48 AM. |
#67 |
Member#: 78139
MWSOC
One more question regarding the programming instructions:
For 2001-2006 Models: (the oblong remote with either 2 grey buttons or a blue and orange button) **Make sure all windows, doors, hood and trunk are closed. **Get in and close the door. **Turn the key in the ignition to the 'ON" position 10 times within 15 seconds **You should hear the horn/chirp **Open and close the drivers side door. **Press one button on the remote **Open and close the drives side door **If you have other remotes, repeat the last 2 steps for all remotes **Remove key from the ignition **The horn should beep/chirp again **Check remote(s) My horn works, but my beeper stopped working a long time ago (the electronic lock/unlock beeper behind the grille). Am I still going to be able to program the remote without being able to hear that little chirper??? I'm sure the instructions don't really mean that the HORN is going to sound (maybe I'm wrong). |
#68 |
Member#: 63616
South East
You should not have a problem, it is the horn that beeps.
#69 |
Member#: 78139
MWSOC
Thanks for all the help. I think I need to order it and get it done.
#70 |
Member#: 200408
Vehicle:08 STI White |
Anyone had any problems with thier 08 alarm/security?
#71 |
Member#: 179845
MWSOC
Vehicle:.... Hello? Yes, this is dog. |
I bought a factory keyless from eBay and it works perfectly! Thanks for the info! Only $25 shipped! To be honest...I don't think I opened my door after turning the key to the on position and pushing the unlock/lock button lol. But it still works! All I believe I did was, got in my car, had all doors unlocked, turned key 10 times, horn, pushed the unlock button, I think horn went off after this?, then took my key out, went outside, and boom! Now I can lock/unlock my doors
#72 |
Member#: 184772
South East
I got a question. I recently had someone break into my car and someone tried stealing it. I know i just asked all these questions but in the area i live in i guess i was right. Well the steering column was busted up and the ignition cylinder was hanging down....so my guess is they got into the car tried starting it after they got the cylinder off but failed since the alarm went off and the starter cut activated. I woke up the next morning to see this and my heart just sank if you know what i mean.
Well i went part searching and asked on some local forums and i got a cylinder+switch all of it for like 120 bucks. Of course it dont come with a key so i had to call and make one. Well after i thought about it....i think i set myself up. If the part i bought was out of another stolen sti could they trace it back to me and try getting me for it??? maybe im over-reacting, but im just worried about that now. The guy seemed real skittish and wanted me to get and go, no questions. What do you guys think, any advice? |
#73 | |
Member#: 78139
MWSOC
FCC ID : - A269ZUA111 Subaru Part # 88036ae060 TRANSMITTER KEY LESS $50.25 The only difference is the button color and of course it says Subaru. I ordered mine from http://www.subaruparts.com Beats the $160 price at the stealership. |
#74 |
Member#: 6030
Tri-State
Vehicle:04 Gold FXT 07 WRB FXT Sport |
rexygirl,
great job with your thread.... one thought for you though, there have been a large number of "chirpers" that have failed in a number of models.. you might want to at least make that as an option for your faq answers.... here's a thread regarding it... (it's for the 04's but our 07 fxt had this same problem, fixed under warranty) dm |
#75 | |
Member#: 63616
South East
I thought about that when I wrote this, and hopefully addressed it when I mentioned valet mode. If there is a mechanical issue with the chirper then that is a different topic, but at least I can cross reference that thread. (which I am very familiar with.... ) |
| Thread Tools | |
| Display Modes | |
| Factory Alarm + Keyless entry from 04 FXT | Skidd | Interior/Dressup/Audio & Security | 0 | 01-22-2009 08:26 PM |
| Factory alarm/keyless entry install - Anyone want to help?! | NickWRX | Tri-State Area Forum | 3 | 07-06-2008 09:22 PM |
| All you need to know about ass hair. | WRick | Off-Topic | 22 | 01-23-2006 07:22 PM |
| Factory Alarm / Keyless entry | Woody | Vancouver Impreza Club Forum -- VIC | 3 | 04-21-2002 11:51 PM |
| Factory alarm/keyless entry on MY01 | Safir | Car Audio, Video & Security | 1 | 02-08-2001 01:01 PM |
