Old 01-29-2009, 11:27 PM   #1
FATCanuck
Member#: 142534
Default Compound charged , fully built .
*LATEST PICS ON LAST PAGE*
got a supercharged/turbocharged o6 sti under the knife . the original set up used a gt35 w a .86 ar the new setup will have a 4088 , not too sure of the exact trim and stuff .
weisco pistons
eagle rods
k1 custom machined, knife edged , and coated crank
custom bearings
darton sleeving
o-ringed
cosworth 280's
custom port&polish
twin-scroll 40r
AMG c32 supercharger
twin plate exedy
aeromotive a1000
aeromotive rails
denso 1000cc's
aeromotive fuel pump controller.
custom lines
aeromotive FPR, 10mic and 100mic filters
tial 44mm wastegate
1'' 5/8 321 stainless header/up-pipe.
3 1/2 '' 321 stainless v-band downpipe.
full custom 3 1/2 '' twin tip exhaust , stainless .
thats it fer now . ill get some pics up tomorrow.
FATCanuck is offline   Reply With Quote
Old 01-30-2009, 03:43 AM   #2
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Unless you have 2 sets of those PE850s your going to run out of injector in a hurry. Super charger and 4088? post pic's or.
Fail Boat!
Token-Negro is offline   Reply With Quote
Old 01-30-2009, 05:25 AM   #3
domestic_abuser
Member#: 126696
2002 Fatbody bugeye
03 R1 09 Raptor 700R
Fail Boat!
I agree
needs way more injector
domestic_abuser is offline   Reply With Quote
Old 01-30-2009, 07:23 AM   #4
perrin247
Member#: 129369
2005 WRX STI
World Rally Blue
WOW you guys are working on this car!!! when I first got my WRX in 2004 I remember seeing this thing on on your guys website, brings back memories haha.
perrin247 is offline   Reply With Quote
Old 01-30-2009, 09:37 AM   #5
bachan114
Member#: 99321
2012 WRX (WRB)
"BLU BALZ" is coming 4 u!
Also, why the eagle rods....are you doing things on a budget??
bachan114 is offline   Reply With Quote
Old 01-30-2009, 10:19 AM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
you can say that about the wiseco pistons too....
I'd bet all the money went into the rest of the setup, like the billet crank and those things...oh what are they called?...oh yeah a supercharger and a turbo
Oh and its tomorrow, now where are the pics?!!
Homemade WRX is online now   Reply With Quote
Old 01-30-2009, 11:28 AM   #7
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
wcbjr is offline   Reply With Quote
Old 01-30-2009, 11:50 AM   #8
Jpizzzle
Member#: 95492
2003 WRX with STI
goodies >:)
Originally Posted by wcbjr View Post
HAHAHAHAHA I just busted out laughing at work! Boy am i getting weird looks!
Jpizzzle is offline   Reply With Quote
Old 01-30-2009, 01:47 PM   #9
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
Originally Posted by domestic_abuser View Post
I agree
This is FAT - They were running STi Pinks on a GT35R and claiming something like 450 whp a long time ago.
Capt Crunch is offline   Reply With Quote
Old 01-30-2009, 02:13 PM   #10
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
I agree needs way more injector
You guys all know what this things for right? Can you tell me off the top of your heads how much the injectors will flow with the fuel pressure at 45 psi or 50 psi?
Well in case you're wondering with the fuel pressure at 50psi the injectors would flow right around 1000cc.
Originally Posted by FATCanuck View Post
aeromotive FPR
For what its worth i was running STi pinks with a 60 lb/min turbo. Just cause most people choose to run huge injectors and no FPR doesnt mean its not possible to run smaller injectors and a higher fuel pressure.
Old 01-30-2009, 02:18 PM   #11
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Well, injector size really depends upon the power he is shooting for doesn't it? Maybe he is just shooting for an autocross monster! I miss the instant boost that damn supercharger gives out! And not just the boost, the massive torque!
reddevil is offline   Reply With Quote
Old 01-30-2009, 02:41 PM   #12
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
A typical 40R puts out about, what, 60lb/min of air at the top of its max efficiency range? A typical conversion of HP -> lb/min is 9-10:1. So that is ~570hp.
Using RC Engineering's handy-dandy injector sizing utility, and using it recommended settings, they would need to run the injectors at 100% duty cycle and 52psi.
Now let's add the supercharger into the equation...
Yes, they probably need more injector, or not use such a large turbo.
Old 01-30-2009, 02:49 PM   #13
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
While yes, the supercharger CAN make more boost when compounding, the use of the supercharger is more inportant in making big boost (and big torque) SOONER.
If all you are after is big boost, then there is no reason for the supercharger, just go big turbo. But if you want a monster all the time, then compound/twincharge!
Old 01-30-2009, 02:57 PM   #14
Phatron
Member#: 36033
CEO PhatBottiTuning
^^ maybe meth and/or racegas also.
custom lines
Doesnt the diameter of the line also come into play? If you're flowing 50 psi worth of fuel through 1/4" pipe or 50psi worth of fuel through a 1/2" pipe arent you flowing way more in the 1/2" pipe?
Anyway, for a build like this I wouldnt expect the IDC to be a problem. At least not a "build stopping" problem.
The first time the IDC gets high you either try raising the FP or simply stop and install bigger injectors.
really not that big of a deal.
although, i will agree at first glance its shocking to see 850's with a gt40, let alone a compound gt40.
Old 01-30-2009, 03:37 PM   #15
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Not sure what you are saying here, but that doesn't come into play with 850cc injectors. Not sure why they chose custom lines. Maybe to avoid any fuel differences from cylinder to cylinder? Or maybe intercooler/intake pipe routing.
Old 01-30-2009, 03:44 PM   #16
Phatron
Member#: 36033
CEO PhatBottiTuning
i was saying if they increased the diameter of the fuel lines doesnt that raise the effective cc's also, especially with an increased FP?
I was asking a question. Im not that familiar with FPR's, fuel lines, etc. But it would seem to me that if you increased the size of the fuel lines, you would flow more fuel, right?
Old 01-30-2009, 03:46 PM   #17
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Nope, it doesn't affect the rate of flow since fuel cannot be compressed. The smallest opening controls the max rate of flow. Intercooler and exhaust piping is another story.
Old 01-30-2009, 03:49 PM   #18
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
On a side note, I always wonder why people upgrade their fuel rails and not the lines. The diameter of the fuel lines are much more restrictive than the rails.
Old 01-30-2009, 03:59 PM   #19
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
needz moar pix
Le Saboteur is offline   Reply With Quote
Old 01-30-2009, 04:01 PM   #20
efmd3
Member#: 120985
2002 Impreza WRX
Midnight Black Pearl
its now tomorrow, where are pics?
efmd3 is offline   Reply With Quote
Old 01-30-2009, 04:45 PM   #21
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
This is the reason I like to twin charge. Look at the boost level skyrocket! This is from a rolling start on the dyno @ 3000 rpm. Full boost 26 psi @ 4000 rpm. The first run I popped the wastegate line off and hit 32 psi @ 4000 rpm.... Wheels slipped so no dyno plot for that one.
And when you are driving around @ higher rpms, the moment you step on the pedal, its is about 1 second to full boost! No lag baby.
Old 02-01-2009, 02:57 PM   #22
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Cmon FAT, I wanna see some pics!
Old 02-01-2009, 05:29 PM   #23
ownnij
Member#: 70459
2002 AW Bugeye ej257
6spd, GT3076R, Alky & EWG
wow this thread sucks without pictures. people should really wait until they get some decent pictures up.
ownnij is offline   Reply With Quote
Old 02-02-2009, 09:49 PM   #24
FATCanuck
Member#: 142534
ummmm
Old 02-02-2009, 09:53 PM   #25
FATCanuck
Member#: 142534
[/IMG]
yea , sorry about the delay . im not an interweb jocky , i work . not on a computer either . with that said here we go .
FS/FT : NY: Fully Built 2000 Si Turbo Electron Blue. 21k Miles!! boostaholic84 Private Vehicle 'For Sale' Classifieds 164 09-08-2010 01:59 PM
FS: Compound Charged 2004 STi AaronB Private Vehicle 'For Sale' Classifieds 22 01-06-2007 03:04 AM
Compound charging stock STI? Bc Rich Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 08-03-2006 01:33 AM
Fully Built JDM 2.0 STI High Revving Engine - Built to Order Gruppe-S Services 15 06-01-2006 03:51 PM
Compound Charge Sti 548 Hp MDJWRX Proven Power Bragging 321 06-08-2005 10:53 PM
