Old 02-10-2009, 11:37 AM   #1
noobsauce
Member#: 197563
08 Impreza
Default Help! Removed sticker and glue won't come off
I removed stickers the dealers put on the car and there's some glue residue from the sticker. What can I use to safely remove what's left w/out damaging the paint/clear coat?
noobsauce is offline   Reply With Quote
Old 02-10-2009, 12:04 PM   #2
stierzy34
Member#: 92113
2013 Mini Cooper S
"Martha"
Goo Gone. Just wash it up afterwards and you will be fine. That is what I used when I had sticky residue left from when I debadged my trunk.
stierzy34 is offline   Reply With Quote
Old 02-10-2009, 12:05 PM   #3
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
1st try some car polish....most likely that wont work, but try it.
Get some bug and tar remover from the auto parts store. Spray it on and let it sit 10 minutes or so. If the adhesive is not easily removed or remains quite tacky reapply and try again. If your out side and its cold out the adhesive will be hard, get a hair dryer to heat up the area B4 and during removal.
After its off be sure to clean the area and re-wax it
.....what ever you use to remove the gunk will be forever covered in it, use something that is not your wife's favorite dish towel......
dangerousatom is offline   Reply With Quote
Old 02-10-2009, 12:15 PM   #4
noobsauce
Member#: 197563
08 Impreza
Thanks for the suggestions
Old 02-10-2009, 12:35 PM   #5
TexSurfer
Member#: 76072
clay bar
TexSurfer is offline   Reply With Quote
Old 02-10-2009, 12:37 PM   #6
blackcompany
Member#: 143158
2007 STI
UGM
dont forget to wax after.
blackcompany is offline   Reply With Quote
Old 02-10-2009, 12:40 PM   #7
noobsauce
Member#: 197563
08 Impreza
I already tried to get it out with car polish had no luck. It made the left over glue shiny LOL
Old 02-10-2009, 12:55 PM   #8
ctrent86
Member#: 129199
I have used clay bar with excellent results. If you are a little reserved about using that type of product (which you shouldn't be) then I have used this over the counter product with good results:
Surf City Garage Road Trip Grime Destroyer
Link to Product here
ctrent86 is offline   Reply With Quote
Old 02-10-2009, 01:38 PM   #9
miller91
Member#: 191475
If worst comes to worst, take a razor and lay the blade flat on your paint, be sure to make smooth and consistent passes. Keep it wet with soap and water and be very careful. After that polish and wax.
miller91 is offline   Reply With Quote
Old 02-10-2009, 01:40 PM   #10
blue-sun
Member#: 15934
Try, in this order.
Goo Gone
WD40
Bug & Tar Remover
Scratch X
Clay Bar
As stated, rewax the area when you're done.
blue-sun is offline   Reply With Quote
Old 02-10-2009, 01:41 PM   #11
blue-sun
Member#: 15934
If possible, find a plastic razor blade (I've seen them at some auto parts stores) and use that instead of a real razor blade.
Old 02-10-2009, 02:07 PM   #12
noobsauce
Member#: 197563
08 Impreza
I'm going to try Bug & Tar remover next.
Old 02-10-2009, 02:09 PM   #13
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Goo Gone
3M Adhesive Remover
Big-E is offline   Reply With Quote
Old 02-10-2009, 02:14 PM   #14
DC16A2
Member#: 174357
2002 OBS
I used Turtle Wax Bug & Tar Remover for debadge... heated the gunk up with a hair dryer and sprayed the remover on. The Bug & Tar remover isn't runny, and I let it sit for at least 10 minutes. It definitely required less elbow grease than the letters that I used Goo Gone on =)
DC16A2 is offline   Reply With Quote
Old 02-10-2009, 02:18 PM   #15
antho!
Member#: 159057
2004 ts wagon
aspen white
goo gone ftw, weird but clr worked on gunky stuff too
antho! is offline   Reply With Quote
Old 02-10-2009, 02:51 PM   #16
aDoBo18
Member#: 197254
2014 STi
Ice Silver Metallic
i just used ice... if it is on your window.. it should come off like nothing... with no type off chemical being used and it is very economical... hahaha
aDoBo18 is offline   Reply With Quote
Old 02-10-2009, 03:00 PM   #17
kingman-442
Member#: 63728
blaze yellow
I am with Big-E
3M adhesive remover works great for this kind of thing....no paint damage, no razors. Spray it on, wait 30 seconds and wipe it off with a rag.
kingman-442 is offline   Reply With Quote
Old 02-10-2009, 05:20 PM   #18
BajaGuy68
Member#: 127720
2015 WRX
Lightning Red
I recommend a product called "Sticker Shock" at Autozone. It comes in a small spray can and it works wonders! De-badging my car was easy with this and it did'nt harm my paint!!
BajaGuy68 is offline   Reply With Quote
Old 02-10-2009, 07:16 PM   #19
hannibal1
Member#: 164465
04 WRX STI
stg2+intake=292whp,350tq
go back to dealer and they will fix it for you
hannibal1 is offline   Reply With Quote
Old 02-10-2009, 07:16 PM   #20
Hines
Member#: 116398
08 STI OBP
Tuned By Agile
ive used alot of products for this, the best product ive used thus far is definately meguiars body solvent. works great plus the smell is real nice too....lol
Hines is offline   Reply With Quote
Old 02-10-2009, 09:01 PM   #21
nix-hex
Member#: 67809
1999 2.5 RS coupe
when i debadged mine, i used a good ol eraser, yeah of the pencil persuasion. it took the glue right off. works for stickers too. dont over complicate things!
nix-hex is offline   Reply With Quote
Old 02-10-2009, 09:43 PM   #22
Hines
Member#: 116398
08 STI OBP
Tuned By Agile
no overcomplicating things, eraser is more damaging.....
ive said it before an will say it always, use the products that are made for automotive applications.
i mean you could probably use vegatable oil instead of synthetic in your engine.......but we know how that would work out.
Old 02-10-2009, 09:52 PM   #23
greenc51
Member#: 154681
2012 135i
Alpine White
rubbing compound will take care of it no prob
greenc51 is offline   Reply With Quote
Old 02-10-2009, 10:00 PM   #24
woodys77
Member#: 192147
2007 STI EfiLogics
422whp 421wtq fpgreen
Originally Posted by blue-sun View Post
Try, in this order.
Goo Gone
WD40
Bug & Tar Remover
Scratch X
Clay Bar
thats what i was thinking.
woodys77 is offline   Reply With Quote
Old 02-11-2009, 01:52 AM   #25
TUNERwRX
Member#: 61318
2005 STi
Aspen white
use 3m adhesive removal. That works the best out of all the other methods and is safe on paint. Just be sure to soak the area for a minute or so. You can pick it up at any auto parts store
TUNERwRX is offline   Reply With Quote
OMG my trans won't come off!! Help! MrDrift Transmission (AT/MT) & Driveline 25 05-04-2008 07:43 PM
Caliper won't come off of rotor HELP!! isk8drugfree Newbies & FAQs 9 10-13-2006 08:15 PM
followed all steps. engine won't come off!!! help!!??!?!?!!?? MrSaabaru Subaru Conversions 18 08-12-2005 01:58 AM
HELP! My wheel won't come off the hub! RightyTighty Tire & Wheel 9 12-05-2004 06:45 PM
Cap bolt just won't come off!! Need help! scooby5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-08-2001 12:25 AM
