Mid Atlantic Impreza Club
Closed Thread
Old 02-16-2009, 05:21 AM   #1101
EdsWRX
Member#: 13881
08 spec b
07 335xi
no more theiren
EdsWRX is online now
Old 02-16-2009, 06:12 AM   #1102
Cereb Daithi
Member#: 112349
95 GM8, 98 GF8,
02 GG2, 05 GD6
Originally Posted by GreekPower View Post
No subie just got a dodge stealth with a single turbo . But in the process of looking into getting a bug eye'd STI.
Welcome! Those can def be a bit tricky to find. Most of the guys who swap the STi bits into an older model go for a GC swap so if you have one lined up you are quite lucky indeed. I've only ever really seen a few true bugeye STi swaps in the area.
Cereb Daithi is offline
Old 02-16-2009, 07:49 AM   #1103
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Originally Posted by dennyt4 View Post
How is that turbo? Do you have any numbers or times? I'm looking at a couple different turbos and can't decide what I want. Looking at that Blouch 20G, the Dom 3, and the FP HTA Green.
I don't see a whole lot of people running FP stuff - am I missing something? I know I had an FP Green on my Evo and the HTA35 on the Eclipse and loved both of them.
I am going to run E85 and have seen some pretty good results from the stock turbo on the 08 - 380whp and 430tq from XPT, but I've also seen 450/450 from a Blouch td05 Green on E85.
I know all 3 of those flow differently and that it will come down to how much I want, but I'm curious as to why people shy away from FP.
Dom 1 here. Even though blouch's number do not portray this it is a larger turbo than the 2.5 with a 49 pound wheel. I chose it to preserve my stock internals. Having an 07 sti short block I was a tad worried about that. It is essentially a tdo6/8cm 20G with a slightly larger wheel and comes ported st so it flows a little better. It spools fast and pulls all the way to the point where my crappy wrx cams give up. I plan to run it until I get a built motor. You are welcome to try it out though my clutch just started to slip yesterday. I would love to run E85 but until it becomes more readily available I am leaning more towards meth.
Forced Performance has had some premature failures here and there so a lot of guys have been going with Blouch. That said the FP td05h/7cm 20 was the most fun I ever had with my 2.0L. It was used when I got it and never gave me any problems.
Tenacious Bee is offline
Old 02-16-2009, 08:03 AM   #1104
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Originally Posted by sk84fun21 View Post
yeah except i need a turbo for my 2.0 so it's either vf34, evo3, possible 18g most likely the evo3. i want 300 at wheel numbers it low lag with a fmic and ewg
Too bad you were not around for my 2.0L 20G set up. I shut a lot of people up about lag with that td05/7cm set up.
See, not laggy and the absolute best chance to hit your numbers. The hp is still climbing at red line. With better internals I could have spun it another 500 rpm or more and made low threes on a 2.0L without using meth.
There is a guy with a very nice full sti swapped bug eye that posts here from time to time. V6 or seven motor, full suspension and trans. It is not to cheap to do nor buy when one is for sale. You could do your own suspension mods and swap a 2.5l and six speed in like I did. Couldn't be happier. I can get a chest of drawers in the back of mine too.
Old 02-16-2009, 08:53 AM   #1105
bobert517
Member#: 56656
buy my pants!!!
Originally Posted by EdsWRX View Post
no more theiren
maybe the pens will win a game now. 95% of the team was not playing with any heart, possibly they will now and manage a huge turn around.
bobert517 is offline
Old 02-16-2009, 09:17 AM   #1106
dennyt4
Member#: 85581
2005 Forester XT
2008 Corvette
Thanks for the info! I'm pretty sure I'm going to do the TD06 20G at this point. It's probably going to give more than enough power for a stock engine HA
Speaking of clutches, what does everyone run? I really liked the Exedy twin but I'm open to options.
dennyt4 is offline
Old 02-16-2009, 09:22 AM   #1107
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Researching that now. Out hp and tq goals are similar. I will let you know what I come up with.
Old 02-16-2009, 09:29 AM   #1108
Blinden
Member#: 122993
WRB 5-door
no more theiren
I was a big Theiren sympathizer, but this was the right move at the right time. The team is just flat. It's like a totally different team then last year.
Blinden is online now
Old 02-16-2009, 09:53 AM   #1109
dmross
Member#: 2818
2000 2.5RS
Originally Posted by glhs377 View Post
DMROSS: i know you'll check this first. i don't have that dowel pin. sorry mate.
Anyone else have an old motor laying around? I'm looking for a little dowel pin that is used to line up the bellhousing and the block. There are two of them, on on the left and one on the right. Otherwise I'm just gonna stop at PepBoys or something and pick one up.
Also, anyone know where I can find a set of fender flares like these?
Trying to turn a little mishap into an opportunity.
dmross is offline
Old 02-16-2009, 10:38 AM   #1110
EdsWRX
Member#: 13881
08 spec b
07 335xi
I have an ACT HD street disc and an oem sti flywheel waiting to go into the lgt. hopefully its enough to hold.
Japan?
Old 02-16-2009, 10:42 AM   #1111
EdsWRX
Member#: 13881
08 spec b
07 335xi
Yeah, it sucks that it was the only move left. Let's see how Bylsma handles the big show today. It will be intesting to see how they will play this afternoon.
Old 02-16-2009, 10:54 AM   #1112
Blinden
Member#: 122993
WRB 5-door
I predict a free wheelin' game. They are basically like school students with a substitute teacher right now. The thing is, this kind of attitude really plays to their talents, so, I would be surprised to see a lot of goals on the board this afternoon.
Old 02-16-2009, 11:54 AM   #1113
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Came up with this. Recommended by Ken and endorsed by Jason.
http://cgi.ebay.com/ebaymotors/ws/eB...m=400001857715
Old 02-16-2009, 12:51 PM   #1114
Mycues1982
Member#: 86995
2005 Tacoma
They are falsely adverstising that because the Pressure plate shown is an Extreme plate and they are selling it as a Heavy Duty plate.. I'm running the Heavy Duty w/ a Street Disc and have been for about 50k miles. I'm looking to try the Extreme plate w/ the Street Disc next.
Mycues1982 is offline
Old 02-16-2009, 01:02 PM   #1115
stealthx32
Member#: 30990
'93 FD3S
Haha, you're probably the only person in the world to have noticed that.
stealthx32 is offline
Old 02-16-2009, 01:08 PM   #1116
Mycues1982
Member#: 86995
2005 Tacoma
Guess I have a good eye haha
Old 02-16-2009, 01:23 PM   #1117
dmross
Member#: 2818
2000 2.5RS
So nobody has an EJ engine lying around? I just need to steal a little dowel pin!
dmross is offline
Old 02-16-2009, 01:32 PM   #1118
stealthx32
Member#: 30990
'93 FD3S
Measure the other one, I'll machine you one.
Old 02-16-2009, 01:43 PM   #1119
Tenacious Bee
Member#: 96452
So, what to play
with next ?
Well I do and I don't . The heads and exhaust mani are mine and the block belongs to ryan. give him a call. The block is close to you.
Old 02-16-2009, 01:45 PM   #1120
Tenacious Bee
Member#: 96452
So, what to play
with next ?
so what clutch is it really ? If it will hold 450 TQ I would still get it.
Old 02-16-2009, 01:48 PM   #1121
Kjott21
Member#: 116937
2011 WRX DGM
forums.pghsubarus.com
All he is saying is that the picture doesn't match the description.
Kjott21 is offline
Old 02-16-2009, 02:20 PM   #1122
stealthx32
Member#: 30990
'93 FD3S
That's not a full ACT kit btw. The disc is F1 Racing, which is some bull**** ebay brand. ACT uses Exedy discs.
Old 02-16-2009, 02:21 PM   #1123
Tenacious Bee
Member#: 96452
So, what to play
with next ?
But the stats do. Thanks for scaring me Mike. I am only half paying attention. Working on some crap for my business.
Doh! Thanks Jimmy.
Old 02-16-2009, 02:27 PM   #1124
dennyt4
Member#: 85581
2005 Forester XT
2008 Corvette
I've had the ACT XTSS w/ street light flywheel...A little heavier pedal than the Exedy twin. It wasn't bad, and at about 1/2 the $ of a twin, it's not bad - I'd probably go with that again if I go single.
dennyt4 is offline
Old 02-16-2009, 02:30 PM   #1125
sk84fun21
Member#: 113300
WRB, LOUD
"Actual item may differ from the picture below."
sk84fun21 is offline
Closed Thread
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 06:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 10:03 AM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 09:08 PM
Pittsburgh - official autocross thread crystalhelix Mid Atlantic Impreza Club -- MAIC 119 05-13-2005 09:22 AM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 07:23 PM
Message Board Statistics All times are GMT -4. The time now is 09:52 AM.
