Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 02-20-2009, 07:57 AM   #1
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
Default HYDRA Installed... FINALLY!
It's finally installed... After 18-19 months with a Hydra Nemesis 2.5 laying around at home in it's box, I finally installed it!
I took my 1999 RS-T to a local tuner (certified Hydra tuner) and left it there for a couple of days. Let me begin by saying that the car I picked up wasn't the same car I left there... It's hard to find words to describe how much of a difference there is. The car feels now like a "stock" car (besides the exhaust note and sick ass power delivery). Nice start up (cold or warmed-up), very nice idle, incredible throttle response, very linear power delivery and no stalling due to flow meter readings (actually it has been eliminated )...
The car is running a bit on the rich side for now @ 20psis... I'm planning to to go to the dyno next week to fine tune it and "lean it out" a bit. In a few weeks I will also install a Garrett GT3076R to see if I hit the 400 WHP with 93 octane...
Mariano is offline   Reply With Quote
Old 02-20-2009, 08:09 AM   #2
MIKE DD
Member#: 106818
2003 Truck
I'll never get tired of looking at an RS, especially one like this. Congrats!!
MIKE DD is offline   Reply With Quote
Old 02-20-2009, 11:55 AM   #3
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Congratulations! I'm glad you're happy after such a long wait.
Element Tuning is offline   Reply With Quote
Old 02-20-2009, 01:17 PM   #4
John Drivesabox
Member#: 81610
2005 Legacy GT
Is that a plug n play harness?
John Drivesabox is offline   Reply With Quote
Old 02-20-2009, 01:18 PM   #5
Mariano
Member#: 56
1999 RS-T (Stage V)
2005 LGT LTD
Yes it is....
Old 02-20-2009, 01:19 PM   #6
WickedRydaX
Member#: 31900
Is that a home built turbo kit?
MCL
WickedRydaX is offline   Reply With Quote
Old 02-20-2009, 02:08 PM   #7
subiidude
Member#: 141472
2008 shagg wgn STI
OG FP20g+e85 corn booze
MCL
looks like the fat kit
subiidude is offline   Reply With Quote
Old 02-20-2009, 04:35 PM   #8
Mariano
Member#: 56
1999 RS-T (Stage V)
2005 LGT LTD
MCL
Yes it is... Only the uppipe and down pipe came from an old JC Sports kit... the rest has been improvised...
Old 02-20-2009, 05:20 PM   #9
freeride
Member#: 49783
2000 2.5rsti&98wagon
SRP/white
Same up and down pipe I am going to use :P
Nice build, whats in the block?
freeride is offline   Reply With Quote
Old 02-21-2009, 02:50 AM   #10
WickedRydaX
Member#: 31900
That is what I thought, that red coolant line looks like mine . I got my hydra/jc turbo'd car running a few weeks back. I need to go to the dyno and fully tune it, but a lot of fun on the street tune so far.
MCL
Old 02-21-2009, 06:43 AM   #11
Mariano
Member#: 56
1999 RS-T (Stage V)
2005 LGT LTD
Here you go:
-Bored RS EJ25 block w/ Darton big bore wet sleeves
-Balanced engine
-Micropolished forged crankshaft
-CP (custom made) oversized forged pistons (9.0:1)
-Crower billet rods
-Cobb coated rod bearings
-Cobb Valve Springs
-Cobb valves titanium retainers
-Bored SOHC Heads(Ported & polished for better flow)
-ARP head studs
-Cometic gaskets (103mm)
-Garrett GT2871R
-Spearco TMIC
-Greddy BOV (Type RS)
-Modded WRX injectors (850 cc)
-STI Tranny mount
-STI Engine mount
-STI Oil pump
-STI Water pump
-ZEROSPORT Thermostat
-Lightened & balanced fywheel
-Walbro 255 fuel pump
-Unorthodox Racing underdrive pulley
-Custom turbo manifold/uppipe/downpipe (3.5")
-Custom 3" piping (catless)
-HKS exhaust/muffler
-SPEC Stage 3 clutch (With custom disc)
-STI Type RA 5sp Gearset (cryo treated)
-K&N RSX Type R Air Filter
-HYDRA NEMESIS 2.5
-Apexi Voltage Regulator
-DENSO Iridium spark plugs for STI
Old 02-28-2009, 04:29 AM   #12
max07sti
Member#: 168522
2007 sti
blue
You're car is sick.. I love it.
max07sti is offline   Reply With Quote
Old 03-02-2009, 09:59 PM   #13
Forester_007
Member#: 87139
2003 Forester XS
JBP
Saludos boricua, el carrito se ve de show felicidades. Esa receta se ve muy bien, yo estoy ahora en el comienzo de hacer la forester mia turbo, nose si usar pistones fabrica y irme low boost, o tirarme con low compression y tirar mas o menos 10-12 libras.
Here you go:
-Balanced engine
-Crower billet rods
-Cobb Valve Springs
-ARP head studs
-Garrett GT2871R
-Spearco TMIC
-STI Tranny mount
-STI Engine mount
-STI Oil pump
-STI Water pump
-HYDRA NEMESIS 2.5
Forester_007 is offline   Reply With Quote
Old 03-10-2009, 11:43 AM   #14
robbie2883
Member#: 151396
+1 i love the rs
robbie2883 is offline   Reply With Quote
Old 05-11-2009, 11:14 AM   #15
dafney02
Member#: 139670
nice setup! Too bad there are no competent Hydra tuners in my area. Do you know if your tuner ever makes trips to the US for group tuning days or anything like that?
dafney02 is offline   Reply With Quote
Old 07-04-2009, 12:59 AM   #16
RSti_Spyder
Member#: 120907
1979 Super Beetle
Convertible STI
Do you have to special order the side feed Spearco TMIC? It looks like that would feed much better than the STi twin rear feed.
Thanks,
Randy
RSti_Spyder is offline   Reply With Quote
Old 07-13-2009, 10:05 AM   #17
Mariano
Member#: 56
1999 RS-T (Stage V)
2005 LGT LTD
Thanks,
Randy
Yes... It was a special order...
Hydra Installation Q 48mpg Other Engine Management 3 01-31-2008 11:43 AM
HYDRA installed!!!! oldbluwrx Other Engine Management 1 09-06-2005 10:42 PM
Need some help with Hydra install... Joey_WRX Other Engine Management 3 07-17-2005 12:54 AM
Hydra installed 1fastsube Car Part Reviews 18 03-08-2005 12:27 AM
Element Tuning Hydra Installed!!! Long CK02WRX Other Engine Management 123 11-16-2004 06:35 PM
