#1 |
Member#: 150300
HIIC
Vehicle:2006 Grocery Getter OBP |
Well, i just bought a bugeye sedan from this guy. He has some kind of top rear diffuser that he attached with double sided tape and some solf silicone stuff. I pulled the diffuser off and was able to take the double sided adhesive off, but the silicone just won't come off! I tried with a heat gun, hair dryer,WD 40, Wax, Alcohol, WTF!! Can someone help me out! Thanks in advance.
#2 |
Member#: 25187
Vehicle:'08 Foz Prem TGM '10 Challenger R/T Blk |
....a thought came to mind.... You may have heard how some use fishing line to remove badges/emblems. How about running a line through the silicone in a slow sawing motion? ....as close to the paint as possible. If you can remove the majority of it and are left with a thin coat, it may be easier to deal with. Personally, I would probably just hit it with my buffer at that point (with a moderate polish) which would likely cut right through the remaining layer. ....vs. expirementing with different solvents.
#3 |
Member#: 150300
HIIC
good idea. i will try that, instead of using different kinds of solvents. thanks.
#4 |
Member#: 135776
Vehicle:2005 WRX WRP10 Silver |
Use wax and grease remover with a clean rag and rub to remove silicone. I used this to remove silkaflex glue
| Thread Tools | |
| Display Modes | |
| Need some advice on silicone removal from paint. | Nivekk | Interior & Exterior Modification | 0 | 07-29-2007 05:14 PM |
| Painting WRX skirts, but now what to do with the rubber gasket thing on the top?? | itachi1314 | Vancouver Impreza Club Forum -- VIC | 8 | 02-15-2007 11:27 PM |
| Removing dry paint on carpet | SupraScooby | Interior & Exterior Modification | 3 | 03-12-2005 07:17 AM |
| How to safely remove the paint dot on the tire? | armand1 | Tire & Wheel | 11 | 05-24-2004 06:31 PM |
| How to remove stain on paint? | pntballfreak | Interior & Exterior Modification | 9 | 05-27-2003 11:29 AM |
