Welcome to the North American Subaru Impreza Owners Club Thursday April 28, 2016
Old 02-28-2009, 08:45 AM   #1
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
Default 2005 WRX S/R30 Dyno Run
Good day. Here's the ride:
2005 WRX Wagon
Power & Engine:
APS S/R 30 Dual Ball Bearing Turbo
APS 3.0" Catless Turbo Back Exhaust
2.5" Catless Up Pipe
Walbro 342 255 lph fuel pump
FSE RRFPR
Ported & Polished Exhaust Manifold and Cross Pipe
Ebay TMIC
Ported Throttle Body, Intercooler
TGV Deletes
Custom Fuel Rail
Silicone Turbo Inlet
Panel Filter
Apex'i AVCR set at 21 psi.
EcuTek Flash Custom Tune from Lightspeed Innovations
Intake Silencer Delete Mod
Grounding Kit and 4 gauge OEM grounding cable replacement kit
SMC Meth Injection Kit
RCI 1 Gallon Fuel Cell
Suspension & Chassis:
Whiteline Anti Lift Kit Comfort Bushing Set
Whiteline Steering Rack Poly Bushings
Energy Front and Rear 20mm Sway Bar Bushings
Front and Rear Perrin Spherical Bushing Endlinks
OEM 20 mm Rear Sway Bar Swap
Perrin Subframe Lockdown Kit
Goodridge Coated SS Brake Lines
Hawk HPS Front and Rear Brake Pads
V8 Jdm STi Front and Rear Lateral Links
Group N Trailing Arm Bushings
Kartboy Front and Rear Poly Shifter bushings
Paranoid Fabrications Fender Braces
1/2" HDPE Saggy Butt Spacers
Perrin 23 mm FSB
Interior:
JL Cleansweep
Alpine SPX-17REF 6.5" Components
JL 300/4/2
JL 10W3 sub and 150w Kicker amp
Dampening on all 4 doors, and the entire hatch
Prosport Premium Boost, Oil Pressure, EGT in Lotek wagon pod
Innovative LC-1 Wideband and G3 Gauge
Stock STi does 210 on that dyno. And yeah, i know that bump is weird. That bump at 5400 was a tune from Dynocomp. Lightspeed didn't want to redo the map so they just played with my fuel and left the map alone. That saved me about $700 btw. The elevation was also about 1000 ft higher at the shop, 600 miles from my home. I make about 3 or 4 more psi here at home. Definitely left some on the table though. This is without the meth injection. The car didn't fair so well on a leak down test, 10 on two cylinders, and the tuner didn't want to push the car. He also thought the emailed tune from Dynocomp was pretty good and didn't think he could squeeze much more timing out.
nicholam is offline   Reply With Quote
Old 03-02-2009, 07:49 PM   #2
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
My next upgrade plan is a STi 6 speed with a built 2.5 hybrid with a goal of 400 whp with as fast a spool as possible.
Old 03-03-2009, 06:19 PM   #3
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
super sleeper...dont touch anything on the outside
BuggeyEYED is offline   Reply With Quote
Old 03-04-2009, 04:03 PM   #4
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
That's the game plan. Nice and legal looking.
Old 03-04-2009, 06:13 PM   #5
4ST-AIR
Member#: 148681
TBD Looking for STI
Back in the Game!
Is that Knock at 5100?
4ST-AIR is offline   Reply With Quote
Old 03-04-2009, 08:04 PM   #6
nicholam
Member#: 133936
2005 WRX Wagon
Stage 4 Silver
No it's something else like more advanced timing. The ecu didn't pull any timing through any of the many dyno pulls we did that day. Running 94 octane fuel.
FS : NV: 2005 Wrx Flat Lambo White! 6 Speed! exdakine Private Vehicle 'For Sale' Classifieds 90 09-29-2011 01:26 PM
Non-WRX Dyno Runs Soon2BturbodRS Proven Power Bragging 21 10-06-2003 09:44 PM
Anyone with a STOCK WRX want a free dyno run? willysaki South West Impreza Club Forum -- SWIC 1 05-30-2003 09:44 PM
Import Tuner WRX Dyno Runs sherifx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 11-17-2001 04:55 AM
Dyno Runs.. AWD car on a 2WD dyno... WTF Mike Moffa Technical Forum Archive 7 07-18-2000 08:31 PM
