Welcome to the North American Subaru Impreza Owners Club Saturday December 3, 2016
Old 03-08-2009, 11:46 PM   #1
simonbsays
Member#: 158241
2006 CGM WRX Wagon
XPT Stage II
Default DIY: Shifter/Center Console Accent Light
First of all, credit for this mod idea goes to Admission_Regret (see his thread here)
This is a pretty simple mod that adds an LED in the overhead sun visor area, shining down to illuminate the center cons0le and shifter area with a soft glow. It’s a really nice touch.
I did this to my 06 WRX wag0n and chose blue. I took a bunch of pics during the process and since nobody has come up w/ a how-to guide yet, I thought I’d post this up.
Parts list:
  • OEM Visor P/N: 92011FE132NE ($14 + s/h from SGP)
    • Sun visor didn’t come stock on MY06
  • Blue LED 3mm/4v/20mA/30░/2000mcd ($0.67 + s/h from superbrightleds.com)
  • Resistors ($0.99/5pk from Radioshack)
    • 1x 10K Ohm
    • 1x 4.7K ohm
    • http://led.linear1.org/led.wiz <-- use this site to determine the resistor size u need!
  • Heat-shrink tubing or electrical tape
  • Wire-taps (~$1.99 from Radioshack)
  • Short length of wire (<1ft.)
  • Hot glue
Tools:
  • Soldering arms + solder gun + solder
  • Wire cutters
  • Power dri11
    • Bits: 5/16”, and 7/64”
  • Hot glue gun
  • Nylon panel tool OR flat head
  • Philips head screw driver
Step 1 - Creating the LED circuit:
I decided to go with a single blue LED for my setup - the 3mm blue one from superbrightleds.com. Looking at the specs, this lamp puts out 2000mcd @ 4v, which is way too bright for this application. So I added 2 resistors – 10K Ohm+5K Ohm:
My circuit goes something like this:
[+] ----/\/10K resistor\/\---/\/5K resistor\/\----[3mm LED]-----[-]
After the soldering, I used heat-shrink tubing to cover it all up (as seen in a few pics down).
Step 2 - Getting to the wires:
Remove the maplights by popping off the lens (use nylon tool or taped up flat-head to prevent scratches). There are 2 philips screws holding the map light assembly. Unscrew those and it will drop down.
Pop out this tab (flat head should work if you don’t have a nylon panel tool), and unscrew the visor clips to drop the headliner slightly:
(note, MY06 already have the metal bracket required for mounting the sun-visor. Someone mentioned that previous MY’s may not)
Step 2: Tapping power from the auto-dimming mirror harness:
There are many ways you can tap power for this, and I chose the easiest way. By tapping the auto-dimming mirror’s power, the LED will come on when you turn on the car. I was too lazy to tap it to something that came on with the headlights (likely more preferable)…
The wire harness for the auto-dimming mirror goes something like this:
[+]-------[yellow/black wire]---{
[-]--------[black wire]-----------{ you want to tap this one
[+]-------[yellow/red wire]-----{ and this one
Also, I had previously tapped this harness for another mod: hard-wired GPS. I used molex connectors in hopes for a modular setup, so for this mod, I plugged into my existing setup:
Once power’s tapped and LED circuit is created, TEST to make sure it works (and brightness expectations are met)
Step 3 - Prepare the sun-visor bracket:
MY06+ doesn’t come with a sun visor, so I ordered one from SGP. Since I don’t need the actual visor part (looks like it’d only interfere w/ this mod), I removed the visor flap. Just pull it off its hinge.
You’ll want to clear the area where you’ll be drilling the hole for the LED. I used wire cutters to cut away the plastic:
Drill the hole. Use a 7/64” bit, which made for a very snug fit for the 3mm LED.
Step 5 - Drilling the headliner:
The back of the sun-visor bracket has a little nub sticking out (as seen in above picture). You’ll need to drill a hole for it in the headliner. I used a 5/16” bit.
Next, I used the same bit to drill a hole for the LED wires to go through:
Last edited by simonbsays; 02-08-2010 at 04:27 PM. Reason: removed annoying vibrant links
simonbsays is offline   Reply With Quote
Old 03-08-2009, 11:46 PM   #2
simonbsays
Member#: 158241
2006 CGM WRX Wagon
XPT Stage II
Step 6 - Installing and aiming the LED:
For testing the LED’s aim, I temporarily installed the bracket to the headliner and plugged it in. Once I found the angle I wanted, I hot glued around the LED.
Step 7 - Put it all back together:
At first, I thought it was a little too bright... but it was because i was testing in complete darkness. In reality, street lights will spill in, and the brightness is perfect
Old 03-09-2009, 12:28 AM   #3
Mechie3
Member#: 120152
Now change the cluster to blue
Nice write up.
Old 03-09-2009, 01:48 AM   #4
bcWRX-02
Member#: 181780
2002 WRX Sedan PSM
'01 CBR 600 F4i
In regards to previous MY's not having the bracket for that sun visor, MY02 came with the visor already installed, so this should work no problem on '02-'03s. Nice job, looks really good.
bcWRX-02 is offline   Reply With Quote
Old 03-09-2009, 02:19 AM   #5
DC16A2
Member#: 174357
2002 OBS
Looks nice. I drove a Toyota Highlander rental last month.. had the exact same thing.
DC16A2 is offline   Reply With Quote
Old 03-09-2009, 02:54 AM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Nice work
hybrid gti 2 is offline   Reply With Quote
Old 03-09-2009, 11:14 AM   #7
gero704
Member#: 156883
15 Outback CWP
07 WRX WRB (sold)
excellent work! where did you get the plugs for the led and the car to hook the two up? good job!
gero704 is offline   Reply With Quote
Old 03-09-2009, 12:18 PM   #8
maxbr
Member#: 185759
2004 WRX Stg II
Java Black Pearl
Thank you for this.
maxbr is offline   Reply With Quote
Old 03-10-2009, 01:46 AM   #9
kimgt
Member#: 142097
2002 celica GT
red
great write up, if i post LED specs for a different bulb is there a formula i can use to find the proper resistors like you did? thanks in advanced.
kimgt is offline   Reply With Quote
Old 03-10-2009, 02:06 AM   #10
simonbsays
Member#: 158241
2006 CGM WRX Wagon
XPT Stage II
Nice write up.
hah, i just read one of your posts where u said "blue's a no go because it always comes out teal" or somehing... i don't mind the green too much, but wish the gauge cluster was brighter.
those are plugs from computer parts actually... i think they were from some CPU fan i bought a while back... it might be easier to connect directly to the power wires unless you have spare plugs laying around also.
hmm... there are a few "led wizards" out there like this one: http://led.linear1.org/led.wiz but they only give you the resistor sizes for max output per your LED's specs... i really don't know much about electronics so I just kept on adding resistors until it was dim enough Ended up with my 15K Ohm.
Old 03-10-2009, 03:19 PM   #11
AlxSti
Member#: 94615
|'06 STi 341/356|
Delaware REALTOR«
cool man.. nice write up! i wish i had the mini visor in my 06 already.. my 04 came with one (but i also didnt have the auto dimming mirror then either).
AlxSti is offline   Reply With Quote
Old 03-10-2009, 11:33 PM   #12
dc2skel
Member#: 136246
07 WRX 39 swap
555 motorsports tuned
nice write up. What nav unit is that? I like your screen on it. I just picked up a garmin nuvi 205 and am looking at doing some sort of splash screen like that.
dc2skel is offline   Reply With Quote
Old 03-11-2009, 12:11 AM   #13
simonbsays
Member#: 158241
2006 CGM WRX Wagon
XPT Stage II
Thanks for all the comments guys
That's one of garmin's older units... the 350. Check out one of my other threads for splash screens
http://forums.nasioc.com/forums/show....php?t=1472134
Old 03-11-2009, 01:19 PM   #14
NihonLifeStyle
Member#: 204935
2006 WRX Wagon Limit
Awsome
NihonLifeStyle is offline   Reply With Quote
Old 03-12-2009, 04:07 PM   #15
Y_I_K_E_S
Member#: 159449
2005 WRX STi
"Ali"
Can someone please tell me what size the bolt is for the visor bracket? I am just going to paint a little piece of flat plastic and use that to mount the LEDs rather that dropping $15.
Y_I_K_E_S is offline   Reply With Quote
Old 03-12-2009, 04:25 PM   #16
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
nice work. my dad's 02 town and country limited an had this, and i fell in love with it.
i ill be doing your version of the mod this spring!
jdubya301 is offline   Reply With Quote
Old 03-26-2009, 12:55 PM   #17
hoffmanEstates
Member#: 122043
04 wagonier
psm
chevy HHR have that its clear/white leds
hoffmanEstates is offline   Reply With Quote
Old 03-30-2009, 02:33 AM   #18
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
nice write up... not sure which color is best for 02 WRX
txl146 is offline   Reply With Quote
Old 03-30-2009, 03:52 AM   #19
Badmunky
Member#: 143391
2007 WRX TR
R.I.P Paul! :(
Nice writeup man. I may do this to mine!
Badmunky is offline   Reply With Quote
Old 03-30-2009, 05:36 PM   #20
DieselClown
Member#: 36135
2005 WRX
looks good man.
DieselClown is offline   Reply With Quote
Old 04-07-2009, 08:05 PM   #21
madmaxwrx
Member#: 194088
2006 Impreza WRX STI
black
awesome mod i just did it thanks for the write up
madmaxwrx is offline   Reply With Quote
Old 04-08-2009, 04:17 PM   #22
Evilchargerfan
Member#: 183529
i wanna help teh
haters ... love life ...
WOW!!!
im doing this soon!
Evilchargerfan is offline   Reply With Quote
Old 04-08-2009, 04:37 PM   #23
island boyeee
Member#: 171758
2006 WRX Ltd Stg m@!
Blk&Grn / 08 Daytona 675
one of the million things on my to-do list. however, as an option to have it switched, i was thinking about wiring both the map lights to one of the buttons, and then using the other for the shifter light. just my 2 cents
island boyeee is offline   Reply With Quote
Old 10-15-2009, 11:20 AM   #24
uhmmmitsmik3
Member#: 217628
2008 Subaru WRX hb
SICK.. thats pretty damn awesome. i might have to try this on my 08
uhmmmitsmik3 is offline   Reply With Quote
Old 10-15-2009, 12:21 PM   #25
exrage
Member#: 77366
2014 WRX Hatch
I wired mine right into the clock harness. the illumination and ground are the middle two wires on the plug
exrage is offline   Reply With Quote
help in taping into center console cig lighter RS 1986 Car Audio, Video & Security 8 06-04-2010 03:19 PM
center console wont light up gerrardallam Newbies & FAQs 7 01-12-2010 03:58 PM
Help Finding Thread on Auxiliary Interior Shifter LED Accent Light Nairb336 Interior & Exterior Modification 3 08-31-2009 03:46 PM
FS: IL- ILP short shifter 5 speed assembly, center console, shift knob, shifter boot wrxss Drivetrain 12 04-11-2007 06:35 PM
FS in PA: 2004 STi center console- COMPLETE w/ STi Ebrake and STi shifter trim phlegmon Private 'For Sale' Classifieds 8 05-14-2006 05:09 PM
