Welcome to the North American Subaru Impreza Owners Club Wednesday July 9, 2014
Old 03-09-2009, 01:45 AM   #1
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
Default DIY splash guard/skid plate?
So I was thinking of making a DIY splash guard/skid plate, anyone done this, is there a template for it?
OUScooby is offline   Reply With Quote
Old 03-09-2009, 02:06 AM   #2
Serkan
Member#: 180514
2004 Sti White
Yea, i was thinking of doing the skid plate myself. It can't be too hard if you have some metal work skills (cutting, bending, welding)
Serkan is online now   Reply With Quote
Old 03-09-2009, 02:28 AM   #3
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
I don't even think welding would be involved, just cutting and bending. I was thinking something like this: http://azpinstalls.com/rallyarmor/
seems pretty simply to make.
Also thinking of making a radiator cover, probably a little more cutting and bending involved in that one. Anyone got a template for that too?
Old 03-09-2009, 02:33 AM   #4
Neuter
Member#: 155829
2004 Wrx
wrb
If you do this, could you post the dimensions and your method
Neuter is offline   Reply With Quote
Old 03-09-2009, 02:44 AM   #5
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
I was hoping to find a template on here. But if I don't, and try and make it from scratch, sure I'll step by step pics and dimensions.
Old 03-09-2009, 03:15 AM   #6
Neuter
Member#: 155829
2004 Wrx
wrb
I did a little searching a while ago and came up with nothing, and then winter came so I got to lazy to go mock it up...
Old 03-09-2009, 09:11 AM   #7
ZOMG.STi
Member#: 191857
RIP Matthew Denice
2003 Honda s2000
subscribed!
I don't have any dimensions but I'd rather make one for cheaper than buying one.
ZOMG.STi is offline   Reply With Quote
Old 03-09-2009, 12:37 PM   #8
MConte05
Member#: 158579
2005 Lotus Elise SC
94 Legacy Rally Car
Pretty simple to figure out the dimensions yourself. Take a piece of cardboard, go lay it up, mark out where you want to cut it, and voila. Template.
MConte05 is offline   Reply With Quote
Old 03-09-2009, 01:08 PM   #9
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
That was my plan. I was going to take my factory splash guard which is sitting in my garage, and use it to outline something in card board, then mock it up under the car, and see how many bends I'll need to make.
Old 03-09-2009, 06:40 PM   #10
thusimos
Member#: 83429
04 WRX Wagon
I made one a few weeks ago. I used two street signs for material and some square stock to space it down from the subframe. Bolts to the five factory bolt holes used by the stock splash guard. The wings are unsupported, but I'm not sure how to change that. Only a little bit of the center section is visible from the front, everything else is nicely hidden.
The notch is to clear one of my fmic pipes. I may end up notching the other side too. You can't tell from the pics, but the leading edge is bent up at and angle to minimize damage if I ever hit something.
I don't know how much of a hit it could actually take since I didn't reinforce it anywhere. The first tank of gas with it is showing +1 mpg and it now coasts much farther than it did with the stock splash guard.
Anyone can build one. It's just a flat plate with some holes drilled in it. One thing to watch out for is when you drill the front three holes. They are not symmetrical. I actually wanted the shiny side of the signs on top.
thusimos is online now   Reply With Quote
Old 03-09-2009, 07:07 PM   #11
Newbuggy
Member#: 152042
I was thinking about using some old signs for a skid guards. interesting.....
Newbuggy is offline   Reply With Quote
Old 03-09-2009, 07:29 PM   #12
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
haha the street sign splash guard is hilarious
+1 for creativity though
evan_impreza is offline   Reply With Quote
Old 03-09-2009, 07:31 PM   #13
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
^looks good, got some dimensions so I can get an idea of what size piece of sheet metal to buy? I may make it out of one piece, or I may make it in three pieces, on for the middle about the size of the factory splash guard, and two other pieces for the sides.
Old 03-09-2009, 08:51 PM   #14
Himynameisgreg
Member#: 200420
'08 DGM 2.5i Sedan
'05 AW STI Track Car
you totally should have left the actual sign picture an pointed it down. so when you took those pictures it said "stop" or RR Crossing
Himynameisgreg is offline   Reply With Quote
Old 03-10-2009, 12:31 PM   #15
thusimos
Member#: 83429
04 WRX Wagon
The signs were right turn only, a little bigger than 3 feet by 2 feet. It's unfortunate that slow children signs are too small for this stuff. I really wanted a freeway sign so it could all be one piece, but the junk yard didn't have any. It turned out quite a bit heavier than I though it would be due to the extra metal from the wings overlap. It came to about15lbs. Stop signs aren't quite the right shape unless you can find the really big ones.
TMIC users will have more attachment locations to chose from. There are three across the bottom of the bumper I can't use because the intercooler is in the way.
My biggest fear has become dropping stuff in the engine bay.
Old 03-10-2009, 03:24 PM   #16
habitatxskate
Member#: 197537
06 WRX
matte black
awesome, i have to do this! i ahve a stop sign and some other signs floating around somewhere around my house.. sweeet
habitatxskate is offline   Reply With Quote
Old 03-11-2009, 01:36 AM   #17
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
OK, so I'm going to start this project and document each step. This is my first attempt at anything like this so I'm going to post each step as I do them rather than all at once, once I'm done. That way people can add suggestions or point out anything that I f**ked up.
First I'm going to make a template out of cardboard and then get a piece of sheet metal to make the real thing. I'm thinking aluminum to save weight, but may do stainless depending on pricing. I'll go to a metal supplier later to get prices on materials.
Got started today. Took my factory splash guard and then traced the outline on a piece of cardboard. Also make sure to mark the holes for the bolts.
I then outlined a simple rectangle around the outline of the splash guard. I figured it would be easiest to keep it as square are possible to minimize the number of cuts I'll have to make.
Cut out the cardboard. And tomorrow I'll mock it up under the car, and see where I need to trim, bend etc.
I know not much for a first step but stay tuned.
Old 03-11-2009, 01:50 AM   #18
NorthBayResident
Member#: 204200
2008 Impreza 2.5i
Interested to see how this turns out, i was thinking about doing the same thing on my car.
Maybe you can use the RalliTEK Skidplate as a guiding point
http://www.rallitek.com/alskle.html
NorthBayResident is offline   Reply With Quote
Old 03-11-2009, 03:04 AM   #19
skate enjoi
Member#: 120716
2002 psm ver7 wrx
reversed and rotated
I wish I had a stock skid plate
skate enjoi is offline   Reply With Quote
Old 03-11-2009, 04:08 AM   #20
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
Well when I'm done with this, maybe I'll sell you mine.
Old 03-11-2009, 04:43 AM   #21
skate enjoi
Member#: 120716
2002 psm ver7 wrx
Ill give you 3 dollars shipped... hell, trace it on a piece of carboard and send that bitch over here... Ill give you a few dollars maybe
Old 03-11-2009, 05:27 AM   #22
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
Don't worry as soon as I dial in a final template, I'll post it up here with measurements. You'll be able to make your own.
Old 03-11-2009, 05:28 AM   #23
skate enjoi
Member#: 120716
2002 psm ver7 wrx
what will really suck though is getting the holes lined up
Old 03-11-2009, 10:43 AM   #24
ADAS1223
Member#: 159853
2005 pew pew
pew pew pew pew
If you could post dimensions, and meticulously explain the points for the holes (distance from each other/edges) please <taco rey wtf?
ADAS1223 is offline   Reply With Quote
Old 03-11-2009, 12:15 PM   #25
NihonLifeStyle
Member#: 204935
2006 WRX Wagon Limit
Interesting.....
NihonLifeStyle is offline   Reply With Quote
FS: 02-07 impreza aluminum mini skid plate/splash guard ten80 Exterior/Styling 3 12-15-2008 10:26 AM
Brush Guard, skid plates, fender liners, and front end aero. Chi_San Interior & Exterior Modification 0 11-20-2007 10:28 PM
WTB: for GC8 L Coupe, clear lights, jdm tails, short shifter, diff guard, skid plates compleckz Private 'Wanted' Classifieds 1 04-20-2007 10:07 AM
FS/T: Stock splash guard (skid plate thing) Stover954rr Private 'For Sale' Classifieds 9 12-07-2005 12:08 PM
Need a skid plate (the stock splash guard isnt very tough!) yellowblaze Baja Forum 3 08-14-2005 08:55 PM
