#1 | |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
I made this thread because this thread is to discuss my dyno number and the other one is to discuss my track numbers.
![]() Same mods on both runs, same test track .Power mods and supporting mods are: VF39 and Sti TMIC gimmick turbo inlet TGV deletes by me Buschur Racing TBE 3" catless (ceramic coated completely) Perrin EL and uppipe (ceramic coated) APS 65mm CAI Hallman MBC APS dual vent BOV 3mm phenolic spacer 860cc modded injector Walbro FP now I understand that numbers are just numbers this car run a best of \/ at 22.7 psi Quote:
![]() TY
#2 |
Member#: 64908
Vehicle:10.8 XT+ Real stock turbo record holder 11.4 |
That is a low reading dyno
#3 |
Member#: 139385
Phatron and I both cleared 400 on that airboy dyno, think about how that feels
#4 |
Member#: 108091
Vehicle:2002 WRX |
good stuff juan!!!
#5 |
Member#: 122980
South East
Vehicle:2010 F150, 2013 CX-5 92 Miata 15 TTF/PTF/E3 |
#6 |
Member#: 133146
#7 |
Member#: 122980
South East
Ill give you the benefit of the doubt and wait to see logs. Then, well...
#8 | |
Member#: 133146
or have fun in this thread \/ http://forums.nasioc.com/forums/show....php?t=1719031 ![]() ![]() |
#9 | |
Member#: 122980
South East
![]() Bring it to me, it will run 11's. ![]() Edit: Where in SC are you? G'ville/Spartanburg? I would say take a night when they are having a Test N Tune at Rockingham and go there, but if youre in G'ville or Spartanburg, thats a pretty good haul. |
#10 | |
Member#: 133146
I know redneck land , I am going to go to Atlanta dragway in GA on the 27th. I hope I can do it .I am in greenville. |
#11 |
Member#: 122980
South East
Yeah, ATL is a good bit closer than Rockingham.
Ill PM you with some advice later. ![]() |
#12 |
Member#: 64908
The rock FTW
Pretty quick track |
#13 |
Member#: 33082
South East
Vehicle:EWG 'dGTX3071 with NO BRAIN |
who drove where? Juan to junior or junior to juan?
#14 |
Member#: 114631
Vehicle:2007 11.5 @ 118 Stock Turbo Record Holder |
#15 | |
Member#: 152867
South East
Vehicle:2007 WRX TR w/ VF39 White, Opensource stg3? |
Also, I think whatever log you ran, you didnt use a good one. I used that same software and made more power than you with a TD04. Were you going up hill or something? And I definately couldnt run that fast of an 1/8th (nice time btw) |
#16 |
Member#: 64908
Same reason why number are just number.. because 1 or 2 missed calculations will equal high or low numbers.
#17 |
Member#: 54060
Vehicle:205 + td04=12.4@109 V8 207+VF37=12.3@111 |
You made 286+ on a TD04?
#18 | ||
Member#: 133146
![]() Quote:
in net 291whp and 325wtq. I am pretty sure all my variables such as weight, tire size, elevation, humidity, temp etc are correct! My testing track is a little up hill but not much, 1 or 2 degrees incline max.I agree |
#19 |
Member#: 156973
International
Vehicle:2002 ADM WRX STi STi Black/Blue |
Even airboys spreadsheet can give highly inaccurate results if numbers entered are incorrect
![]() EDIT: however, if ppl posted a 4th gear WOT log (time and engine speed is all that is required, but engine load, afr and itt would also be beneficial), the exact model car they had, the sized tyres/wheels they had, and the total weight of the car with them in it, it would be a great way to compare ppls cars and tunes ![]() |
#20 |
Member#: 148372
South East
Vehicle:02 WRX, FD, S2K Hybrid,07 6spd, BW Roated |
#21 |
Member#: 194599
Vehicle:2005 Legacy GT OBP |
Looks good.
#22 |
Member#: 56345
Vehicle:93 Swapped L Green |
#23 |
Member#: 151126
Vehicle:2003 WRX Sonic Yellow |
that dyno sheet doesnt make any sense its wrong, thats not the right horsepower level
#24 |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
Just remember that road dyno software must be used properly. Using a road that isn't completely flat, using the wrong gearing, tire size, weight, or aero data will greatly throw off the readings. Also remember you can't use a log that was done on a chassis dyno and expect accurate results from the road dyno software.
-- Ed |
| Thread Tools | |
| Display Modes | |
| Siegal Tuned: 05 STi, VF39 on E85 - 293 HP, 386 TQ on Dyno Dynamics! | NaiveRapture | Proven Power Bragging | 14 | 05-23-2010 11:28 AM |
| 2.5L VF39 Road dyno lots of HP/TQ | medamullet | Proven Power Bragging | 51 | 11-19-2009 04:41 PM |
| 2.5L VF39 E85 CAMs and Ported heads VS 2.5L VF39 E85 | juanmedina | Proven Power Bragging | 156 | 09-05-2009 04:27 AM |
| 2.5 VF39 Dyno sheets/before meth/after | mapleleaf | Proven Power Bragging | 12 | 04-26-2007 09:40 AM |
| Dyno Sheet Request: 06 WRX vs 06 WRX Cobb Stage 1 | karnick | Proven Power Bragging | 7 | 01-03-2007 05:15 PM |
