Old 03-17-2009, 11:23 AM   #1
ejswimmer45
Member#: 202278
Post Nu finish car polish
Has anyone used nu finish car polish or scratch remover on their subaru? like all of you i have watched the finish on my car get destroyed, and I want something that can fill in some of the swirl marks, and bring out the shine a little bit. my car is only a lease, so i dont want to take the time to buff the whole car and then wax. I am looking for a one step product that will bring back the finish as much as possible. any suggestions???????????
ejswimmer45 is offline   Reply With Quote
Old 03-17-2009, 11:54 AM   #2
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....well, not all of us have let our cars get that way (90k miles on a 6 1/2 yr old black car):
I would suggest reading through the articles found in the following link:
http://www.autopia.org/publish/categ...-and-Car-Care/
Those write-ups will answer most (if not all) of your questions. If you want a real fix to your problem, fillers are not the answer. Once corrected, it will take some effort and diligence on your end to maintain the finish from that point on. ....a change in wash habits, tools, products, etc.
Btw, you may also want to consider enlisting the services of a professional detailer. Once the initial hard work is done, all you have to worry about is properly maintaining it.
Old 03-17-2009, 11:55 AM   #3
rotorhead
Member#: 35187
2003 impreza wrx
you might want to do a search here on nufinish as it's been discussed a few times before, but the short version is nufinish is a decent, cheap, quick, & easy polish. there are better polishes out there, and there are worse, but for the $$$, it's good enough for me.
rotorhead is offline   Reply With Quote
Old 03-17-2009, 12:26 PM   #4
brian1g
Member#: 84123
2005 wrx
cgm
i think meguairs nxt tech wax is going to be hard to beat if you want a 1 step wax/cleaner that has some swirl hiding properties. best of all it is cheap and a lot of places sell it.
it isnt going to remove any swirls or correct flaws in the paint but it will clean and wax in 1 step. it does also seem to "hide" swirls a little better than most waxes and sealants i have used. keep in mind that if you have a dark colored car waxing can amplify the amount of swirls you see just because more light is reflected off of the paint.
nxt wax is hard to beat for an all in one product.
i personally would look at hiring a detailer to buff out the swirls and wax/seal the car. your results will be better (hopefully) than a 1 step product and it may actually be cheaper than buying all the products needed to do a detail yourself.
brian1g is offline   Reply With Quote
Old 03-17-2009, 05:35 PM   #5
DPGX
Member#: 111184
Love this stuff as well when Im in a hurry and I want my car to look nice.
DPGX is offline   Reply With Quote
Old 03-18-2009, 10:05 AM   #6
djosbun
Member#: 202176
2004 WRX wgn P1RANHA
'07 Tribeca
+2 on the NXT wax. It's more expensive than regular wax products, but it's easy to find (WalMart sells it), easy to apply and remove, practically no dust during removal, and gives a great shine.
djosbun is offline   Reply With Quote
Old 03-18-2009, 10:48 AM   #7
ctrent86
Member#: 129199
2004 WRX
PSM Stage 2
I would say it depends on the condition of the car you are working on. NXT scratch hiding abilities are not that great. I would say for the same work that goes into applying NXT doing the detail I just did washings aside is just as much labor.
Link Here
links to products are in that thread
The only product I have to "apply" was prime strong which is a much better paint cleaner and swirl/scratch fixer than NXT. Also, mixed in is a light wax booster and sealant. Sure the price point is higher but why not spend a little more for a much better product with loads more of durability. Once you apply the primestrong, just spray some Opti-seal on there or Acrylic Jett Trigger wipe off, and then spray a coat of Duragloss Aquawax and wipe off.
This combo would last at least 3-5x times longer than NXT and shine would have a lot more depth.
Some might argue product are more expensive. Well lets take Opti-seal, at 25 dollars a dime size application will do one or two panels. So in one bottle you get about 20-40 car applications. When you break it down like that it is a bargain buy. Also, Optiseal is a wipe on walk away product and Aquawax being a spray on wipe off product.
Plus, I don't understand the available everywhere issue. Just order on Monday and you will have it for the weekend to clean up your car.
I didn't mean for this to come off harsh or anything. I just want people to know of other options that are better.
ctrent86 is offline   Reply With Quote
Old 03-18-2009, 11:16 AM   #8
Kean
Member#: 25187
'08 Foz Prem TGM
Originally Posted by ctrent86 View Post
Also, both Optiseal and Aquawax are products that are essentially wipe on wipe off.
....Optiseal is a "wipe on & walk away" product (no wiping or buffing is necessary if applied properly).
Old 03-18-2009, 02:16 PM   #9
ctrent86
Member#: 129199
2004 WRX
PSM Stage 2
You are correct I was being a little lazy. Corrected above
Old 03-18-2009, 03:36 PM   #10
neat-0-wrx
Member#: 175975
this is what i am going to do... i dont think i could polish everything out, but i can keep wax on and wash properly
neat-0-wrx is offline   Reply With Quote
Old 03-18-2009, 03:46 PM   #11
Kean
Member#: 25187
'08 Foz Prem TGM
....check around the regional forum. There may be fellow locals who can give you recommendations on a good detailer in your area. .....they may be members themselves and/or give discounts. Also, I know in my area I sometimes see detailers, PDR techs, etc. offereng discounted services to members at special meets. .....just throwing it out there. Hope this helps.
Nu Finish radekkacz07 Car Care & Detailing 25 01-23-2009 06:26 PM
WTT/FS:Rays gram lights 57 pros.18x7.5 5x100 et+48 Gold Finish with polished lip blu_sti Wheels/Tires 17 10-03-2007 11:24 PM
Question about Nu Finish polish Rex87 Car Care & Detailing 6 04-28-2006 09:44 AM
Finish First Polish cnk Interior & Exterior Modification 0 10-22-2002 10:46 AM
Nu Finish MagicMT Car Care & Detailing 13 05-22-2001 08:26 AM
Message Board Statistics All times are GMT -4. The time now is 03:44 PM.
