Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 03-12-2009, 11:59 PM   #26
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
So I mocked up the cardboard template under the car and here is the updated shape. I trimmed the template down a little on both front and back, and added a hole for access to oil filter and drain plug. The black dotted line is where I will bend up the metal approximately 6 degrees. It's not in the template but it is illustrated by the red line, I'm going to add a little edge that will be bent up vertically. Two pics here from both sides so you can see the new shape relative to the outline of the original splash guard.
OUScooby is offline   Reply With Quote
Old 03-13-2009, 12:04 AM   #27
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
Originally Posted by ADAS1223 View Post
If you could post dimensions, and meticulously explain the points for the holes (distance from each other/edges) please <taco rey wtf?
OK here is the measurement between the hole on the splash guard.
NOTE, it may not seem so because of the slight angle the photo was taken at, and because the splash guards is not laying perfectly flat, but all lines drawn intersect at right angles. The hole I plan to use for my skid plate are the ones circled in yellow.
Next step: make a final template with bends, make sure hole for oil filter and drain plug leave enough work room, and price out sheet metal.
Stay tuned.
Comments, criticism, and suggestions highly encouraged.
Old 03-13-2009, 12:04 AM   #28
ADAS1223
Member#: 159853
2005 Impreza
wrb
can you post dimensions man. looks good!
Edit: NVM, YOUR AWESOME!! hahahaha
ADAS1223 is offline   Reply With Quote
Old 03-13-2009, 12:36 AM   #29
skate enjoi
Member#: 120716
2002 psm ver7 wrx
reversed and rotated
Ill try this out possibly now
skate enjoi is offline   Reply With Quote
Old 03-13-2009, 12:41 AM   #30
NorthBayResident
Member#: 204200
2008 Impreza 2.5i
If I end up doing this for mine ill post dimensions for all of us 08/09 guys (for the 2.5i atleast, Im pretty sure the STI and WRX underbelly is different )
NorthBayResident is offline   Reply With Quote
Old 03-13-2009, 02:10 AM   #31
brokenfingerdesigns
Member#: 180914
2004 wrx
555 motorsports tuned wrb
I would recommend some kind of luvers to evacuate hot air .
brokenfingerdesigns is offline   Reply With Quote
Old 03-13-2009, 02:29 AM   #32
skate enjoi
Member#: 120716
2002 psm ver7 wrx
hot air rises
Old 03-13-2009, 01:07 PM   #33
ADAS1223
Member#: 159853
2005 Impreza
wrb
if its cut/bent correctly, the wind current underneath should suction out the hot air
Old 03-13-2009, 01:16 PM   #34
Tbagger
Member#: 122680
2006 STi Rally Car
i have a "homemade" plate ....
Tbagger is offline   Reply With Quote
Old 03-15-2009, 09:55 PM   #35
05wrx09
Member#: 204111
2005 WRX
I love it! I'm going to Home Depot tomorrow to try this out! What did you use to cut the metal? I'm going to just use some tin-snips I guess. Also, I'm going to cut a few slits in this thing to vent it...because some people told me if you replace the stock plastic splash guard, it'll get too hot? Weird. Any problems with this?
05wrx09 is offline   Reply With Quote
Old 03-16-2009, 12:32 AM   #36
fastwrx25
Member#: 126441
03 bugeye
great post!! please post up the pricing you got for alu and steel!
I'm going to do this too.
Old 03-16-2009, 12:57 AM   #37
ZOMG.STi
Member#: 191857
RIP Matthew Denice
'05 2.5RS / '03 S2K
wow, thanks for the dimensions!
A DO NOT ENTER road sign just showed up on my porch... idk how it got there..... but now I know what I'm gunna do with it! Sign side down of course.
ZOMG.STi is offline   Reply With Quote
Old 03-16-2009, 01:00 AM   #38
KillerRabbit
Member#: 184772
2004 Crazy Slow WRX
I totally was thinking about this. But i might buy one, depends on my job. Looks great so far!
KillerRabbit is offline   Reply With Quote
Old 03-16-2009, 12:40 PM   #39
thusimos
Member#: 83429
04 WRX Wagon
I haven't had an cooling trouble, but it's only 50 degrees outside. Hot air probably follows the firewall down to the transmission tunnel for it's exit which is still completely open.
I cut my signs with a jigsaw, they were too thick to cut easily with tin snips.
thusimos is offline   Reply With Quote
Old 03-16-2009, 01:57 PM   #40
charris90
Member#: 165003
2004 FXT
Satin Black
I have a custom skid plate to protect the header on my forester xt, and i have not had any cooling problems temp outside is 75+. I think the front gap below the grill is allowing cool air to flow through the radiator and down underneath the car.
charris90 is offline   Reply With Quote
Old 03-21-2009, 11:36 PM   #41
ZOMG.STi
Member#: 191857
RIP Matthew Denice
'05 2.5RS / '03 S2K
bump bump!
any update? final design?
Old 03-22-2009, 12:18 AM   #42
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
Originally Posted by ZOMG.STi View Post
bump bump!
Sorry everyone for the lack of updates. The project took a new direction when I attempted to see if I could incorporate brake cooling ducts into the design. I was trying to vent air to the brakes from the underside of the car. No luck with that idea, and I'll be going back to the original idea, and picking it up again soon. I'll keep you updated.
Old 03-23-2009, 01:23 AM   #43
truckie453
Member#: 199767
2009 Impreza
Dark Metallic Gray
Did you ever end up making a plate for your 2.5i? If you did can you post dims?
truckie453 is offline   Reply With Quote
Old 03-23-2009, 07:42 AM   #44
ADAS1223
Member#: 159853
2005 Impreza
wrb
homedepot doesnt sell 1/8" Aluminum sheets =(
Old 03-23-2009, 04:22 PM   #45
NorthBayResident
Member#: 204200
2008 Impreza 2.5i
I have not yet, sorry. Im on break right now so I don't have access to a lift, but I should be getting started next week.
Old 03-23-2009, 10:21 PM   #46
truckie453
Member#: 199767
2009 Impreza
Dark Metallic Gray
No worries... Enjoy your break!
I'll keep an eye out for your update.
Old 03-26-2009, 09:23 PM   #47
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
So I was at a metal supply shop today, and asked about prices on stainless steel sheet metal. Prices on steel are not that much lower than the price of buying a skid plate. I'm going to look into plastic or some polymer as a meterial for the skid plate. Anyone got sugestions?
Old 03-26-2009, 10:12 PM   #48
ADAS1223
Member#: 159853
2005 Impreza
wrb
polycarb glass? nvm... they go for like $60+.. a local sells Aluminum skid plates for $75 so might as well buy one. unless you find a junk street sign to fab with
Old 03-26-2009, 11:20 PM   #49
OUScooby
Member#: 100449
'04 WRX 307whp278tq
'99 Imp L, '72 MGB
Where can you get a $75 skid plate? Hook me up.
Old 03-26-2009, 11:54 PM   #50
fastwrx25
Member#: 126441
03 bugeye
alumalite? google it
FS: 02-07 impreza aluminum mini skid plate/splash guard ten80 Exterior/Styling 3 12-15-2008 10:26 AM
Brush Guard, skid plates, fender liners, and front end aero. Chi_San Interior & Exterior Modification 0 11-20-2007 10:28 PM
WTB: for GC8 L Coupe, clear lights, jdm tails, short shifter, diff guard, skid plates compleckz Private 'Wanted' Classifieds 1 04-20-2007 10:07 AM
FS/T: Stock splash guard (skid plate thing) Stover954rr Private 'For Sale' Classifieds 9 12-07-2005 12:08 PM
Need a skid plate (the stock splash guard isnt very tough!) yellowblaze Baja Forum 3 08-14-2005 08:55 PM
