Old 03-24-2009, 08:17 PM   #1
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
Default Check engine light ....blinking...
According to the owners manual this indicates some sort of misfire. im a bit of a subie noob so bear with me.... what would cause the engine to misfire? and how do i fix it?..... btw its a '98 2.5 RS with 116,000 headers, cold air intake,
light weight pullys thats all i know about the history of the car. i bought it about a month ago.
thanks guys
Baja820 is offline   Reply With Quote
Old 03-24-2009, 08:47 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
It could be a coil that is starting to fail or has failed.
It could also be the intake. If it lets in too much air and the MAF doesn't properly compensate with more fuel then at higher rpms it can go lean and detonate, throwing a misfire code. When we first got it, my wife's car had a JC Sports intake and anything above 5500rpm would crackle with detonation.
Old 03-24-2009, 08:53 PM   #3
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
the thing that is weird is it seemed to be at lower rpms and the intake has been on there for at least six months. could it be a simple spark plug gone bad? or loose wire? how often do the coil packs go bad?
Old 03-24-2009, 09:00 PM   #4
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
have the code pulled to get a more specific idea of what it could be or where to start the diagnosing process. misfires can be caused by many things.
GrundleJuice is online now   Reply With Quote
Old 03-25-2009, 12:29 AM   #5
sa4baru
Member#: 195354
check the plugs 1st.
sa4baru is offline   Reply With Quote
Old 03-25-2009, 10:57 AM   #6
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
yeah that seems like a good place to start. Thanks man.... im just bummed out cause i have to drive my jeep to work today
Old 03-25-2009, 10:07 PM   #7
sa4baru
Member#: 195354
post up if it fixes it.
Old 03-25-2009, 11:04 PM   #8
jasonspeed
Member#: 187971
03 Grocery Getter
subyshop.com
THIS! flashing CEL means CAT damage from misfire. If you get a scan tool (rent one from autozone so you don't have to drive a misfiring car) and find out what cylinder it is and go from there.
jasonspeed is offline   Reply With Quote
Old 03-26-2009, 12:25 AM   #9
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
I thought a flashing cel only ment misfire detected that could damage a cat... not the other way around....
Old 03-26-2009, 12:25 AM   #10
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
Will do!
Old 03-26-2009, 09:29 PM   #11
my4isflat
Member#: 120002
2000 2.5 RS, '95
Legacy w/325k mi (RIP)
You are correct.
my4isflat is offline   Reply With Quote
Old 03-28-2009, 01:17 PM   #12
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
ok ... sat. morning. time to change the spark plugs..... what a pain in the ass! I thought changing the plugs in my jeep was a pain! plus its like 40F!
Old 03-28-2009, 01:25 PM   #13
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Oh, it is such a pain. I learned that the hard way
chazly413 is offline   Reply With Quote
Old 03-28-2009, 01:59 PM   #14
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
got any tips? this is my first time on a subaru...
Old 03-28-2009, 08:00 PM   #15
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
anyone know what the gap should be? pulled the old ones out they .050 Im thinking they should be more like .040....
Old 03-28-2009, 08:25 PM   #16
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
.039"-.043" tighten to 15 ft-lbs
yarrgh is offline   Reply With Quote
Old 03-28-2009, 08:29 PM   #17
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
nice.... could the large gaping on the old plugs have caused the misfire?
Old 03-28-2009, 10:41 PM   #18
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
Ok I changed all four spark plugs...... It did not fix the problem. the weird thing is it didnt start stuttering till the engine warmed up.... im thinking bad coil packs?.... also since i removed the battery to change the plugs the cel went away and has not returned even though the engine was misfiring pretty bad.
Old 03-29-2009, 01:37 AM   #19
22BeaSTI
Member#: 122686
1997 leggacy GT
sexy silver
first does the car feel gutless or shake alot when you push down the gas pedal? or does it feel like it's running on 3 cylanders? or anything but normal. also check you mas air flow sensor and your pcv valve chances are the car hasnt had it's major tune up yet with timing belts and stuff so i'd look into that first.
22BeaSTI is offline   Reply With Quote
Old 03-29-2009, 11:39 AM   #20
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
your first post says it's a 98, yet your profile says 99...?
have you checked your valve lash? hmmm...I'm not sure if you can on a 98, but 99 was sohc, so you could on that. and since the correctly gapped plugs may not have solved it, Matt may be right that it could be a coil pack on its way out.
If it didn't do anything bad until temp was up, it may be time to change temp sensor.
Old 03-29-2009, 11:54 AM   #21
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
PULL THE CODE for crying out loud.
If you're only misfiring on one cylinder, it'll solve a lot of your time in diagnosis. Example: If you're misfiring on a given cylinder, and you switch plug wires across the engine (center-mounted coilpack = equal length wires), if the problem follows with the swap then you very likely have a bad plug wire.
LetItSnow is offline   Reply With Quote
Old 03-29-2009, 11:26 PM   #22
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
really gutless at about 3500 rpms.. then it screams at about 4700rpms...
sorry its a 98 for sure i need to change that
Old 03-29-2009, 11:29 PM   #23
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
will it still pull the code if its cleared?
Old 03-30-2009, 09:47 AM   #24
bcware
Member#: 190724
2008 2.5i Sedan
Lightning Red
I think so! That is, unless you've driven it a lot since you cleared it. Last I remember some mechanic told me clearing a CEL for an inspection wasn't enough; you have to drive the car through its "drive-cycle" before it totally resets.
Can anyone else confirm this? Or totally shut me down? Haha
bcware is offline   Reply With Quote
Old 04-02-2009, 12:42 AM   #25
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
Ok so it only happens when the engine is warmed up.... gotta be the coil pack right?
btw I dont have access to a obd tool......
Check engine light blinking!?! Chonojake Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 03-11-2006 09:06 PM
check engine light blinking jimball21 Tri-State Area Forum 20 01-25-2005 12:31 AM
Check engine light blinking!!! rageatm007 Electrical & Lighting 5 07-26-2004 07:54 AM
check engine light blinking after installins safcII for 99 2.5rs q0Y0p Electrical & Lighting 5 08-26-2003 09:08 PM
check engine light blinking after installins safcII for 99 2.5rs q0Y0p Electrical & Lighting 2 08-26-2003 08:59 PM
