Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 03-27-2009, 04:13 PM   #1
spazmoo
Member#: 140183
2005 Legacy GT
Default What is an EJ20G?
What is an EJ20G and why is it so special. What are the pros and cons? What kind of block should I tell my friend to get? He doesn't have all the money in the world, but he is up a creek with a blown engine.
Ben
spazmoo is offline   Reply With Quote
Old 03-27-2009, 07:47 PM   #2
RallyColtTurbo
Member#: 16819
The EJ20G is the first incarnation of a turbo motor in Subaru's EJ motor line. It was first used in the '89-93 Legacy/Liberty. It was the top motor almost everywhere but in North America. It was then slightly revamped and used in the '93-'96 Impreza WRX/STI.
There is nothing "special" about them other than being the oldest, they are usually the cheapest. Some say they are the stoutest, but that is likely just because they were less high strung than later years.
EJ20Gs are easily identified because they have a cast 90 degree elbow on the inlet of the turbo (no pipe under the manifold).
You don't state what car your friend has, but if your friend has an '02+ WRX then he cannot use the EJ20G. Maybe the shortblock, but not the heads or intake manifold. There are sensor compatability issues.
RallyColtTurbo is offline   Reply With Quote
Old 03-27-2009, 09:41 PM   #3
spazmoo
Member#: 140183
2005 Legacy GT
My friend has an 04 WRX. He asked me today to do some research on the EJ20G. He said he heard that it was stronger than his old engine. Do you think I should tell him to just get an STi engine?
Old 03-28-2009, 12:00 AM   #4
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
They are pretty tough bitches. I've got a number of friends with V1-2 WRX's that are making wicked numbers with the factory engine and are reliable DD that also see regular track time.
I intend to up the output on mine till it just blows up.
i_c_the_light is offline   Reply With Quote
Old 03-28-2009, 12:57 AM   #5
RallyColtTurbo
Member#: 16819
He could only use the shortblock, and even at that his compression ratio will not be ideal. The piston crowns and head gasket thickness have changed through the years.
In your friends case, I would look for an EJ257/EJ255 shortblock and an open source tune after installation.
If he really wants (or already has) an EJ20G, rebuilding the EJ20G with USDM WRX spec pistons (forged or not) would make an good motor, but not neccisarily any better than using an actual USDM WRX block.
Old 03-28-2009, 05:57 AM   #6
jaimebenlasnow
Member#: 188065
Im not too sure about this, EJ20G had everything forged its close deck etc.. so using some wrx piston wouldnt really make this motor as good as it is..
jaimebenlasnow is offline   Reply With Quote
Old 03-28-2009, 11:03 AM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Not true, on several counts
Only really early Ej20G's(like 89-91) or STi's(up through 1995) were closed deck. 90% of them were not.
Only STi versions ever got forged pistons.
All Ej20's from 1989 until present have forged cranks and rods. There's really not one that's better than the other.
I personally wouldn't put an Ej20G block into an '04 WRX. For the money one would spend building an Ej20G to make it appropriate you can buy a brand new crate Ej25 bottom end.
Old 03-28-2009, 01:08 PM   #8
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
http://www.rogerclarkmotorsport.co.u...productID=1036
EJ20 closed-deck block is one of the strongest Scooby starting points around and one of that was equipped with oil squirters to aid pistons cooling. Closed-deck blocks are the strongest blocks of Subaru and endure high boost and high horse power (700+hp). Heres a pic of a jdm ver7 ej207 and a ej20g.
Old 03-28-2009, 02:12 PM   #9
jaimebenlasnow
Member#: 188065
I<m pretty sure youre talkin about the ej20k cause there was not that much of variant for the ej20g and the STi only came out in 94 for the ej20g and i<ve read and heard that pretty much all ej20g are closed deck and forged till 95-96
Old 03-28-2009, 07:35 PM   #10
RealDealTarheel
Member#: 142447
06 Outback
So when my 94 WRX gets it's heads pulled for an HG change I will find an open deck block?
The Spec C crank isn't better than the EJ205 crank, or are they all the same?
RealDealTarheel is offline   Reply With Quote
Old 03-28-2009, 08:21 PM   #11
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
Yes and yes...they are all the same as far as strength.
Cbgrandtheftauto is offline   Reply With Quote
Old 03-28-2009, 10:35 PM   #12
spazmoo
Member#: 140183
2005 Legacy GT
Did the EJ20G come in anything over here? It sounds to me like the only source of one would be overseas.
Old 03-28-2009, 10:55 PM   #13
RallyColtTurbo
Member#: 16819
Correct. No EJ20Gs came to north America from the factory.
Old 03-28-2009, 11:57 PM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
This is the point at which I politely suggest that you search my last 100 posts or so here in the Pre-2002 FTP forum and see what I have had to say on the subject in the past. I said what I meant.
Old 03-29-2009, 12:05 AM   #15
blkgm8
Member#: 184543
JDM RHD GM8 Type R
02 6 Speed Bugeye
We do know however of several V2 V-limited WRX with closed deck.... including mine which is 1996..... Closed deck baby. Yea... I already know the response will be "it was probably specially ordered as an option." Whatever the case may be the closed deck ej20g is a sick starting point for some serious power. No need to add sleeves.
blkgm8 is offline   Reply With Quote
Old 03-29-2009, 12:51 AM   #16
RealDealTarheel
Member#: 142447
06 Outback
They're both cross drilled?
Old 03-29-2009, 11:26 AM   #17
WRX_RA
Member#: 151188
1997 GC8 EJ20G
2010 W204
no and yes..
just pulled the heads off my 93 wrx and its a closed-deck block.
WRX_RA is offline   Reply With Quote
Old 03-29-2009, 12:33 PM   #18
Matt Monson
Member#: 832
99 2.5RS, '85 911
What ever happened to sending me a picture of your plate?
Old 03-29-2009, 02:24 PM   #19
jaimebenlasnow
Member#: 188065
Mine is a 93 WRX RA and its closed deck
Old 03-29-2009, 03:14 PM   #20
Matt Monson
Member#: 832
99 2.5RS, '85 911
Yep. RA's and STi-RA's will be the exceptions that I was talking about. For the first couple of years of the WRX they didn't have an "STi" model but the RA's were the equivalent offer at the beginning. It was kind of the transition from the RS-RA Legacy. Then over time the model line expanded and there were RA's, STi's, and STi-RA's.
I've never seen a 1993 EJ20G that was closed deck that wasn't also an RA. I've seen a lot of open deck 1993 engines from both WRX's and Legacies.
Old 03-29-2009, 05:03 PM   #21
jaimebenlasnow
Member#: 188065
Well ahah we were on the same line thats what i was talkin about
Old 03-29-2009, 08:32 PM   #22
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Let's face it, it's really muddled.
Old 03-29-2009, 10:31 PM   #23
Flat4TW
Member#: 200456
0295 WRX
why cant your friend do the search himself? if hes engine is fine stick with it until it dies... if he got the dough go for either an ej207 or ej257 build.
Flat4TW is offline   Reply With Quote
Old 03-29-2009, 11:11 PM   #24
RealDealTarheel
Member#: 142447
06 Outback
^^This, I don't think even Subaru really has a firm grasp of which motor they put in which car, much less someone in the states buying front clips and tearing down motors.
Old 03-29-2009, 11:21 PM   #25
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
Im not sure on that...Matt might be able to answer that.
what is an acessport and what is turbo pressure meter for? lasercombo Newbies & FAQs 43 02-13-2006 10:56 PM
WHAT IS AN ALK???? Frey Bone Newbies & FAQs 9 06-01-2001 05:51 PM
What is an Air Assist Solenoid? KeithRS Normally Aspirated Powertrain 8 05-08-2001 10:22 PM
What is an S-AFC? datpnoy2nv Normally Aspirated Powertrain 5 05-03-2001 03:25 AM
('93-'01) What is an Impreza C-21???? TurboRX Impreza Forum 0 04-12-2001 10:07 AM
