#51 |
Member#: 2112
MWSOC
I finish college in three weeks, so that has to be done before I can bust out some more wicked voodoo.
Denver has a new road course opening up . Drifting those wide flat corners is going to be a blast.
#52 | |
Member#: 196257
Vehicle:02 wrx 354 whp RIP 10' genesis coupe |
I am proud to be part of the e85 army...
1) Your injectors size: modded injectors (almost 830 cc's) 2) Injector duty cycle (if you have it), Ill log later, should be low 90's 3) Elevation: 5400ish ft, broomfield co 4) Turbo VF30 (spools quick and holds real strong till a little past 6k ty e85) Quote:
#53 |
Member#: 137832
TXIC
Vehicle:02 02 PSM WRX 05 OBP STI |
1)Injector size- 820cc (modified stockers)
2)IDC- not sure yet.. 3)elevation- 587ft above sea level 4) turbo- vf48 not sure of the numbers it pulls really nicely.. tune is half way done.. the clutch kept slipping on my pulls .. will post numbers soon enough |
#54 |
Member#: 169591
Vehicle:05 LGT |
Just found this thread. Cool. '05 LGT
1) Your injectors size = PE850 "flow 930ish per mfgr" 2) Injector duty cycle = ~75% 3) Elevation = 5800-6200ft (Denver, Bandimere dragstrip) 4) Turbo = VF52 I haven't dyno'd my car nor I have I completely finished the tune due to the unexpected death of my laptop (new dedicated tuning laptop is on the way...). But I did take it to the dragstrip... Elevation at Bandimere = 5800' (other guys here have it listed as 6200', but pretty sure it's 5800') Here is the video of this run.. ![]() Last edited by Guy on the corner; 03-30-2009 at 06:47 PM. |
#55 |
Member#: 171611
BAIC
Vehicle:GH WRX Stg.1 SSM |
Love me some E85. Am not tuned for it with my VF43 but was *this* close to throwing in a 1/2 tank or so this past weekend at one of the local E85 equipped stations.
P.S. - Why no rebuttal from the 'haters'?? |
#56 | |
Member#: 169591
Vehicle:05 LGT |
Here is the timing I am running on my 2.5L, VF52. Critiques welcome. ![]() |
#57 |
Member#: 163648
MWSOC
Vehicle:2002 Wrx,2.5L,HTA86 E85,2007 6mt,No traction |
^cool lets see more timing , I will have some once I get the beast back on the road....
#58 |
Member#: 170439
Vehicle:I <3 Lamp |
#59 | |
Member#: 9548
RMIC
Vehicle:2004 WRX STi PSM, 10.741 @ 126.29 |
#60 |
Member#: 169591
Vehicle:05 LGT |
Makes sense, but in juanmedia's "SORTED BY 1/4 ET" in post #2 he has the quarter-mile runs at 6200'.
Elevation shouldn't matter for the dyno graphs since the CF takes that into account (theoretically anyhow) |
#61 | |
Member#: 127704
TXIC
Vehicle:2013 Leggy Scooby no4 - huntin for 5 |
Pretty close to my timing dude, when I get the next lot of runs in, I will post up the latest.
#62 |
Member#: 2112
MWSOC
Forgot to post my setup!
Drunken Boxer v3.0 1) Your injectors size: STOCK 280cc 2) Injector duty cycle: enough 3) Elevation: 5280ft. 4) No boost. Bolt-ons + Fuel chemistry only. 32mpg on virgin E85. My only fuel mod is a Walbro pump. It also uses colder NGK plugs. 7's and 8's love you long time... E85 allows better tuning from the same combinations to bring us closer to our sea level times. It rapidly became popular in Colorado due to availability and a solid enthusiast base crossing ALL realms of vehicles. Gas tuning up here sucks because every vehicle is running around like a big octane test with brutally hot air and poorer cooling capacity compared to sea level. Ethanol fills both voids. I doctor fuel chemistry to improve power, cooling, and mileage. Ethanol is a fantastic tool at any altitude. As I prefer to put it: "Making altitude meaningless." Latitude means more with ethanol blends. You equatorial bastards get to run 100% hydrous. I can't do that in December .BTW, you guys might want to consider trying butanol eventually. I'll have more data up on that on my website. My little pitbike loves the stuff, but it needs to be blended to run right. Butanol doesn't evaporate very well but carries just fine in a mixture. Too much of it in a blend doesn't burn completely and I have to dial the mixture back to run right. These run really well: E85 and butanol Gas, E85, and butanol + hydrous ethanol in any of those. These mixes hold up for me so far in the cold. Gasoline is still the only one I can run straight. Blends of the others run brutally fast with the right plugs, timing, and mixtures. E85 is easy for most of you to handle. But, I went over your heads a looooooooong time ago with fuels. Marketing this stuff is a major bitch .Last edited by HamFist; 04-01-2009 at 12:21 AM. |
#63 |
Member#: 2112
MWSOC
Oh, one more thing....You better consider a "Biofuel Armed Forces". Within 10 years America will have these fuel blends proven, tested, and stable in land, air, and sea.
That's what made Subarus boring to me. It's all about "my car's faster than yours"...not everything that's actually out there that made it into specifically a Subaru. I prefer flight, and a Subaru is my little baby airplane. Luckily, few ricers are actually working with E85. They're too busy blowing up everything else before they hear of E85. I like my strong hobbyist and tinker-freak markets for specifically biofuels . They're free of a lot of riff raff and are far more creative. They're even self sufficient and know how to work on their own stuff. Sorry to sound harsh and cynical, but when you're trying to make a living things look different.I <3 biofuel scooters . |
#64 |
Member#: 114730
SWIC
Vehicle:2006 WRX Limited Wag |
1) Your injectors size -960cc
2) Injector duty cycle (if you have it), 95% (installing bosch 044 as we speak and raising base fuel pressure to lower this) 3) Elevation - 5400 ft 4) Turbo - Blouch Dominator 4.0R 2006 WRX Limited Wagon Stock rods, CP pistons, 05 6 speed Dynoed 546/540 SAE (~19%, thanks to our altitude and 11.9 atm press) Ran 11.69@122 with stock tires, 1.73 60'. I'm the guy that tuned Juan's car. |
#65 | ||
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
![]() Quote:
![]() Also I see lot of people that posted setups but didn't include power numbers , please include the numbers so I can add youUPDATED 03/31/09 |
#66 |
Member#: 2112
MWSOC
150whp, 150wtq. I'm not picky. None of my runs are the exact same numbers, anyway
. I updated my mods, too. It only has a 255 pump for fueling.This would be a good spot to ask but I don't want to go OT. Has anyone else noticed condensation issues in their oil or crankcase? I haven't had any, but here it's a rare issue. Motors in cold climates are the ones going out but mine hasn't. They spin bearings, but by then the oil is too contaminated to tell. Are iron block Mitsus behaving any differently than aluminum block Subarus? Last edited by HamFist; 04-01-2009 at 12:26 AM. |
#67 |
Member#: 184206
SWIC
Vehicle:2013 X1 sDrive 28i gray |
#68 | |
Member#: 6265
BAIC
Mike |
#69 |
Member#: 163648
MWSOC
I think it is a little safer to stay in the .75-.78 range I think my car tends to run just as well there... I tried the .82 range for a while and I don't like it as much as the .75-.78 range... HHHmm E85 tends to keep my egts pretty low, what are we talking when you say up there a little?
#70 | |
Member#: 44771
![]() I wait for better times ![]() |
#71 |
Member#: 163648
MWSOC
^thats pretty good for 5400ft elevation isn't it??
#72 |
Member#: 114730
SWIC
#73 |
Member#: 44771
#74 |
Member#: 161273
TXIC
Vehicle:2008 forester xt silver |
Thanks to Cobb Tuning in Plano for turning my FXT into a torque monster.
20 psi WTQ 381 WHP 331 Mods: VF48 Cobb turboback Turboxs tmic 850 cc DW Perrin Fuel Rails Walbro Fuel Pump Cobb Intake E85 idc: 94% Pardon the bad iphone pic ![]() Last edited by modliving; 04-09-2009 at 12:06 AM. |
#75 |
Member#: 184206
SWIC
1) Your injectors size = DW 850cc
2) Injector duty cycle = 75% ish 3) Elevation = Phx, not sure 4) Turbo = VF39 Maps not quite done. . . but 363whp is pretty good i'd say ![]() Terrible launch but the trap speed was decent: ![]() ![]() ![]() Last edited by ChandlerWRX06; 04-19-2009 at 12:46 AM. |
| Thread Tools | |
| Display Modes | |
| Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
| jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
| The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
| Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
| Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
