Old 04-08-2009, 06:25 PM   #1
wiggy1
Member#: 142987
Default Another Heated Mirror Install on 2006 Subaru Baja
All, i just installed the heated morrors on my 2006 Baja and they work great. I followed the instructions in another thread, but had to do some hunting to find the part numbers, so I thought I would share them here:
Heated Mirror Driver's (Left): 91031AE99ANN
Heated Mirror Passenger's (Right): 91031AE98ANN
Mirror Switch (with heat): 83061AE04A
All parts can be bought at subarupartsforyou.com so you can order it all in one shot. No need to visit your dealer. The install is real easy, with direct replacement of existing mirrors and switch assembly.
Now I have my Atlantic Blue Pearl powered (non-heat) mirrors for sale. Let me know if you are interested. I listed them in the for-sale area of the forum.
Cheers
wiggy1 is offline   Reply With Quote
Old 04-08-2009, 10:33 PM   #2
BajaGuy68
Member#: 127720
2015 WRX
Lightning Red
Thanks for the parts numbers! I'll get a set for my 06' Turbo....they'll come in handy next winter!
BajaGuy68 is offline   Reply With Quote
Old 04-09-2009, 12:27 AM   #3
Benhart21
Member#: 149617
I'm definitely gonna have to do this to mine. It would have been great to have this winter.
Benhart21 is online now   Reply With Quote
Old 04-09-2009, 08:05 PM   #4
The Distance
Member#: 140704
Did you get your heated mirrors painted? I thought I saw a note on subarupartsforyou.com that they would be able to paint the mirrors for you. I suspect that I am wrong.
Is it feasible to buy the heated mirrors and just exchange the "guts" of the heated mirrors with the currrant, painted mirrors?
The Distance is offline   Reply With Quote
Old 04-09-2009, 08:14 PM   #5
wiggy1
Member#: 142987
I did not get my mirrors painted. I think there is a way to extract the mirror and power module from the painted hoods, but it involves heating up the glass to soften the holder and I believe that there is some glue that is used to secure the glass. This glue has to be cut through and you run the risk of breaking your mirror in the process. While that may not be a bad thing on the non-heated mirror, you definately would not want to have that happen to your brand new heated mirrors. It is just not an easy process any way you look at it.
Old 04-10-2009, 11:16 PM   #6
shipjumper
Member#: 6307
what I has no car...
am carless
junkyards and ebay for the win.....
mine cost me $79 a miror and $50 for the door switch... 15 minutes, heated mirrors....
shipjumper is offline   Reply With Quote
Old 04-11-2009, 12:10 AM   #7
Benhart21
Member#: 149617
I just remembered my old roommate has a wholesale account with the local Subaru dealer.
Old 04-11-2009, 09:43 AM   #8
jeromes
Member#: 192299
2011 Forester XT
Default How much for the old painted mirrors
How much for your old ones?
jeromes is offline   Reply With Quote
Old 04-11-2009, 10:25 AM   #9
shipjumper
Member#: 6307
am carless
mine are the painted black (like the LLBean)
for both pass and drivers? i dunno $100?
Old 04-11-2009, 10:46 AM   #10
WYSubaru
Member#: 154884
2005 Baja turbo
What models and years of mirrors can you use?
WYSubaru is offline   Reply With Quote
Old 04-11-2009, 11:35 AM   #11
jeromes
Member#: 192299
2011 Forester XT
Default Pass
Pass on the black ones for $100.00
Old 04-11-2009, 03:32 PM   #12
shipjumper
Member#: 6307
am carless
ANY outback or Legacy mirrors from 2000-2004 will bolt right up. I got the switch for the door @ subarupartsforyou.com it was $50 or so.
the master control on the drivers side pops right up with a gentle pry from a flatblade screwdriver. You can then pop out the mirror control and pop in the heated mirror control. There is also a #3 phillips screw behind that for door panel removal. the 2nd #3 phillips is located behind the little square under the armrest. then reach under the door panel at the bottom and pop out the door pops, then the door panel slides up off the window sil.
if you have tweeters they will have to be popped off first.
the mirror harness is up near the mirror, and the door is prewired for it.
3 screws hold the mirror on, remove, install, re-tighten the screws, hookup the harness, re-align and pop the door panel back on, 2 #3 screws, master control, and done.... 15min tops.... then the pass door is the same.
if you can dealwith unpainted mirrors, a company called keystone does auto crash parts and can get you unpainted ones new in the box for less than subaru OEM ones.
Old 04-14-2009, 01:24 AM   #13
steven765
Member#: 105920
2006 Baja 5 Speed
I also have my orig mirrors still around for sale from when I did the switch if anyone is interested.
I also installed the heated seats if anyone is curious how that went.
steven765 is offline   Reply With Quote
Old 04-14-2009, 01:29 AM   #14
Benhart21
Member#: 149617
Absolutely, with part numbers please.
Old 04-14-2009, 02:14 AM   #15
The Distance
Member#: 140704
[quote=if you can dealwith unpainted mirrors, a company called keystone does auto crash parts and can get you unpainted ones new in the box for less than subaru OEM ones.[/QUOTE]
Can you give a few more details about this Keystone parts place? I did a google search and came up with nothing.
Old 04-14-2009, 04:29 AM   #16
Benhart21
Member#: 149617
This place? http://www.keystone-auto.com/
Apparently you need an account to order from them.
Old 04-14-2009, 09:36 AM   #17
shipjumper
Member#: 6307
am carless
crap, really?
I work for a ford dealership, so if someone REALLY wants em, I can order them.
Old 06-26-2016, 01:21 PM   #18
Rsmith8126
Member#: 449047
Just bought a 2005 Baja with heated seats they don't work can you tell me where the relay is and how do you get to the switches to check voltage sure hope the elements aren't bad thanks Ronnie ps just bought 2 heated mirrors on eBay for 79.00 new black and a used switch for 25.00 be glad when they get here
Rsmith8126 is offline   Reply With Quote
NY: 2006 Subaru Baja Sport $13k sandman1011 Tri-State Area Private Classifieds 2 04-18-2010 04:23 PM
Heated mirror install party? simonbsays North West Impreza Club Forum -- NWIC 8 09-29-2008 12:29 PM
custom Sub install on a Subaru Baja moonzie Car Audio, Video & Security 7 01-17-2007 05:20 PM
Win a three-year lease on a Subaru Baja Sport Jon [in CT] Baja Forum 2 01-24-2003 10:49 PM
