Vancouver Impreza Club
Old 04-14-2009, 02:18 AM   #1
JccL
Member#: 152806
2006 2.5i
SGM
Default local pulley install
hey guys i was wondering where i should get a lightweight pulley installed.
I was thinking any performance shop such as RG, drivehard, advance, teamwork, ajr or a dealership. Or any home mechanics with torque specs and a wrench wanna help me out? I think RR is overkill for something so simple. let me know your thoughts on the places i listed and any other recommendations. thanks guys
JccL is offline   Reply With Quote
Old 04-14-2009, 02:29 AM   #2
tora
Member#: 5851
09 Forester XT
+ NA Miata
Or, just don't put it on, sell it and save yourself some moneys!
tora is offline   Reply With Quote
Old 04-14-2009, 02:31 AM   #3
JccL
Member#: 152806
2006 2.5i
SGM
haven't bought it yet lol
Old 04-14-2009, 02:32 AM   #4
tora
Member#: 5851
09 Forester XT
+ NA Miata
don't, biggest waste of money.
Old 04-14-2009, 02:32 AM   #5
tora
Member#: 5851
09 Forester XT
+ NA Miata
But to answer your question, you answered it in your first post in terms of who could do it.
Old 04-14-2009, 02:45 AM   #6
aspect
Member#: 43901
no car
+1
111
aspect is offline   Reply With Quote
Old 04-14-2009, 03:32 AM   #7
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Or just install it yourself. Takes less than 30 minutes if you have the right size socket and a long breaker bar.
I don't really feel any noticeable difference on my car though.
minifreak is offline   Reply With Quote
Old 04-14-2009, 03:35 AM   #8
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
lol have you felt the stock som bitch.....its heavy as hell...like 7 lbs lol....and its ugly as sin....
it wont really get you much real gains though...maybe a bit of throttle response...but it'll look pretty.....
if you still want to do it let me know and i'll give you a hand, it'll only take about 20 minutes....i live in langley....let me know
ps aspect and tora....have u tried LW crank pulley or are you going by common nasioc consensus?
people spend just as much on other cosmetic engine mods oil caps and belt covers.....so why the hate for the pulley...lol
Jeff54 is offline   Reply With Quote
Old 04-14-2009, 03:43 AM   #9
JccL
Member#: 152806
2006 2.5i
SGM
i don't know my thinking is reduce drivetrain loss, it'll be the same as removing the spare tire. or running smaller diameter wheels/tires. I'm not expecting anything close to the gains from EL headers over UEL but that's another can of worms. esp because the car is NA little mods make a bigger difference then they do on turbo cars. johnson or jeff do you guys have a breaker bar/torque down specs?
Old 04-14-2009, 03:51 AM   #10
JccL
Member#: 152806
2006 2.5i
SGM
I have access to a breaker bar and torque wrench but have no idea how to pull off the old one and how much tension to put on the belts and bolt. If anyone has specs please post that also = ). This is assuming i actually end up buying one.
I suppose it wouldn't hurt to put up the pulley's i've looked at agency power, cobb, perrin, medieval and groupA.
Any experience with any of these? i'll likely end up getting the groupA or medieval since they're the cheapest at about 100
Old 04-14-2009, 03:59 AM   #11
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
i plan on getting a lightened pulley set but its at the bottom of my priorities as i hear gains are only measurable by the butt dyno.
if your car is stock, you might want to save the money towards a bigger mod?
notjustforshow is offline   Reply With Quote
Old 04-14-2009, 04:02 AM   #12
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Torque spec is between 94 ft-lbs to 133 ft-lbs depending on which instruction you followed.
http://techinfo.subaru.com/html/down...IMING_BELT.pdf <-- Page 17 has the reinstallation info.
I cheated with the installation by cranking the engine with the coil unplugged. I won't really recommend this method as your car should be new enough that the bolt isn't ceased yet.
I also have the Group A crank pulley. Even though it is quite a bit lighter than stock I didn't felt any real gain (it is said the gain on a turbo is less than that of a NA car).
Old 04-14-2009, 04:07 AM   #13
Chp_Stix
Member#: 95195
1974 Rat Rod Bug
back and white
I noticed my car revved a bit quicker with it did it myself easy!
Chp_Stix is offline   Reply With Quote
Old 04-14-2009, 04:12 AM   #14
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
DIY. Takes like less than 10 minutes.
Old 04-14-2009, 04:17 AM   #15
JccL
Member#: 152806
2006 2.5i
SGM
yeah besides boring the hell out of the block and intake there isn't much more for NA lol cams aren't an option as there isn't any tried and tested reliable setup available. car is rock solid with konis and rce yellows. sways/endlinks will come as soon as i find a good set used. Wheels and tires have been done and have been aligned w/ a bit more negative camber. There are holes in my trunk, but it adds to the funkyness of driving a sube/ plus appearance isn't anywhere near the top of my priorities. I've managed to weaken the car by putting uel headers on but it makes for a more enjoyable driving experience. Might toy with phenolic intake manifold spacers after i do some more reading on them. brakes are great for dd'ing but ss lines and/or 4pots are being considered.
and i've derailed my own thread lol
thanks for the specs johnson
Old 04-14-2009, 10:13 AM   #16
brendan_mac
Member#: 125055
12 STI hatch
It's actually a good mod for n/a guys. Made rev-matching easier for me, pretty minor (on a 2.0-litre) and I've heard the 2.5 Turbo guys don't notice it at all.
It just depends how much torque you have.
brendan_mac is offline   Reply With Quote
Old 04-14-2009, 10:56 AM   #17
tora
Member#: 5851
09 Forester XT
+ NA Miata
Yes, I had one on my old Legacy N/A. It felt nicer, but there were ZERO gains as far as power went. It is a bling option. The reason for the hate is the widespread opinion that it DOES offer gains on our cars.
Read this thread - http://forums.nasioc.com/forums/show...ghlight=pulley
Anyways, if someone just wants to do it for looks I can't argue with that.
Old 04-14-2009, 11:52 AM   #18
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
yes there is...the delta regrinds are awesome.....i'm using thems
http://www.deltacam.com/ give em a call...they're like 90$/cam
then opensource the ecu (u can do that with the 2.5i apparently).....
those are the only two things that will get you power on the RS
Old 04-14-2009, 12:00 PM   #19
JccL
Member#: 152806
2006 2.5i
SGM
I think they are still ironing out the kinks for the 2.5i avls, usage isn't widespread but it is growing.
Old 04-14-2009, 12:11 PM   #20
Lantec
Member#: 48685
2010 Prius
http://www.hspn.tv/?videoid=65&catid=14
That's what I used to install the crank pulley. Butt dyno felt the car revved quicker but I dunno. I bought it when it was cheaper during a group buy.
Lantec is offline   Reply With Quote
Old 04-14-2009, 01:03 PM   #21
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
I've done the mod before, and would prefer to spend my money elsewhere now.
That said, if you NA guys are seeing gains, you can't argue with that. Plus, you're so limited on the mods you can do, it's almost a no brainer. Fwiw, I'd throw a shot of Zex on it and call it a day.
steve is offline   Reply With Quote
Old 04-14-2009, 01:18 PM   #22
Jeff54
Member#: 129503
2002 It's resting
6 > 4?
Originally Posted by hypa View Post
Fwiw, I'd throw a shot of gt3071 on it and call it a day.
fixed
Old 04-14-2009, 01:36 PM   #23
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
I removed the lightened pulley that was on the car when I bought it in favour of the stock one, FWIW.
Inertia is important in small displacement vehicles.
Splinter is offline   Reply With Quote
Old 04-14-2009, 03:34 PM   #24
alcoolaid
Member#: 134949
'07 SWP STi
fixed
gt3071? too tiny man 4088r
Old 04-14-2009, 04:00 PM   #25
Drakar
Member#: 68402
2016 WRX
on the street and road racing yes, but drag racing no.
Drakar is offline   Reply With Quote
HELP! pulley install-broke plastic bit that connects a/c tensioner pulley to bolt garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-22-2004 12:46 PM
Pulley install question. RallyImprezive Normally Aspirated Powertrain 4 04-27-2001 12:35 AM
unorthodox racing pulley install IMPREZA GUY Normally Aspirated Powertrain 2 04-24-2001 10:14 PM
('93-'01) NEED HELP ASAP W/ PULLEY INSTALL! TimCat Impreza Forum 2 04-14-2001 11:45 AM
Underdrive pulley install... SFsube Bay Area Impreza Club Forum -- BAIC 2 05-18-2000 05:03 PM
