Welcome to the North American Subaru Impreza Owners Club Monday June 27, 2016
Old 01-20-2009, 12:07 AM   #301
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Originally Posted by limitedsti2007 View Post
Best Turbo For A 2007 Sti?
Whichever turbo fits your budget and goals. We can't answer that question for you, because we're not you. For some it might be a TD05-18G, for others it may be a GT42R on Nitrous with propane injection. This is NOT the forum to answer your question though (as vague as it is), it's simply to list turbos
Audiosavvy is offline   Reply With Quote
Old 01-31-2009, 06:20 PM   #302
bbarker1
Member#: 158206
06 WRX
Does anybody have any specs for the Slowboy Racing 20G? I'm no turbo expert and i didnt know if it was basically spec'd from every other 20g or if they did their own thing with it that changes the amount of air flow.
bbarker1 is offline   Reply With Quote
Old 02-04-2009, 03:22 AM   #303
Pink sOck12
Member#: 175988
07 STi
CGM
for the most part fp's 20g, deadbolts 20g, and slowboy's 20g, will have the same approximate hp rating, all of these have a 44lb compressor wheel and 7 or 8cm hotsides
Pink sOck12 is offline   Reply With Quote
Old 02-18-2009, 09:35 PM   #304
Wrx_Fan_0717
Member#: 152080
6266 Precision'd Big
Cam'd 2.55l 6spd Bugeye
crap wrong thread.....
Wrx_Fan_0717 is offline   Reply With Quote
Old 02-22-2009, 12:55 AM   #305
driftertim
Member#: 203665
Very Helpful info :-)
driftertim is offline   Reply With Quote
Old 03-30-2009, 03:49 PM   #306
ezil71
Member#: 207118
2003 Wrx Wagon
Excellent resource, thank you very much!
ezil71 is offline   Reply With Quote
Old 04-01-2009, 05:56 PM   #307
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Cool Garrett GT Series Turbos from ATP Turbo
More info on the Garrett GT Series Turbos from ATP Turbo: http://www.atpturbo.com
More info on the Subaru Specific applications here:
http://www.atpturbo.com/Merchant2/me...egory_Code=SUB
Garrett GT2860RS (aka GT28RS), stock location
Turbine Wheel: 53.85mm w/ 76 trim
-Housing: .64 or .86 ar
Compressor Wheel: 60mm w/ 62 trim
-Housing: .60 ar
$1,695.0
Dual Ball Bearing GT28RS turbo assembly with T25 style turbine inlet. Comes with internal wastegate pre-assembled. This turbo is great for small displacement engines up to 2.2L and has the ultimate spool up time compared to other units. This turbo has a flow capacity of about 350HP. This turbo would be comparable to the HKS GT2530.
Garrett GT2871R, stock location
-Housing: .86 or .64 ar
Compressor Wheel: 71mm w/ 56 trim
-Housing: .60 ar
$1,745.00
Dual Ball Bearing GT2871R turbo assembly with T25 style turbine inlet. Comes with internal wastegate pre-assembled when purchased with T25 style housing.
Optional "T3/T4 drop-in" style turbine housing available for an easy retrofit into older T3 based applications where T3 turbine the inlet flang is required and either internal or external wastegate are used (internal wastegate assembly is not included when ordering T3/T4 drop-in configuration).
This turbo is great for small displacement engines up to 2.2L and has the ultimate spool up time compared to other units. This turbo has a flow capacity of about 400HP. The external packaging of this turbo is identical to that of the GT28RS and can be a nice stealthy upgrade to step up to 400HP of flow without much re-arrangement.
Garrett GT3071R, stock location
Turbine Wheel: 60mm w/ 84 trim
**Available internally or externally gated at no additional charge.
$1,895.00
The Garrett GT Ball Bearing GT3071R, quite possibly the fastest spooling and most responsive 450+HP capable turbo on the planet now available in a drop-in package for the Subaru WRX/STI! The easy to implement turbo assembly that takes no more than 1-2 hours to install in place of the stock journal bearing VFXX unit is made possible by a high flowing GT inspired ATP exhaust housing and a series of custom engineered components built to suit the installation.
Each GT drop-in turbo package consists of a Garrett factory assembled and high speed balanced dual ball bearing CHRA which is then assembled into a set of CNC machine ported housings that have been optimized in every aspect for maximum flow and efficiency.
All accompanying oil and coolant supply components included in each kit have been designed to properly and seamlessly bridge the Garrett GT turbo to the EJ engine so that the fit is as OE as possible.
Just bolt the turbo on, add fueling and a good tune and prepare for a blast of acceleration. Garrett GT turbos offer more then just "peak HP" numbers. These GT turbos off more torque area under the curve and more "accessible" power then any other turbos series out there.
We do recommend that you compliment your GT bolt-on turbo with a nice high flowing bellmouth downpipe and a high flowing inlet pipe to effortless channel air in and out of the turbo. Although every bolt-on GT turbo ships with a 3" inlet, we do provide a "stepdown" sleeve just in case you're forced to use the stock 2.25" inlet hose. However, as a rule of thumb, turbos, especially higher flowing units love as much inlet flow as possible. This promotes both quicker spoolup and better ultimate HP, with less boost pressure at the manifold. The 3" downpipe and bigger inlet is critical for reaching peak efficiency on the GT turbo. Please also be aware that some downpipes such as the stock catted downpipe, has a "no-flow" door at the wastegate flapper area. This type of downpipe may not allow the wider swinging wastegate valve to open all the way, thus causing the possibility of a "boost-creep" condition or uncontrollable rise in boost.
The GT3071R is a great match on the 2.5L, especially if you're looking for boost threshold that is close to stock but want enough airflow for 450+HP. Almost all the boost is available all the time even at part to medium throttle. Boost recovery between gearshifts is awesome with full boost ready even before upshift is complete as the STI lurches forward with shear enthusiasm at the onse of each gear. The 2.0L driver should not rule out the use GT3071R if his HP target is in the same range. The modern generation wheels, coupled with an awesome wheel ratio, allows even the smaller displacement engine to provide adequate motivation to get the GT3071R going for an great powerband. The competition grade turbo still offers the best response and spooltime out of any unit in this flow range.
Garrett GT3076R, stock location
Compressor Wheel: 76.2mm w/ 56 trim
$1,895.00
The Garrett GT Ball Bearing GT3076R, the benchmark 500+ HP capable dual ball bearing turbo, is now available in a drop-in package for the Subaru WRX/STI! The easy to implement turbo assembly that takes no more than 1-2 hours to install in place of the stock journal bearing VFXX unit is made possible by a high flowing GT inspired ATP exhaust housing and a series of custom engineered components built to suit the installation.
The GT3076R is a great match for the 2.5L that still has great spoolup, especially if you're looking for boost threshold that is just a little later than stock but still want enough airflow for 500+HP. The GT3076R makes boost about 300 to 400 rpms later than the GT3071R but keeps pumping where the GT3071R starts to run out after 450HP. A lot of the boost is available even at part to medium throttle. Dual ball bearings means boost recovery between gearshifts is awesome with full boost ready even before upshift is complete as the STI lurches forward with shear enthusiasm at the onse of each gear. The 2.0L driver should not rule out the use of the GT3076R if his HP target is in the same range. This competition grade turbo is still a big favorite for the HP range because it hits like a hammer while other 500HP turbos are still "spooling up".
Garrett GT35R, stock location
Turbine Wheel: 68mm w/ 84 trim
Compressor Wheel: 82mm w/ 56 trim
$1,995.00
Available with internal or external wastegate
The Garrett GT Ball Bearing GT35R (aka GT3582R aka GT35/40R), the ultimate 600+ HP capable dual ball bearing turbo, is now available in a drop-in package for the Subaru WRX/STI! The easy to implement turbo assembly that takes no more than 1-2 hours to install in place of the stock journal bearing VFXX unit is made possible by a high flowing GT inspired ATP exhaust housing and a series of custom engineered components built to suit the installation.
The GT3582R is a great power maker on the 2.5L that still has great spoolup, especially if you're looking for best area under the curve possible, but still need a lot of power in the high revs. The GT3582R makes boost about 200 to 300 rpms later than the GT3076R but keeps pumping where the GT3076R starts to run out after 500HP. A lot of the boost is still available at part to medium throttle. Dual ball bearings means some boost is always there even if you are lugging the engine and boost recovery between gearshifts is awesome with full boost ready even before upshift is complete as the STI lurches forward with shear enthusiasm at the onse of each gear. The 2.0L driver should not rule out the use of the GT3582R if his HP target is in the same range. This competition grade turbo is still a big favorite for the HP range because it hits like a hammer while other 600HP turbos are still "spooling up".
**Note: Externally gated turbos come with a built in flange for Tial 44mm wastegate on the turbine housing. High flow, less exhaust backpressure, more precise boost control, even more power! Optional Tial 44mm wastegate and dump tube sold separately.
chrisarella is offline   Reply With Quote
Old 04-07-2009, 02:18 PM   #308
DDScooby
Member#: 161876
02 Impreza WRX
is there an update to the list of the new model years WRX, STi and LGT as to what stock turbo comes with which vehicle?
to my knowlege:
08 WRX: TD04
08 STi: VF48
09 WRX: VF52
09 STi: VF48....this one I'm not sure of.
DDScooby is offline   Reply With Quote
Old 04-07-2009, 03:43 PM   #309
blackrex13
Member#: 194884
2009 dirty
JSW TDi
it should be listed that the compressor housings on the 08/09 wrx are the LGT style and only bolt to the stock top mount. and that generic compressor housings will not work on stock 08/09 top mounts.
blackrex13 is offline   Reply With Quote
Old 04-08-2009, 12:57 PM   #310
gero704
Member#: 156883
15 Outback CWP
07 WRX WRB (sold)
yeah i didnt see vf48 in there. but thats an awesome list thanks!
gero704 is offline   Reply With Quote
Old 04-09-2009, 12:58 PM   #311
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
Gt42 Ftw.
snowflowmfg is offline   Reply With Quote
Old 04-14-2009, 03:40 PM   #312
blakeM.U.R.T
Member#: 208575
2004 wrx
if i where to go out and buy a new turbo for my 04 wrx today, what one or one's would you suggest? im willing to spend a little more for something.
blakeM.U.R.T is offline   Reply With Quote
Old 04-14-2009, 04:07 PM   #313
icudruln
Member#: 197060
2004 STi
Bolt on, stock internals? Read the main listing and see what's right for you.
icudruln is offline   Reply With Quote
Old 04-14-2009, 04:08 PM   #314
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
Yea that's kind of vague. A little more info would be helpful.
shadowmd is offline   Reply With Quote
Old 04-15-2009, 12:05 AM   #315
Jdmrevelations
Member#: 206988
2003 WRX
This info is great especially for a noob like me....
Thanks!
Jdmrevelations is offline   Reply With Quote
Old 04-15-2009, 01:12 PM   #316
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
That's sort of like asking us which woman you should marry. It depends on your goals, desires, intended use, and budget.
bcblues is offline   Reply With Quote
Old 04-15-2009, 02:29 PM   #317
Audiosavvy
Member#: 150794
Qcab dakota 4x4
This is not the right place to ask that question. Also, that question is so vague that it's clear that you're nowhere near a point where you should be asking that, you should be researching and researching some more.
1. Decide on your goals for the car
2. Decide on a whp/wtq goal for the car
3. Decide on a budget
4. Research
5. Research
6. Re-research
Old 04-16-2009, 01:20 PM   #318
nickfxt
Member#: 202878
keep the updates coming! We got anything for the 09' models?
nickfxt is offline   Reply With Quote
Old 04-17-2009, 06:56 AM   #319
dingobite
Member#: 82391
08 OBP Sti
td06SL2, 20g 299hp 300tq
Thread needs update of DeadBolt Turbos which is Out of Business looks like its for good !
dingobite is offline   Reply With Quote
Old 04-26-2009, 07:40 AM   #320
payway87
Member#: 209710
Hi!
I'm totally new! I'm from Italy and I'm desperate.
I'm searching for information about a turbocharger ihi vf38 (or vf44 or vf45).
I can't understand what's the difference between vf38 and vf44 and vf45.
Compressor wheel ind/exd are different? Turbine wheel ind/exd?
Journal bearing? Or ball bearing? Someone say that they're ball bearing, but on ebay and others I see that they're journal bearing..
Thank you very much!
Some ebay link to understand:
vf38
http://cgi.ebay.co.uk/IHI-RHF5H-VF38...4.c0.m14.l1262
vf44
http://cgi.ebay.com/IHI-RHF5H-VF44-T...3286.m63.l1177
vf45
http://cgi.ebay.it/IHI-RHF5H-VF45-Tw...3286.m63.l1177
In the second link they say that vf 44 replace VF38 VF45 and VF47. So vf47 is very similar to vf38, vf44 and vf45 too?
Sorry for my bad English, but I'm really going mad about all this VF twin scroll turbochargers.
payway87 is offline   Reply With Quote
Old 04-30-2009, 10:25 PM   #321
bgh831
Member#: 112316
2003 WRX
08V Blue Black Mica
How about adding Bloush TD04-19T. Be curious to see some info...
bgh831 is offline   Reply With Quote
Old 05-02-2009, 02:17 PM   #322
heeb101
Member#: 203549
2005 WRX STi
RALLY BLUE
Thanks for the info!!!! Great write up!!!!
heeb101 is offline   Reply With Quote
Old 05-04-2009, 01:18 AM   #323
x-techno-x
Member#: 197229
2006 impreza wrx
nice write up. now you can add this one:
Forced Performance - 68HTA (Bolt on)
FP's newest turbo is the FP 68HTA™Turbocharger for the Subaru STi/WRX unit which out flows both the E316g and 18g wheels and allows for higher PR operation without increased compressor outlet temperatures like the existing 16g and 18g wheels. Mass flow is increased to a whopping 47lb/min which is several lb/min greater than either the E316g or the 18g wheels are capable of. Rapid spool and large torque numbers are guaranteed by the TD05H turbine section.
These units are constructed from Genuine MHI 16g turbochargers which are reconfigured to 68HTA specs by Forced Performance.
x-techno-x is offline   Reply With Quote
Old 05-05-2009, 03:19 PM   #324
BbugWag
Member#: 205629
'04 v7 207 WRX
Dull version of JBP
all this info, almost over whelming. ITS AWESOME
BbugWag is offline   Reply With Quote
Old 05-05-2009, 06:15 PM   #325
ramair18954
Member#: 28308
03 td-06 wrx ra-c
Platinum
agreed
ramair18954 is offline   Reply With Quote
Subaru Wagons listed first on 10 Used Cars that Seem to Last Forever pepperjack News & Rumors 74 07-14-2015 07:07 AM
is there a Subaru turbo list? housedj General Community 8 03-18-2009 12:48 PM
subaru forum list 949 General Community 10 11-01-2005 11:32 PM
Subaru wish list carrera News & Rumors 9 06-19-2002 08:45 PM
('93-'01) Subaru Mailing List rubadub Impreza Forum 3 08-18-2001 02:40 PM
