Old 04-16-2009, 06:54 PM   #1
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
OMGHi2U Stock Header VS. Borla UEL
I am wondering which one flows better? I know the diameter of the borla is bigger, but since the stock is almost EL, would it flow better? it just kinda popped into my head on my way home from work today. It seems like I have lost some down low power on my RS, but I can't think of why?
I have Torque grind cams from Delta
Borla UEL headers
STi Mid-pipe
Devil Axle-back
Any thoughts?
Gr3en is offline   Reply With Quote
Old 04-16-2009, 07:06 PM   #2
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
I also have borla uel's on my 07 2.5i. They do indeed flow better than the stock el's. But all past arguments say that the aftermarket el's flow better than the aftermarket uel's........ but you dont get that sexy boxer rumble from the el's like you do with our borla's.
07ImprezaMB is offline   Reply With Quote
Old 04-16-2009, 09:59 PM   #3
Ogden
Member#: 1748
'09 Outback Sport
OBP over DGM
Borla UEL headers
STi Mid-pipe
Devil Axle-back
Any thoughts?
What's the overall diameter of the piping in the exhaust?
It seems like when the piping gets too big for the 2.5i, it costs you on the low end. I think that most folks say 2.25" to 2.5" is about the size you want. Anything bigger and it starts to cost you in the low end.
Ogden is offline   Reply With Quote
Old 04-17-2009, 02:34 AM   #4
07ImprezaMB
Member#: 153861
2008 WRX hatch
WR Blue
MY borla header and catpipe are 2.25 and i think my catback is some weird number like 2.36??? lol i dont know but its made for the 2.5i/2.5rs.
Old 04-17-2009, 02:37 AM   #5
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Platinum Silver Metallic
Maybe the OP can benefit from some open source tuning.
EdHilario is offline   Reply With Quote
Old 04-17-2009, 09:32 AM   #6
Dammod
Member#: 208881
Do you all have a 2 small pipes coming from the engine on either side (4 all in all) then further on it joins to two and then 1? I got custom headers made but in only gets to 2.5" when in gets to the main zorst. the 4 to 2 and the 2 to 1 pipes are alot thinner then the main zorst. Is this right?
Sorry for the hi jack.
Dammod is offline   Reply With Quote
Old 04-17-2009, 09:36 AM   #7
Gr3en
Member#: 160991
05 Corn Burner
Dirt Silver?
So.. Which do you think will flow better? The UEL is a lot longer and is a bigger diameter, but the stock is more direct to the cat?
OEM vs Borla UEL header - acoustics Bluefoton Normally Aspirated Powertrain 60 02-11-2010 06:12 PM
P+P Stock Headers Vs Aftermarket Rokkit Factory 2.0L Turbo Powertrain 295 04-09-2007 03:16 PM
wrap on stock headers vs aftermarket w/ wrap? OvrClkdPmp Factory 2.0L Turbo Powertrain 2 12-31-2005 12:52 PM
Techworks Header vs Borla Kevin Thomas Normally Aspirated Powertrain 105 06-12-2005 11:56 PM
Gruppe-S header vs Borla spankaveli Factory 2.0L Turbo Powertrain 3 08-31-2004 10:41 PM
Message Board Statistics All times are GMT -4. The time now is 03:22 PM.
