Welcome to the North American Subaru Impreza Owners Club Friday March 27, 2015
Old 04-22-2009, 05:27 PM   #1
g_$
Member#: 203813
Default installing front and rear door speakers on my 05 WRX
I got pioneer speakers im trying to install in my car, when i took the doors apart i sow that the old speakers have a harness, and they are mounted. How do i get this mount. Is there an easy and CHEAP why to install these speakers.
g_$ is offline   Reply With Quote
Old 04-22-2009, 06:22 PM   #2
kevin85193
Member#: 145900
2003 16g wagon sold
05 SWP LGT
Kartboy Spacers
http://www.allwheelengineering.com/b...y_class=KB-010
Cut the wiring harness off and solder or tape new leads on
kevin85193 is offline   Reply With Quote
Old 04-22-2009, 06:43 PM   #3
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Originally Posted by kevin85193 View Post
Kartboy Spacers
Kartboy spacers won't work with all speakers, make sure you're pointing him towards ones that fit. Since we don't know exactly what model speakers he has, I wouldn't be so assumptive .
Also, don't tape the wires, that's messy and unreliable. If you're new to this game, then soldering isn't gonna happen, just invest in some decent butt connectors or crimp caps (a good set of crimpers is key as well, those cheapos are crap) and tie in the new wires.
Do you know how to test the polarity to make sure the speakers are wired up correctly? If they aren't, you'll have crappy sound, zero bass, and your ears will be angry.
Audiosavvy is offline   Reply With Quote
Old 04-22-2009, 10:06 PM   #4
WiGGitY
Member#: 201988
2002 2.5 TS
If U bought Pioneer spks they should have come with spkr wire in the box. Cut the factory plugs off & use but connectors (crimps) to attach the after market wires to the FACT. ones. The Fact. wire with the Bright color ie. Red, Green. is your power (the large pin on your pioneers) and the LT. colors are groung (grey, blk.) The small pin on the Pioneers.
WiGGitY is offline   Reply With Quote
Old 04-23-2009, 09:30 AM   #5
Rodwrx23
Member#: 170948
How do you do this with a DMM? The - one to the chassis and the + one to each wire? Then look for a + or - value?
Rodwrx23 is offline   Reply With Quote
Old 04-23-2009, 09:44 AM   #6
g_$
Member#: 203813
yeah i figured you could cut the wire and jus match them up... but thought it deff can kill the quility.. does anyone kno if these away to mess with the stock mounts to make them work..cause i dont want to buy ones to find out they dont fit.. i got pioneer 6.5 speakers..
Old 04-23-2009, 11:32 AM   #7
Uncanny
Member#: 133012
Obsidian Black Pearl
You can modify the stock "mounts" by cutting out the stock speakers that are built into them. Most people don't do this because then they can never return the car back to stock (you are literally hacking apart the stock speakers).
Uncanny is offline   Reply With Quote
Old 04-23-2009, 12:29 PM   #8
g_$
Member#: 203813
im not to worried about goin back to the stock speakers..i got the speakers real cheap...thanks circuit city!!! but if i end up jus usin the stock mount and takin out the stock speakers..what do i do jus screw them into the side wall of the mount.. you dont think it will splitthe mount?
front and rear strut bars on my rs (yay) SnowSurfer Member's Car Gallery 16 05-09-2006 05:01 PM
what size are the front door speakers for an 05 wrx? a1autosports Car Audio, Video & Security 5 04-29-2006 06:20 PM
2006 wrx Front and Rear door speakers mtags335 Car Audio, Video & Security 3 03-09-2006 05:27 AM
Will 06 WRX Front and Rear Calipers fit on my 05 WRX? mrtrex Brakes, Steering & Suspension 2 01-06-2006 09:04 PM
What is the size of the front and rear sway bar on a 05 wrx, and should I up grade? mrtrex Brakes, Steering & Suspension 4 08-14-2005 11:24 PM
