Old 04-26-2009, 09:33 PM   #1
binkman88
Member#: 134093
Unhappy rpm drop after new wires
so i installed new plugs a month ago and then had to order some wires, I threw on the new wires today and all is well except if i tap the gas my rpms drop to nearly nothing then go back up. This happens every time I stop. All the wires are connected tightly>? This also happened when i just put plugs in but then went away. Any suggestion what it could be?
2005 rs
new rallitek wires installed
binkman88 is offline   Reply With Quote
Old 04-26-2009, 10:51 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
you tap the throttle every time you stop?
yarrgh is offline   Reply With Quote
Old 04-27-2009, 12:01 AM   #3
binkman88
Member#: 134093
uh no? the rpms just go down when i DO tap it
Old 04-29-2009, 12:40 AM   #4
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
i tap the throttle everytime i stop . you dont?
less wear on the clutch when engaging it .
watchunglava is offline   Reply With Quote
Old 04-29-2009, 12:42 AM   #5
watchunglava
Member#: 168862
thats a wierd situation though . sounds like you crossed the wires up or something .
try some dielectrode grease as well .
Old 04-29-2009, 05:31 PM   #6
05RSnazzy
Member#: 173007
2005 2.5RS...AW
05RS-RIP...avenged by AW!
At night time, open up your hood while the car is started, and see if the wires are arcing. I had this problem on my old Jetta, it was like frankenstein **** in there man!
EDIT: oh this was after aftermarket wires as well, i will forevermore use oem wires for now on
05RSnazzy is offline   Reply With Quote
Old 04-29-2009, 05:35 PM   #7
funky monk
Member#: 143094
08 LGT
DBM
I had this issue when I installed a grounding kit. It'll eventually go away, the ECU has to reset and relearn timing. Should clear up after a 50 miles or so.
funky monk is offline   Reply With Quote
Old 04-29-2009, 11:57 PM   #8
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
I don't see what relearning timing has to do with plugs, wires and grounding kits.
I'm going with rechecking the wiring.
formula91 is offline   Reply With Quote
99 2.5 rs clunking sound when rpms drop from 2700 rpm HELP!! s4bones Normally Aspirated Powertrain 0 05-27-2008 05:48 PM
RPMs increase then drop after accelerating... is this normal? tibor75 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-15-2007 08:38 PM
RPM Drop after small rev Seke631 Service & Maintenance 1 03-08-2003 09:30 PM
RPMs drop when thottle is pressed imprez25 Normally Aspirated Powertrain 5 04-04-2002 09:27 PM
Installed Cobb CAI, rpm drop when shifting? tymax Normally Aspirated Powertrain 5 03-22-2002 04:09 PM
