Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 04-27-2009, 04:54 AM   #1
route69wrx
Member#: 111046
1996 STiL wagon
2002 MBP bugeye
Question v4 sti ej20k valves question
i have a set of v4 sti heads that are being rebuilt and i was told i need 4 intake and 4 exhaust valves. i got a price from a dealer in japan of $550 for the valves, not including tax or shipping. i cant afford to drop $1100 on new valves, so i need an alternative.
my engine came from a gc8e4ed model, engine code is ej20kdw7pr.
i have been told that ej25d valves will work and ive been told that they wont, something about shim over bucket vs shim under bucket.
i have a complete ej25 dohc heads out of a 98 rs that i can pull valves from, or i can have new custom valves made for $$$.
can somebody clear this matter up so i can get on with putting my engine back together and finally get my swap done?
thanks!!!
route69wrx is offline   Reply With Quote
Old 04-27-2009, 05:10 AM   #2
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
Why not remove valves from the EJ25D and compare them? If the length is OK they will fit. However, the EJ20K valves are hollow (intakes) and sodium filled (exhaust).
Have you tried japanparts.com?
Marnix is offline   Reply With Quote
Old 04-27-2009, 05:27 AM   #3
route69wrx
Member#: 111046
1996 STiL wagon
2002 MBP bugeye
i just looked on japanparts.com, the intakes are $447 for a full set and the exhaust are $483 and thats without shipping.
i think im going to try the ej25 valves. is the length all thats going to matter though or is the shim bucket (over vs under) being a different type going to matter?
Old 04-27-2009, 10:56 AM   #4
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
You can get new exhaust valves (13202AA330) here in Europe at the dealer, they're expensive at 75 Euros excl. VAT each. No idea why intakes can't be ordered.
Old 04-27-2009, 11:54 AM   #5
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Yes, this is going to matter. Another member recently encountered this same problem. He had shim under bucket heads and his builder ordered Ej25D valves and they were too short.
Old 04-27-2009, 12:25 PM   #6
linsavy
Member#: 11620
1997 GF4-STiV3 clone
As I said I am using the EJ25D intake valves in STi V3 Type R heads. I am boosting 21psi no problems. They have only been in there for about 5k kms so far though. I would think that the exhaust valves would get a lot hotter, so you are likely best to go with the pricey ones.
linsavy is offline   Reply With Quote
Old 04-27-2009, 02:21 PM   #7
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Mind you, the EJ25D valves are identical to the valves which are used in the EJ20G up to 240 hp. Those engines have been tuned to around 300 hp (crank) without any issues.
Old 04-30-2009, 03:06 PM   #8
kingsubi
Member#: 19239
We ordered supertech valves.
There is no USDM available part from Subaru or Ferrea that replaces the EJ20K STI shim under bucket valve.
kingsubi is offline   Reply With Quote
Old 04-30-2009, 03:30 PM   #9
Rei_Akira
Scooby Scammer- Do Not Buy From User
Member#: 194555
1997 GC8 coup
green
how much did those run you? also benefits of the supertech ones over stock (are they oversized or anything?)
Rei_Akira is offline   Reply With Quote
Old 04-30-2009, 03:55 PM   #10
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
You could use shimless buckets from the EZ30R engine, they will work.
Old 04-30-2009, 04:28 PM   #11
route69wrx
Member#: 111046
1996 STiL wagon
2002 MBP bugeye
one big difference is in the price but im not sure whether they are going to be any better or worse. the supertech valves should be around $320, while the oem valves were about $950 before shipping/taxes from japanparts.com.
james, did they finally give you a total on the whole rebuild?
Old 04-30-2009, 06:16 PM   #12
kingsubi
Member#: 19239
You could convert to a shimless design but it ends up being just as expensive (??) and more downtime.
Supertech make a quality SS valve and manufacturing time is next to nothing when compared to having to do a valve job from scratch.
Old 07-13-2009, 10:15 AM   #13
RJSP
Member#: 170905
1998 WRX STi Type RA
Feather white
Does anyone have the part # for the Supertech valeves that replace the EJ20K Ver4 Sti valves?
RJSP is offline   Reply With Quote
Old 07-13-2009, 03:19 PM   #14
route69wrx
Member#: 111046
1996 STiL wagon
2002 MBP bugeye
they are special order, i believe they are standard sti valves that are machined down to fit the 20k. pm kingsubi, he was the one that deal with supertech and ordered the parts for me.
Old 08-07-2009, 04:41 PM   #15
RJSP
Member#: 170905
Feather white
Default Supertech valves: Part numbers
I wanted to share that I bought the following Superetch Valves that work with the V3 - V4 JDM STi heads:
Exhaust: SEVI - 1016 (Inconel) price $33 eachIntake: SIVN - 1016 (Nitrided) price $ 22 eachThey are made for the 97 - 98? Subaru EJ25 2.5Lts, I was able to get the part number from ZEN Performance in the UK, they used to sell them as V3 - V4 Supertech valves. If you ask Supertech directly for V3 - V4 JDM STi valves they might tell you that they donīt have them, sothe part numbers are realy helpful.
Old 08-07-2009, 04:49 PM   #16
ASF
Member#: 218500
1997 OBS
Green
Get measurements on the valves, stem diameter, head diameter and length, then refer to Supertech's catalog.
ASF is offline   Reply With Quote
Old 08-09-2009, 02:08 PM   #17
rivman05
Member#: 159986
1994 Acura Integra
Milano Red
Hey guys,
Im just wondering, whats all involved in the shimless conversion? If at all possible Id like to do it. I have some 20k STI heads that I have springs and keepers and cams for, but no valves. Since I have everything apart I would like to go shim less since no matter what Im going to spend the cash anyway. Can anyone point me in a good direction? I know that the bucket dimensions and thickness need to be used, but since I have neither, does it really matter? If it does, can anyone post them?
Gabe
rivman05 is offline   Reply With Quote
Old 08-09-2009, 03:13 PM   #18
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
Use Supertech valves for a EJ25 engine, length should be around 105 mm (checked them last week). You can go shimless using the buckets of a EZ30R H6 engine. Measure valve clearances so you know what buckets to order.
EJ20K V4 STI heads + EJ257 US STI SB any issues? keirnna Built Motor Discussion 5 07-12-2015 12:38 AM
FT: v4 STI EJ20K ECU for v4 WRX ECU martystoked 1993 - 2001 Impreza Specific Parts 12 07-27-2009 09:04 AM
V4 STi stock egt question fishheadback Pre-2002 Factory Turbo Powertrain 3 05-30-2008 12:26 AM
V4 sti ej20k engine value? 40k miles greddy18 Pre-2002 Factory Turbo Powertrain 7 02-08-2008 01:13 PM
STi diverter valve question CasopoliS Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-16-2006 05:49 PM
