Old 05-11-2009, 12:36 PM   #1
GeneralTJI
Member#: 152680
2002 ej22t 2.35 s363
surged aem ems 6spd wagon
Default Holset powered 2.0 makes a couple passes down the track...
Some info/pics/video of my build: General's Homebuilt Holset
The quick run down on my project:
2002 WRX Wagon
Stock motor with just over 170,000 miles (heads have about 80,000)
Homebuilt Custom Rotated Holset setup (HE351)
Turbonetics EWG, ebay FMIC, E85, 07 STi tranny, lots of custom stuff (all piping, exhaust etc.) other mods *check that other thread, or my website: http://www.generaltji.com Car is full weight, full interior including spare.
I ran the car the other night at Bandimere. Elevation is 5900ft (5860 or something like that). It was a pretty decent time to run, but we had some headwind all evening).
I had terrible trouble getting off the line. That track hooks extremely well, but this caused issues for me because I couldn't get any tire spin. Tires at 47psi, LC at 6200. But with the 2.0, big turbo, and light flywheel it wasn't enough for a good launch. Had a best of like a 1.98 (at our other local track I've done some 1.6's, and 1.7's but it's easy to get a little spin there)
Anyway, I should have raised the LC some more, and played with my diff controller but I didn't get very many runs, it was packed.
Ran a best of a 12.3 and had a couple runs where I trapped in the 116.6mph area. I turned the boost up a little tiny bit each run.. but ended up getting my best launch in an earlier run. I need to check the slip but I think my 12.3 was at 114 or 115. I then made some 116mph passes with horrible 60ft's running a couple 12.4's.
I have the power, if this poor motor will hold together I just need 1 clean launch to do something good here! This isn't anything real exciting, but I figured I'd share.
Going to our other track where I do much better 60ft wise in about 2 weeks and we'll see what happens. Thanks for stopping by this post.
GeneralTJI is offline   Reply With Quote
Old 05-11-2009, 12:48 PM   #2
Astartes
Member#: 183813
2006 WRX TR OBP
WRX STi SGM
Grats man! Shoot for those 11s.
Astartes is offline   Reply With Quote
Old 05-11-2009, 01:34 PM   #3
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Nice times!
CKxx is offline   Reply With Quote
Old 05-11-2009, 02:02 PM   #4
cnstman
Member#: 9548
2004 WRX STi
PSM, 10.741 @ 126.29
nice. what day you going to PMI?
cnstman is offline   Reply With Quote
Old 05-11-2009, 02:23 PM   #5
GeneralTJI
Member#: 152680
Planning for the 22nd. First fri night drags will probably be a crowded mess, but I'm going to try anyway
Are you thinking of going Aaron?
Old 05-11-2009, 02:26 PM   #6
evan_impreza
Member#: 115276
04 PSM WRX
FP 16g--UTEC+raided ROM
Nice! Ive been wanting to see more of your build! Keep up the good work man.
evan_impreza is online now   Reply With Quote
Old 05-11-2009, 02:27 PM   #7
cnstman
Member#: 9548
2004 WRX STi
Originally Posted by GeneralTJI View Post
Planning for the 22nd. First fri night drags will probably be a crowded mess.
If I do it will be just to watch. transmission should be getting pulled this week or next for a rebuild, would like to get a few miles on the clutch before I run it.
Old 05-11-2009, 02:31 PM   #8
GeneralTJI
Member#: 152680
Sounds good! I'm anxious to see your car run again... sob gets down
Old 05-11-2009, 03:16 PM   #9
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
man....you should be golden 11's at sea level
Phatron is online now   Reply With Quote
Old 05-11-2009, 05:18 PM   #10
GeneralTJI
Member#: 152680
Thanks guys!
I was hoping this Holset setup could get me an 11.9 and a 117mph trap (on the stock motor). The trap is right there, I could turn up the boost but I'm hoping to sneak in on a high 11 before I blow this 205 apart
Down the road, I'll finish putting together my built cammed motor and see how much power this turbo will make.
I was using the ignition cut LC when I first put my UTEC in.. it builds more boost and would have helped me get off the line. But I had to switch it back to fuel because I blew one of my remflex gaskets apart FFS w/ ign cut. Just a little too violent for those thick (and not very well re-enforced) gaskets
Eventually I'll go all copper exhaust gaskets, both shimless heads (instead of 1 ) , the good motor etc. and switch back to the ignition cut.... it's WAY more fun.
Old 05-11-2009, 05:55 PM   #11
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Very nice. Maybe Ill see ya up there sometime!
project_skyline is offline   Reply With Quote
Old 05-11-2009, 06:55 PM   #12
jason miller
Member#: 158313
Ramflex gaskets are crap. What did you trap on your old t3/t4 setup?
jason miller is offline   Reply With Quote
Old 05-11-2009, 07:09 PM   #13
C J
Member#: 132587
2006 JrTuned STi
E85 GT3582r/10.83@126mph
if you want to trap 117mph you should be deep into the 11s not 11.9x imo.
C J is offline   Reply With Quote
Old 05-11-2009, 07:12 PM   #14
jason miller
Member#: 158313
This is an ej205, not an ej257 with avcs. There have been two recent ej205's run 11.9's, and they were at 117.x and 119.x mph if I remember correctly. Coolrex went 11.6, but at 124.
Old 05-11-2009, 10:09 PM   #15
STi Mikey
Member#: 114631
2007 11.5 @ 118
Stock Turbo Record Holder
2002 WRX Wagon
Wow
Congrats on the motor holding up this long, that is damn impressive man and even more impressive that this project was home built. I know elevation is a killer but trapping 116 can yield mid-high 11 1/4 times.
EDIT: Did you try going through the water box to get some spin out of the tires?
Good luck next day out and congrats again!!
STi Mikey is offline   Reply With Quote
Old 05-12-2009, 01:41 AM   #16
GeneralTJI
Member#: 152680
Yea they are not the greatest. Probably work well on an NA setup.
I trapped a best of 113mph, once. 112 usually.
Getting a good 60ft could potentially bring my ET down a bunch. I was just stating I would be extremely happy to get this setup in the 11's whether it be an 11.99 or better. I need to get out of the hole harder (1.7 would be good enough), but I try not to beat my car and hopefully can avoid breaking the stock 170k axles / rear diff. A lot of 2.5 cars with a heavy flywheel and not so over-sized turbo seem to do some impressive stuff especially in the 1/8! my car seems to be more of a back half car at the moment lol.. with the Holset I picked up 28mph on most of those runs.
Wow
Thank you!!
I didn't try that.. (DUH). I also didnt turn down my spiider diff controller very far (manual controller).. I have no idea what I was thinking while at the track.. just kept raising my LC thinking it would make enough difference
Old 05-12-2009, 11:48 AM   #17
All4bSpinnin
Member#: 99102
08 Corvette Z06
problem Traction?
the 116 trap is a good sign
All4bSpinnin is offline   Reply With Quote
Old 05-12-2009, 11:57 AM   #18
Audiosavvy
Trust me, I'm a scientist
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
116 at Bandimere is MOVING!!! Good job Todd!
Audiosavvy is offline   Reply With Quote
Old 05-12-2009, 07:54 PM   #19
TDagen
Member#: 163648
2002 Wrx,2.5L,HTA86
E85,2007 6mt,No traction
Nice work! That 2.0 just keeps putting out...lol... How are you digging the 07 6mt at the track?
TDagen is offline   Reply With Quote
Old 05-12-2009, 10:37 PM   #20
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
I was one of them,,... It was 11.9 @ 117
117 will get you there on the 5 speed,... maybe its that extra shift thats killing you? ( I am assuming you are shifting into 5th with your 6 ).
Anyhow these are great times! You would be wicked at closer to sea level
jmlaser is offline   Reply With Quote
Old 05-12-2009, 10:49 PM   #21
JSarv
Member#: 163445
l33t *******
12.07@115.9mph-EJ205
No he has an 07 tranny he gets to leave it in 4th until just over 120
Todd - I'll have a v8 6mt in my car in a few weeks and going to go make a pass or two down the 1/8th!
Sweet times - To bad your not at sea level!!!
-Jerod
JSarv is offline   Reply With Quote
Old 05-12-2009, 11:19 PM   #22
jmlaser
Member#: 125529
02 WRX 18G EJ205
-Jerod
Ooo I missed that, Sweet. I forgot about those,... makes me want one!
Old 05-12-2009, 11:23 PM   #23
JSarv
Member#: 163445
l33t *******
I dunno gears are to long for my taste - I'm used to my Honda H with a close ratio trans.. I even hated the 5mt...
I'm a big fan of very long 1st (around 45-50mph) and then keep em close after that...
-jerod
Old 05-13-2009, 02:54 AM   #24
GeneralTJI
Member#: 152680
Thanks for the comments guys
It's working out well. I'm just sneaking through the lights before I hit the rev limiter (7350)
I won't be able to trap much higher though without making a shift.. but I have a set of cams for my motor I'm putting together which should get a couple hundred more usable rpm's out of it in 4th.. so hopefully that will let me keep it in 4th even then. So basically it's pretty well geared for the sub 120 traps w/o cams.
EDIT Check out what I built tonight. (4" intake piping, huge AMSOIL fender filter) and the v-band cutout (other side of v-band is a plug).. oh these 11's are going to be mine! (maybe, if it doesn't sh$tcan that is) ... actually these mods probably won't make any noticeable difference right now....
Old 05-19-2009, 09:56 AM   #25
CoolRex
Member#: 85813
2002 E46 M3
2006 RC51
At that sea level you got 11's man easily. Do what I do....go through the water box. Get to the line back up and mini launch to sling the heavy water off. Then give er all ya got! You want those tires to spin but I understand with a big turbo it's hard!
CoolRex is offline   Reply With Quote
Couple subbys at the track e2blade Member's Car Gallery 12 02-09-2010 01:00 PM
A couple pics from the track in my 06 bhhamblin Member's Car Gallery 31 03-14-2008 01:24 PM
looking to get the timebomb faster down the track... OMG_WTF Factory 2.5L Turbo Powertrain 47 11-29-2007 04:34 PM
06-07 Forester XT 5mt power handling limits? And a couple Qs about the recent 5MTs Davenow Transmission (AT/MT) & Driveline 12 05-02-2007 11:30 PM
('93-'01) Saw a couple WRXs at the track last night TTA89 Impreza Forum 3 08-09-2001 03:50 PM
Message Board Statistics All times are GMT -4. The time now is 05:01 PM.
