Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 05-13-2009, 07:30 PM   #1
hondahata
Member#: 64905
2004 WRX/STi
Rally Blue
Default Lingenfelter Camaro
[quote]
You didn't think that Hennessey was the only big-name tuner meddling with the new Camaro did you? Give a big honky-tonk, mullet-swaying welcome to the 800 HP, turbocharged LS7-swapped Lingenfelter Camaro SS.
Not pleased with recently taking the back seat to Hennessey Motorsport in the LS-tuning circle, Lingenfelter has upped the ante by beginning development on its very own version of the 2010 Chevy Camaro SS. Their plan is to release five distinct power packages ranging from a supercharged 550-horsepower model all the way up to a monster 800-horsepower, turbocharged, LS7-swapped version that we're going to talk about a little more.800-horsepower and 800 lb-ft of torque. Those are big numbers no matter who you speak with and Lingenfelter knows it. The first order of business to transform the already stout 2010 Camaro SS into a fire-breathing beast is a removal of the stock 426-horsepower 6.2-liter LS3 V8 and fill the empty hole under the hood with a Corvette Z06-sourced, 7.0-liter LS7. Now the LS7 already produces 505-horsepower, which would do the Camaro just fine, but Lingenfelter decided to go a little crazy (How 'bout a magic trick?) by taking the aluminum-blocked LS7 and slapping a pair of Garrett oil lubricated and liquid cooled ball bearing snails onto it. But we all know that adding big turbos doesn't necessarily get you very far, especially when you're pushing a big round number like 800-horsepower.
In addition, Lingenfelter has upgraded the LS7 with a Callies 4340 forged steel crankshaft with a 4.000-inch stroke, CNC ported LS7 heads, a multi-angle valve job, stainless steel intake valves, heavy-duty Inconnel exhaust valves, Competition cams with dual valve springs and titanium retainers, JE forged aluminum pistons, Manley 4340 forged steel 'I' beam conrods, a higher capacity fuel system with larger fuel injectors, Lingenfelter 304 stainless steel 4-to-1 headers and a Corsa stainless steel cat back exhaust to round out the mix. All of this is backed by a 3-year/36,000 mile warranty. Hot damn!
Not content with just offering engine packages, Lingenfelter has gone the extra mile in creating an aggressive body kit that includes a large front fascia lip spoiler, revised rockers, custom grille, custom hood with air extractors, a revised rear fascia diffuser with four exhaust pipes, rear tail lamp cover panel and a rear deck spoiler.
Lingenfelter is quite ambitious with its 2010 Camaro SS package, but apparently not ambitious enough to release a price or an exact release date, though you can purchase the styling package as early as this summer.
Lingenfelter 2010 Camaro Engine Packages:
550 BHP / 550 lbs-ft of torque
When Lingenfelter installs the Magnuson supercharger system we upgrade many components from the base Magnuson kit for better performance and reliability. Each car also gets Lingenfelter PCM programming that lets you benefit from the experience LPE has gained from installing hundreds supercharger systems since 2001 when we first started offering the Magnuson superchargers as a package.
Package includes:
- TVS2300 intercooled supercharger system- silver painted finish
- Based on OEM Eaton supercharger unit
- Properly sized fuel injectors
- Fuel system upgrades
- 160 Degree thermostat
- Boost bypass controller
- Lingenfelter High Flow Air Intake
- Professional installation, testing and calibration
- Corsa stainless steel cat back exhaust
- Chassis dyno report before & after installation
- Excellent drivability, highway mileage not adversely affected
- Lingenfelter 3 year/ 36,000 mile warranty
- Lingenfelter fender badges
- Lingenfelter certificate of authenticity
570 BHP / 570 lbs-ft of torque
Package includes:
650 BHP / 600 lbs-ft of torque
- Engine removal, disassembly and inspection
- Lingenfelter CNC porting of LS3 cylinder heads
- Lingenfelter multi-angle valve job, cc, surfacing & assembly
- Stainless steel intake valves and heavy duty Inconnel exhaust valves
- Competition Cams dual valve springs, titanium spring retainers, 10 degree locks
- JE Forged aluminum pistons and tool steel pins
- Manley 4340 forged steel "I" beam connecting rods
- Computer balanced LS7 forged steel crankshaft & rotating assembly
- File fit rings, heavy duty rod & main bearings, head gaskets, head bolts
- Fuel system upgrades and properly sized fuel injectors
- Ported & polished LS3 throttle body
- Boost by pass system
- Professional engine installation, testing & tuning
750 BHP / 685 lbs-ft of torque
- Chevrolet LS7 7.0 L aluminum block
- Chevrolet LS7 aluminum heads
- Chevrolet LS7 titanium connecting rods
- Chevrolet LS7 forged steel crankshaft - 4.000" stroke
- Heavy duty inconnel exhaust valves
- Professional assembly and blueprinting of engine
800 BHP 800 lbs-ft of torque
- Callies 4340 forged steel crankshaft - 4.000" stroke
- Lingenfelter CNC porting of LS7 cylinder heads
- Computer balanced crankshaft & rotating assembly
- Properly sized fuel injectors and high capacity fuel system
- Twin Garrett oil lubricated & liquid cooled true ball bearing turbochargers
- Lingenfelter turbo compressor housings & exhaust housings with integral waste gates
- Lingenfelter super high efficiency air to air charge coolers
- Lingenfelter 304 Stainless steel 4 into 1 custom exhaust manifolds & turbo outlets
- Lingenfelter belt driven turbocharger scavenge pump & turbo oil drain reservoir
- Lingenfelter custom molded silicone air ducts
- Two S&B 360 degree conical air filters
- Stainless steel / ceramic heat shields & stainless clamps
- Port matched LS7 intake manifold
Lingenfelter 2010 Camaro Body Kit
Lingenfelter will be offering body enhancements for the new 2010 Camaro later this summer.
Enhancement package will include:
Front Fascia & Rocker Extension
Front Splitter
Grille Bar Insert with Wire Mesh Texture
Hood with Air Extractors
Rear Deck Lip Spoiler
Rear Fascia Extension with Exhaust Tips
Rear Tail Lamp Panel
hondahata is offline   Reply With Quote
Old 05-13-2009, 07:33 PM   #2
hondahata
Member#: 64905
2004 WRX/STi
Rally Blue
Lord, thats why I leave this to Avanti R5. Moderator could you please move it.
Old 05-13-2009, 08:33 PM   #3
Choose
Member#: 7247
Platinum Silver Metallic
Ibtl....
Choose is offline   Reply With Quote
Old 05-13-2009, 11:16 PM   #4
wronskij
Member#: 186795
What Does This Have To Do With Subaru?
wronskij is offline   Reply With Quote
Old 05-14-2009, 02:14 AM   #5
desertaero
Member#: 88954
'05 Saab 92X Spec C
desert silver metallic
Nothing...that's why its posted in non-subaru news and rumors...?
desertaero is offline   Reply With Quote
Old 05-14-2009, 03:07 AM   #6
phoenix96
Member#: 14148
2006 Legacy GT Ltd
2011 Outback 3.6R Ltd
It wasn't. It got moved.
phoenix96 is offline   Reply With Quote
Old 05-14-2009, 09:11 AM   #7
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
I'll pass... I'm waiting for the 1200 BHP and 1250 lbs-ft of torque...
Mariano is offline   Reply With Quote
Old 05-14-2009, 09:44 AM   #8
sub9lulu
Member#: 36946
whatever it is, its better than Hennessey
sub9lulu is offline   Reply With Quote
Old 05-14-2009, 09:45 AM   #9
WhiteKnightSTi
Member#: 169250
2001 Schweizer 300CB
(wirlybird)
I'll take one is RS trim without all the ricey bodywork, sleepers FTW.
WhiteKnightSTi is offline   Reply With Quote
Old 05-14-2009, 10:39 AM   #10
design1stcode2nd
Member#: 112178
Are drag radials included?
design1stcode2nd is offline   Reply With Quote
Old 05-14-2009, 11:18 AM   #11
E. Nick
Member#: 8489
Mac MP4, Vip ACR,
BDR Cobra, M5, X5, F350
Why remove the NA LS7 from a light car, add boost, and put it into a heavy one? I would think the CTS-V motor would be an easier and a cheaper starting point if going for big power. Maggied LS3 should already run with a KB GT500, no?
E. Nick is offline   Reply With Quote
Old 05-14-2009, 11:30 AM   #12
Not-EWRX
Member#: 158043
2013 Wrx Hatch
No, but it comes with free doughnuts.
Not-EWRX is offline   Reply With Quote
Old 05-14-2009, 11:31 AM   #13
scprs
Member#: 172359
2005 STi
damn thats sick!!! but bet the price tag isn't i wonder thoug any info on that?
scprs is offline   Reply With Quote
Old 05-15-2009, 02:26 AM   #14
hondahata
Member#: 64905
2004 WRX/STi
Rally Blue
Old 05-15-2009, 03:28 AM   #15
masson
Member#: 177145
$64,995.00 for 800 hp.
masson is offline   Reply With Quote
Old 05-15-2009, 03:56 PM   #16
PikkaGTR
Member#: 179940
2007 Sti
that's not a bad price for the power level
BUT it is still RWD and GOBS of tq don't mix
bet it's fun sideways
PikkaGTR is offline   Reply With Quote
Old 05-15-2009, 04:00 PM   #17
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I'll take combo number 5 please....
jigga is offline   Reply With Quote
Old 05-16-2009, 06:37 PM   #18
phlegmon
Member#: 26223
2016 Focus RS
1992 NSX twin turbo
Ummm, yeah.... That's $65,000 PLUS THE COST OF A NEW CAMARO. You're talking about a $100,000+ camaro Also, it doesn't mention whether that includes labor (it does say it take 8-10 weeks of labor for the conversion). Don't forget about the costs for the upgraded transmission, differential and brakes!!!
The Z06 1000HP conversion is $87,000 PLUS the cost of the Z06
phlegmon is offline   Reply With Quote
Old 05-17-2009, 09:50 PM   #19
hondahata
Member#: 64905
2004 WRX/STi
Rally Blue
Def ridiculous, but that price includes everything I would think?
Old 05-17-2009, 11:19 PM   #20
Layman
Member#: 3717
2011 Swagger Wagon
bikes with pedals
Layman is offline   Reply With Quote
Old 05-18-2009, 11:13 AM   #21
mhoward1
Member#: 9481
1832 Steam Buggy
Wood
someone better tell the Rolex and Lemans people that.
mhoward1 is offline   Reply With Quote
VR Chevrolet Camaro (2010): the UK's Camaro AVANTI R5 Non-Subaru News & Rumors 32 11-09-2009 02:12 PM
LT1 Camaro, LS1 Camaro and a WRX tubular031 General Community 116 10-14-2005 07:21 PM
does anyone remember the chevy camaro commercial with all the camaros?where can find? bobturismo Off-Topic 0 01-02-2004 02:46 AM
John Lingenfelter in Serious crash Sirkbac Off-Topic 16 10-29-2002 06:00 AM
John Lingenfelter @ NED? V6TurboTA New England Impreza Club Forum -- NESIC 25 10-06-2002 09:31 PM
