Old 05-22-2009, 12:33 AM   #1
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Default ECU Help with Unnecessary Wiring
Not really sure if this is where i should post, but here it goes.
Im gutting my car and trying to remove all the unnecessary wiring.
I was wondering if anyone had any tips on which wires i could remove without taking away any of the unnecessary wiring.
Figured shops with time attack cars would be the most help which is why i posted here.
My car is a 2002 WRX.
Ron
Old 05-22-2009, 01:22 AM   #2
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Ron
Not positive, but maybe you should go over to IWSTI and ask anorexicsti. His car weighs 26XX with full interior, im sure anything not needed was removed.
STi Mikey is offline   Reply With Quote
Old 05-22-2009, 05:27 AM   #3
Phatron
Member#: 36033
CEO PhatBottiTuning
hmmm, i dont think he will be much help. he still has full interior. my car is gutted, no dash.
basically what im looking for is, "what wires can i pull outta the ecu and still have all my driving functions"
Old 05-22-2009, 07:50 AM   #4
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Get yourself the wiring diagrams from the factory service manual. Definitely don't cut any wires without looking at that first, especially wires that go to the ecu.
boost junkie is offline   Reply With Quote
Old 05-22-2009, 11:54 AM   #5
MasterKwan
Member#: 98961
2003 WRX
Dunk did this. At best, you're going to knock no more than 20 lbs out of the car though. I question whether it's worth the effort. I have a WRX harness sitting in a box. I've carted it around. No more than 40lbs for the whole thing including all the little control boxes for DRL, Power locks and the like. The hassle factor is high and the chance of cutting the wrong wire is very high because subaru uses the same color codes for multiple circuits.
MasterKwan is offline   Reply With Quote
Old 05-22-2009, 12:14 PM   #6
Phatron
Member#: 36033
CEO PhatBottiTuning
but 10 little 20 lb things that may not seem like they're worth the effort add up to 200 lbs.
i have been questioning cutting doors, cutting wires, taking out the dash, cutting trunk supports.... i finally said F*it im going all the way.
sheet metal dash and sheet metal door cards and 2 CF seats.
i wont just start cutting. im not that retarded yet.
Old 05-23-2009, 11:01 PM   #7
555ideways
Member#: 36652
Go through the wiring diagrams and highlight what wires you need to keep and those you don't. Go through each connector and de-pin everything. Throw away what wires you want gone and wrap and shrink the wires you want to keep in the harness. Then re pin all the wires back into the connectors. If you are looking for a list of wires to cut from us - you won't find it. Everyone's list of things they need in their race car is different. The rally guys need horns, windows, blinkers. The TA guys need none of that crap - not even headlights.
Someone up there said they have a harness in a box that it ~40lbs... I ripped a complete harness with all junction boxes out of a wrx a few years ago and it was not that light. I could barely carry it it was so awkward and heavy. I would say 55lbs+ for sure. If you want to take it to the next level, go for a PDM and eliminate the fuses and relays. But judging from the question you asked in your first post, you might not be ready for that type of system.
-Paddy
555ideways is offline   Reply With Quote
WTB - for 02 wrx - obdII female connector and ecu plugs with some wiring gto7419 Private 'Wanted' Classifieds 3 08-03-2009 05:44 PM
Help with headlight wiring with pics! jordanderson Electrical & Lighting 6 12-14-2006 08:48 PM
Help with Amp Wiring HELP FAST Black_Rain Tri-State Area Forum 4 09-28-2003 08:30 PM
help with purple wire in blitz fatt tt petawabit Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-30-2002 06:36 PM
Need help with one wire for turbo timer dman918 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-22-2002 05:01 PM
