Old 05-11-2009, 11:10 AM   #1
bnr34rb26dett
Member#: 188424
2012 640WHP STI
Talking Let me see your CB radio/ police scanner setup
hello! im interested in purchasing a CB radio (Uniden 510XL)
but i am interested in what everyone else has and how its installed.
i would love to see the antenna setup also!
thanks.
bnr34rb26dett is offline   Reply With Quote
Old 05-11-2009, 11:51 AM   #2
cMags
Member#: 88668
'05 Outback Sport
5MT - Regal Blue / Grey
Outback Sport
You running a wagon or sedan? That will make all the difference in antenna mounting options. I'll post some pics of my wagon's antenna setup soon.
Where are you thinking of installing the radio itself? This is the biggest problem in my install. Since I RARELY use it, I just keep the radio under the pass. seat and pull it out when I need it, sitting it on the floor or the pass. seat if unoccupied. If you want a permanent install, you may want to get the Cobra WX-75-ST radio - the radio is entirely in the microphone and can be mounted on a hook on the dash somewhere. If I used my radio often enough I would go this route.
cMags is offline   Reply With Quote
Old 05-11-2009, 12:47 PM   #3
bnr34rb26dett
Member#: 188424
2012 640WHP STI
its a sedan.
yea, im installing the radio myself. if the unit is small enough, its going in my 2nd din pocket. if not, mounted on the side with velcro strips.
im not gonna be using the radio often. i just want something small and light..
as far as antenna, im looking to get wislon 500. although i would love to get one of those long antennas sticking out from side of my trunk
Old 05-11-2009, 01:57 PM   #4
cMags
Member#: 88668
'05 Outback Sport
Outback Sport
Ah, in the din pocket will work quite well I'm sure. I just didn't have the space there. As far as the antenna, however, you WILL get scratches/scuffs from a magnetic antenna. There's not a lot of great options, you'll likely have to do something custom. I have seen decent results with long antennas mounted on a low bracket sticking out from under the bumper. But here's what I did on my wagon. I made the black brackets custom to fit the contour of the siderail:
Old 05-11-2009, 02:00 PM   #5
bnr34rb26dett
Member#: 188424
2012 640WHP STI
that looks simply amazing
very clean install.
i might have to go with a long antenna then...
what kind of antenna are you using?
and have you heard of any trunk antenna mount applications??
Old 05-11-2009, 02:19 PM   #6
wrxracer519
Member#: 149890
09 Forester
Green
That does look good. I have an older cb a friend gave me but need an antenna and have been thinking about what to get and where to mount it. I have a wagon so i could make the brackets and stuff.
cMags, what antenna are you using? Thanks.
wrxracer519 is offline   Reply With Quote
Old 05-11-2009, 02:20 PM   #7
cMags
Member#: 88668
'05 Outback Sport
Outback Sport
That's a 2' long Firestik II "tunable-tip" antenna. It has a thumbscrew that allows you to tune the antenna for low SWR rather than needing to cut the antenna like the original Firestik and other antennas. I used Subaru touch-up paint to color match the once-red plastic cover for the tip.
The antenna cable runs along the back and under my spoiler into a hole I drilled under there (you can see this in the 2nd pic). From there it follows the wiring from the tailgate through the rubber tube for stock wires into the headliner, down the D pillar, and along the floor to the pass. seat. I had to install the connector on the outside of the car on bare wire after running it because I didn't want to drill a hole big enough for the connector to pass through. I can't uninstall the wire now without cutting off a connector on one end or the other, not that I have a reason to.
Old 05-11-2009, 02:37 PM   #8
cMags
Member#: 88668
'05 Outback Sport
Outback Sport
As far as other mounting ideas, here's one I saw that might work on both the wagon and sedan. It's from another member on this site who PM'ed me the pics. Drew, if you want me to take these down, just lemme know.
Originally Posted by Yesitsdrew5310
I do not have the WRX wing, and the mount has a lip on it to slip over the metal. There are 4 hex bolts that tighten into the metal for the connection to ground.
You could totaly mount it to the roof rails, but you would NEED to ground it to the chassis. With no ground you will fry your radio. haha.
Here are the photos of the mount:
Old 05-11-2009, 02:45 PM   #9
juSTIn5
Member#: 178777
2006 STi
Ishin, here is my fairly clean setup on my daily driver.
juSTIn5 is offline   Reply With Quote
Old 05-11-2009, 02:55 PM   #10
juSTIn5
Member#: 178777
2006 STi
Just found this in Member's Car Gallery....05 OBP wingless (aka how it would look on your car aka awesome)
Old 05-11-2009, 03:04 PM   #11
bnr34rb26dett
Member#: 188424
2012 640WHP STI
cmags, do you know where i can get that mount drew used?
is that on a wagon?
Old 05-11-2009, 03:25 PM   #12
habitatxskate
Member#: 197537
06 WRX
matte black
cMags why didn't you just use some type of rubber (like an old tube from a bike tire) to keep the metal separate from the roof rack
habitatxskate is offline   Reply With Quote
Old 05-11-2009, 05:50 PM   #13
cMags
Member#: 88668
'05 Outback Sport
Outback Sport
CB antennas need to be grounded - the aluminum teeth on the inside of the bracket dig into the rail to ground it to the chassis. I don't plan on ever selling this car, so I accepted this minor, hidden "damage" to the car.
Old 05-11-2009, 05:58 PM   #14
cMags
Member#: 88668
'05 Outback Sport
Outback Sport
is that on a wagon?
It says right on the side of the mount - Comet RS720. Found one vendor here:
http://www.universal-radio.com/catal...tm/cometx.html
Old 05-11-2009, 06:11 PM   #15
MotorolaBizz
Member#: 119290
2004 WRX 4EAT
Java Black Pearl
That black WRX is member "Noah's" car. I'm looking for something short (need to grab 800mhz trunked signals better). The newer model police Impala's have those little stubby antennas that I like (I know it serves a different purpose though).
MotorolaBizz is offline   Reply With Quote
Old 05-11-2009, 06:16 PM   #16
JavaBot
Member#: 156723
05 crp foresterX
rip 2.0i/2.5rs
I'll post pics soon when I can. Have a sticky antenna like above and then it runs through the pass through down round the seat up to the front drivers side. I have a Quad plug in the glovebox for power. I'll get pics soon, do it you'll love it!
JavaBot is offline   Reply With Quote
Old 05-11-2009, 06:46 PM   #17
hoffmanEstates
Member#: 122043
04 wagonier
psm
i have cb's and whips for sale. my "used to be" setup was a uniden 1001z w/cobra magnetic mount on wagon. tuned the cb and the whip . received 1.1:1 swr. i like how the whip is mounted on the rail just limits your rx/tx to mostly the driver side and little forward
hoffmanEstates is offline   Reply With Quote
Old 05-13-2009, 08:39 AM   #18
bnr34rb26dett
Member#: 188424
2012 640WHP STI
so i ended up purchasing a uniden 520 with lil will antenna.
now, how do people run the wire from the trunk into the interior onto the seats?
is there a hole on the trunk?
Old 05-13-2009, 03:08 PM   #19
cMags
Member#: 88668
'05 Outback Sport
Outback Sport
You might be able to go under the seat backs in the corner by the strut towers and come out near the lower seatbelt connection on either side in the back seats. Then you can run the cable under the door sill to wherever you need it to come out.
Check the A/V section - people will have done a lot of wiring to the trunk for amps/subs.
Old 05-13-2009, 03:10 PM   #20
bnr34rb26dett
Member#: 188424
2012 640WHP STI
good call
Old 05-24-2009, 01:52 PM   #21
bnr34rb26dett
Member#: 188424
2012 640WHP STI
CB radio installed!!
uniden 520XL and lil wil antenna
Old 05-24-2009, 01:59 PM   #22
hoffmanEstates
Member#: 122043
04 wagonier
psm
clean. interior looks like a mobile comand center. i have mine installed where the Ddin was.
Old 05-24-2009, 02:47 PM   #23
subieroo88
Member#: 208392
interesting. What do you need it for though?
subieroo88 is offline   Reply With Quote
Old 05-24-2009, 04:42 PM   #24
DeathSStar
Member#: 202982
Interior, made the vertical mount myself:
VHF Kenwood
VHF Motorola
Cobra WX75ST CB, handheld control head...mentioned elsewhere in this thread.
The VHF radios have NMO antennas on the roof, CB antenna is a glass-mount as I use it for monitoring only. If I was using the CB to talk, I'd have a better antenna.
To the OP: Use a decent CB antenna, or it will not be worth your time to even install it. I prefer to use the Larsen NMO27B antenna, as it can be mounted to most anything easily and it's all black with a skinny .100" whip. You can use any NMO mount...whether permanent, lip mount or magnetic mount...for it and it works very well. I'd stay away from mag mount antennas, as they will scratch the paint and generally don't work too well. The antenna mount needs to be grounded to the chassis in order to work correctly.
Chicken and ROFL's to the guy who said no ground will cause the radio to fry. It will work like **** but the radio won't "fry". I guess all the no-ground plane antennas that are used in the industry must cause a whole lotta damage.
I'm sure this sounds like greek to most of you, so ask questions if you have them. Besides my day job, I do communications and warning equipment installation for some select entities.
DeathSStar is offline   Reply With Quote
Old 05-24-2009, 08:09 PM   #25
Noah
( ͡ ͜ʖ ͡)
Member#: 111510
05 WRX 16 Xtrek
03 SV650S
that's my car!
Noah is offline   Reply With Quote
Let me see your partially painted C/F hoods sedonawrx Member's Car Gallery 3 10-08-2003 11:47 AM
Let me see your skidplate pics!! Slalom RS Interior & Exterior Modification 3 03-26-2003 12:04 PM
Let me see your roof racks on your WRX's Jesperss Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-14-2002 10:09 PM
Let me see your WReX sittin' on aftermarket wheels! EJ205rulezall Member's Car Gallery 8 08-02-2002 04:51 PM
Let me see your DIY headlight mods! wrxlvr Interior & Exterior Modification 24 11-20-2001 06:37 PM
