Welcome to the North American Subaru Impreza Owners Club Sunday May 29, 2016
Old 05-26-2009, 08:00 PM   #1
In2Deep
Member#: 10651
2013 WRX - Silver HB
04STI(sold) 06STI(sold)
Default Tires for an STI in SM - Kumho or Hoosier?
I'm trying to choose between the Kumho Ecsta V710 and the Hoosier A6, unless there is a better choice... thoughts?
Car is a 2006 STI tuned to have 325whp running on 17's.
Suspension is a set of ZZYZX competition coilovers. Whiteline front and rear sway bars etc.
In2Deep is offline   Reply With Quote
Old 05-26-2009, 11:22 PM   #2
Davidss
Member#: 27446
Hoosiers are faster, and hoosier is still doing contingencies
Kuhmos are cheaper, last longer, and (depending on shoulder shape) handle less camber better
Davidss is offline   Reply With Quote
Old 05-26-2009, 11:35 PM   #3
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
I run the hoosier a6 on my sti in SM, mainly because they are the only ones that make a 295/35/17. If Kumho made the 710 in that size, i'd run them locally as they last a whole lot longer than hoosiers. I'd run hoosiers nationally though just for contingency
pignoseSTI is offline   Reply With Quote
Old 05-27-2009, 01:28 AM   #4
In2Deep
Member#: 10651
What size wheel width & offset are you using, and did you have to modify fenders?
Old 05-27-2009, 03:02 AM   #5
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
9.5 et 42 and I had to pull my fenders a lot. Still rub a bit though on hard bumps. Currently I get rubbing in the rear of the trailing arm and inside wheel well. I could run a lower offset but then they would rub the outside fender even more on hard bumps. They really need a 10" wide wheel or more though. I'd recommend a 275, less issues fitting that size
Old 05-27-2009, 07:11 AM   #6
steveRS
Member#: 180430
2008 335i
Hoosier A6
285/18's is the tire to have on any SP or SM Evo/Sti
steveRS is offline   Reply With Quote
Old 05-27-2009, 11:44 AM   #7
In2Deep
Member#: 10651
I thought people stayed away from 18's because of the increased rotational mass due to the weight of the wheel.
Old 05-27-2009, 11:53 AM   #8
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
Sometimes gearing is a bigger factor. 17's tend to be tall
If you concerned with being competetive and have the $$$ for additional sets, Hoosier.
If you can live with being a little slower and want longevity, Kuhmo's.
I've chosen to run hoosiers nationally but picked up a used set of Kuhmo's to tear up locally. The car would be set up differently for each........Kuhmo's seem to be a bit more prone to oversteer. At least on my set-up.
mccanixx is offline   Reply With Quote
Old 05-27-2009, 12:43 PM   #9
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
& 2006 IAG WRX (ForSale!)
+1 I'll be on 18s on my ESP car, but if I can get some 15x10s, I will likely switch to that.
And like others have already said -- A6 will be faster, but won't last as long.
CamaroFS34 is offline   Reply With Quote
Old 05-27-2009, 12:49 PM   #10
Chiketkd
Member#: 71634
In hibernation...
Shawn and I are switching to Hoosiers for the rest of the '09 season. First event on the A6's will be this Sunday @ Fedex.
I hope we find them to be quicker as well.
Chiketkd is offline   Reply With Quote
Old 05-27-2009, 01:31 PM   #11
xcdhridr
Member#: 58865
2004 WRX
99ESP - Drew =)
I had two events on the hoosiers last weekend (4 days total on them) and am feeling more comfortable with them. they are wearing quickly near the shoulders. I was able to finish 6th out of 129 (indexed) on sunday and 2nd (out of 123) monday. Damn chris dorsey killed me on points though.
I think they are faster than the kumhos I was running (same size) and they fit the rims better (18x10.5's).
xcdhridr is offline   Reply With Quote
Old 05-27-2009, 01:38 PM   #12
In2Deep
Member#: 10651
So are you guys recommending 18's over 17's? I'm not too worried about the cost difference, just the performance.
The O.Z. Alleggerita HLT's I was looking at come in both 17 and 18's.
Old 05-27-2009, 03:21 PM   #13
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
For me, the height of the 295/30R18 and the 295/35R17 were the same, and the tires weighed the same (according to Hoosier). So, it came down to the rim weight, and with the rims I was looking at, the 18s were slightly lighter.
Old 05-27-2009, 07:23 PM   #14
In2Deep
Member#: 10651
Which wheel are you referring to?
Old 05-29-2009, 03:22 PM   #15
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Something to consider if you are serious about getting your car down to the minimum weight:
"Weight Adjustments
Cars running tires with a rated width of 275 mm or less on all four
wheels may compete at a minimum weight 200 lbs less than their
calculated weight." - 2009 solo rules appendix A
RS_to_WRX_swap is offline   Reply With Quote
Anyone in the market for an STI in NE please read wrmazin New England Impreza Club Forum -- NESIC 4 05-07-2006 10:28 PM
WTT-18" Tenzo wheel w/ Kumho Ecsta tires for 04 STI BBS's with or without tires/ Pics murrdogg24 Private 'Wanted' Classifieds 3 11-06-2005 12:37 AM
i need brake pads for an sti in charlotte for sunday cdavis03 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 10-10-2004 08:58 PM
Good daily driver tires for an STI. Kokensu South East Region Forum 11 06-08-2004 01:19 PM
