Go Back   NASIOC > NASIOC Classifieds > Vendor 'General Sale' Forum
Closed Thread
Old 03-20-2009, 10:57 AM   #1
201Motorsports
Vendor
Vendor Sales Rating: (37)
Member#: 121809
2003 Evo VIII
Default Cosworth Intake Manifold 2002-2009 - READY TO SHIP @ 201 Motorsports
Cosworth @ 201 Motorsports
After much anticipation, these elusive Cosworth Intake Manifolds for the 2004-2009 STi are ready to ship! Grab one from 201 Motorsports today!
Originally Posted by Cosworth USA
The Cosworth Subaru High Volume Inlet Manifold is cast from aluminium featuring large tapered runners with radiused inlets for improved air flow. Plenum volume has been substantially increased and tuned for power. Engineered for easy installation and is the key to making big power.
Cosworth intake manifold flows an average of 478.5 CFM per runner and the stock manifold flows an average of 421.25 CFM per runner. That is about a 13.5% increase over stock. These numbers were measured at 50 inH2O on our flow bench (some people use 28 inches to measure, but 50 inch is a motorsport standard.
The Cosworth manifold made 12-15 hp above 6000 rpm with no sacrifices in response or low end torque on a stock 300hp engine. Same boost level.
As boost levels are increased over stock levels, the power gains compared to the stock manifold will be even higher.
■ Substantially increased plenum volume
■ Large, tapered runners with radiused inlets
■ Tuned plenum volume and runner length/taper
■ Over 10% increase in flow
■ Integral vacuum manifold for connection of brake booster, boost gauge, MAP sensor, boost controller, etc.
■ Will work with standard or forward mount throttle body configurations
■ Developed, cast, and machined in the USA
■ Stock throttle body location for compatibility with most aftermarket FMIC kits
Price: $999 shipped
__________________
[b]Phil
[COLOR="SeaGreen"]201 Motorsports[/COLOR]
[COLOR="SeaGreen"]Email[/COLOR]
phil[at]201motorsports.com
[center]
[/b][/center]
201Motorsports is offline
Old 03-20-2009, 10:57 AM   #2
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Here's an installed image of this gorgeous product!
__________________
[b]Phil
[center]
[/b][/center]
Old 03-25-2009, 12:35 PM   #3
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Bump it up to the top!
__________________
[b]Phil
[center]
[/b][/center]
Old 03-26-2009, 06:40 PM   #4
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
To the top!
__________________
[b]Phil
[center]
[/b][/center]
Old 03-27-2009, 01:20 PM   #5
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
Bump it up! Still available!
__________________
[b]Phil
[center]
[/b][/center]
Old 04-03-2009, 07:46 PM   #6
ricky05
Member Sales Rating: (4)
Member#: 121910
2002 WRX Wagon
does not fit 02/03? any reason ?
ricky05 is offline
Old 04-03-2009, 07:58 PM   #7
201Motorsports
Vendor
Member#: 121809
2003 Evo VIII
I'm dumb and made a huge, giant typo. Wow. My apologies! The manifold absolutely works with the 02-03.
__________________
[b]Phil
[center]
[/b][/center]
Old 04-05-2009, 08:34 PM   #8
dubya-R-ex
Member Sales Rating: (15)
Member#: 113698
But it does only fit drive by wire and will not work on drive my cable, correct?
If it can work on DBC I might consider it. I suppose it could be re-tapped to work, no?
dubya-R-ex is offline
Old 04-17-2009, 11:00 PM   #9
ricky05
Member#: 121910
2002 WRX Wagon
any comment to previous post? im interested as well!
ricky05 is offline
Old 05-22-2009, 05:28 PM   #10
D Money
Member Sales Rating: (91)
Member#: 109948
. Most famous car
on Nasioc ever. :/
They do not work with drive by cable (02-05 wrx) or else I would ordered one from Phil!
D Money is offline
Old 05-27-2009, 10:24 AM   #11
Fei Jai
Member#: 159829
07 STI
bump for a very nice product.
Fei Jai is offline
Old 05-27-2009, 03:53 PM   #12
Fierysun
Member Sales Rating: (104)
Member#: 82745
2005 Subaru STI
2003 EJ207 S204 Wagon
Anyone created TMIC bracket (only need the one on the driver side) that will work with this manifold?
Also, kind of lame that Cosworth did away with all the mounting bosses (coolant reservoir, ground, inlet holder, and so on).
Fierysun is offline
Closed Thread
