Old 08-22-2007, 11:35 PM   #101
piekarski17
Member#: 131178
05 WRX
FP 18g'd tuned by Jorge
vice grips worked for me
piekarski17 is offline   Reply With Quote
Old 08-23-2007, 12:25 AM   #102
dawiyo
Member#: 87209
07 inline six and
two snails
OP, did you use PVC primer on your design?
dawiyo is offline   Reply With Quote
Old 08-23-2007, 10:23 AM   #103
Mayor McCheese
Member#: 117018
79 Rexor on Dubs
Paws McGillicutty
Anyone have a part number for this cap?
Mayor McCheese is offline   Reply With Quote
Old 08-26-2007, 05:47 AM   #104
GlobalWaste
Member#: 74792
Well... There are 3 hoses attached to the inlet pipe, all with fairly rigid tubing which I was a bit afraid of somehow damaging with vice grips , did all need to be clamped/plugged?
Some say all, others say none.
It's a brilliant idea though, it's stuff like this that keeps me coming back to this forum
GlobalWaste is offline   Reply With Quote
Old 11-20-2008, 03:57 PM   #105
chanders
Member#: 131319
2003 JDM STI
Bumping an good thread.
Do you have to cap out the hard line coming from the BPV to the Turbo inlet pipe too?
chanders is offline   Reply With Quote
Old 11-20-2008, 05:16 PM   #106
41922
Member#: 185307
SILVER
how do you find the leaks?
41922 is offline   Reply With Quote
Old 11-26-2008, 07:38 PM   #107
jtdudley18
Member#: 193828
2004 04 VF34'd WRX
Java Black Pearl
Originally Posted by Vlad View Post
Sorry to resurect, but did this today and got a humming/buzz from the evaporative system purge valve, that small capsule located in front of the intake manifold, by the back of the alternator.
Did anybody else get that?
Also, I did not think the pressure rised above 2 PSI.
What I did not understand is how do you guys prevent air from leaking past the throttle body. Depending where the engine stopped, valves could be open and the air could just end in the exhaust, no?
Please help me out.
Vlad
i heard the same sound. its like a hissing sound. im wasnt sure if it was a leak or what. when you start to fill the tester with air, it wont hold pressure and sounds like its letting alot of it out somewhere. but i cant figure out where
Is it a leak, or just something i'm forgetting to plug up?
jtdudley18 is offline   Reply With Quote
Old 04-03-2009, 07:26 PM   #108
05wrx09
Member#: 204111
2005 WRX
I have a dumb noob question... I want to do this... but how do you see the pressure? I mean, where is a gauge? Or are you doing this with the engine running and with a boost gauge or some type of like ECU or RomRaider logging setup?
Or do you pump air into this setup with a compressor and see where your leaks are with the engine NOT running?
05wrx09 is offline   Reply With Quote
Old 04-03-2009, 09:06 PM   #109
jcbluescooby
Member#: 113012
'04 XT red LIFTED
'15 XV CROSSTREK LIFTED
lol..yeh thats a pretty noob question but i wont bash on u..you pump air into it like you would for your tires..i dont think it would be wise to turn the car on with that on
jcbluescooby is offline   Reply With Quote
Old 04-04-2009, 03:20 AM   #110
05wrx09
Member#: 204111
2005 WRX
Haha thanks for not knocking on me. I went ahead and bought everything I need at Home Depot. Gotta find someone with an air compressor now, or maybe a bike pump haha. What works best to plug the 4 things coming off the turbo inlet hose, or do you leave those on? And do you plug up the other end of the inlet hose, or let the air go through the turbo? Sorry I'm such a noob I just don't wanna screw anything up and someone told me if I put 20psi of air it will go into my valves, etc?
Old 04-04-2009, 01:33 PM   #111
jcbluescooby
Member#: 113012
'04 XT red LIFTED
lol..its gotta go through the turbo inlet nipples and turbo to get through the other stuff in the motor/exhaust..im pretty sure thats what needs to be done but i guess wait for another person to confirm this
Old 05-11-2009, 11:10 AM   #112
thebloodRS
Member#: 49621
2001 ver7 STi GC8
sedona red
Do not put 20 psi through your inlet!!!!!!
I just talked to my tuner and he says that that kind of pressure will kill turbo bearings. He said using this equipment, the max you should put to the system is 2-3psi.
thebloodRS is offline   Reply With Quote
Old 05-31-2009, 04:38 AM   #113
go1d1e
RIP 2/21/14
Member#: 91263
02 WRX Wagon
Going to try this....
go1d1e is offline   Reply With Quote
Old 05-31-2009, 05:45 PM   #114
Meatbawl
Member#: 175878
Tried this on a 2.0L WRX last weekend. Works wonderfully. I only had to use 12psi, and a bottle of soapy water to find any leaks. Sprayed the soapy water on all joints that are supposed to hold PSI, any leaks were clearly evident by the soapy water starting to FOAM like crazy. 20PSI probably isn't necessary. If you drill a big enough hole for the tire valve to push all the way thru to the ridge, you won't need to use silicone since it will seal itself much like it would on a car rim. Another tip: PVC cement isn't needed to hold the cleanout adapter to the elbow... at 12psi, it wasn't anywhere near popping off and sealed well.
OP & Jorge: Thanks for the info, it was very helpful
Meatbawl is offline   Reply With Quote
Old 06-01-2009, 03:28 AM   #115
05wrx09
Member#: 204111
2005 WRX
Did you keep the oil cap on? how about the PCV valve? what year 2.0 WRX? I had my oil cap off, and I am thinking all the PSI I was trying to push through kept going out the oil cap...my gauge wouldn't hold a reading...
Old 07-12-2009, 02:45 PM   #116
gopsu
Member#: 96448
02 WRX VF34
is this true??
gopsu is offline   Reply With Quote
Old 07-12-2009, 02:54 PM   #117
Meatbawl
Member#: 175878
Kept the oil cap on... had all the lines that come from the intake inlet capped off... can't remember if I pinched the PCV line though. It's an 02 WRX.
Originally Posted by gopsu View Post
is this true??
I don't know... but I do know that I only had to run 12psi max to find leaks... and my car is doing fine. I wouldn't do 20psi just because it's unnecessary. Better safe than sorry if it does damage something. My .02
Old 07-12-2009, 06:54 PM   #118
pismobeachrider25
Member#: 216673
bump for a smart little tool
pismobeachrider25 is offline   Reply With Quote
Old 07-12-2009, 09:59 PM   #119
gopsu
Member#: 96448
02 WRX VF34
Guys, I performed DIY bost leak check, but never got to manage to build any boost. I capped off all lines off of turboinlet except BPV line. Any idea why?
I used $20 tire inflator...
Old 07-12-2009, 11:22 PM   #120
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
There are two categories, with no good explanation. Some cannot build pressure, no matter what and some never have problems building pressure.
It doesn't mean that there's something wrong with your car.
Someone narrowed it down where the air was just coming out of the exhaust, although he separated the intercooler from the engine, suggesting that air might go through the compressor housing into the turbine housing and out the tailpipe.
Since you have to separate all the other pipes on the inlet, you're testing the turbo, inlet, intercooler and manifold.
I think that the way a compressor works is by pressure zones, low pressure around the inlet and high pressure inside the compressor cover. I don't think that the area under the compressor wheel gets pressurized much during normal operation. When you hit it with compressed air, if some escapes by the bearings, it doesn't mean anything.
I think that in the future I'm going to test them separately and possibly skip the turbo alltogether, I think it's better that way.
Old 07-13-2009, 12:04 AM   #121
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
How did you hook it up? Basically, you want to test all the post-turbo hoses/connections from compressor out to throttle body. Sorry for simple explanation, but you want to disconnect the hose from turbo compressor out and place the thingy in, then disconnect the hose to the throttle body and plug it and test.
Then once all the post-turbo hose/connections are tested and all leaks are fixed, remove the test thingy and the plug and put the hoses back on the throttlebody and compressor and tighten them up properly, because they are the only two places you can have an air leak now (not inlcuding pre-turbo piping/connections).
Here is a nice youtube vid showing how to make the test thingy and test for leaks:
wrxsti.l is offline   Reply With Quote
Old 07-13-2009, 01:34 AM   #122
GundamFan
Member#: 212204
bookmarked!
GundamFan is offline   Reply With Quote
Old 07-13-2009, 06:02 PM   #123
gopsu
Member#: 96448
02 WRX VF34
no one has answered this question -> is it necessary to cap off BPV line?
also, anyone knows PN of WRX TMIC elbow gaskets (x2)?
Old 07-13-2009, 09:08 PM   #124
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
BPV should remain closed until 20-26psi depending on which BPV you have. So it all depends on what pressure you test at. If you want to test at pressures over 20psi, I'd say cap it off to ensure it doesn't bleed the pressurised air out while you are testing.
Old 07-13-2009, 11:02 PM   #125
WRX 02
Member#: 215393
bump
bump
WRX 02 is offline   Reply With Quote
This just in - the War on Drugs is a complete failure FightingFalcon Political Playground 2753 01-09-2016 02:24 PM
A complete n00b's guide to changing the oil in your WRX (with pics!) perret318 Service & Maintenance 153 11-28-2013 01:17 AM
Swap complete, just lost the clutch! SJwrx Pre-2002 Factory Turbo Powertrain 9 05-08-2010 01:56 AM
The longest lasting DIY paint your wheels thread chimchimm5 Tire & Wheel 1 04-03-2010 01:26 PM
Just got the Escort ZR3 and Passport 8500. Your thoughts on the product. Chandy69 Tri-State Area Forum 13 05-09-2005 05:58 PM
