Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 05-30-2009, 11:49 PM   #201
subarujimbo
Member#: 140702
07 Wrx Wagon
Garnet Red Pearl
Found this diagram for the 07 WRX that backs up badmunky's claim.
It's from alldata so assuming it's correct it shows that there is a pressure sensor in the actual LH valve. I've compared the same diagram to the 06 WRX and it's not shown in the LH valve. So this suggest that it cannot be removed and must be kept similar to the 07 STI.
subarujimbo is offline   Reply With Quote
Old 06-03-2009, 11:56 PM   #202
BlueSubeDude
Member#: 172977
2006 WRX TR
Yep. There's a note in Subaru's Diagnostic Procedure for DTC 2444 (SECONDARY AIR INJECTION SYSTEM PUMP STUCK ON), the LH Valve has the pressure sensor integrated.
I have a question...I'm getting the CEL above, and I was wondering if it was okay if I just pulled the relay off of the air pump and valves and clearing the CELs with a protune instead of physically removing the entire system?
The thought of removing the intake manifold to access one of the valves is not motivating me very much.
BlueSubeDude is offline   Reply With Quote
Old 06-10-2009, 02:35 PM   #203
TFBHTMFSNE
Member#: 156086
Originally Posted by kh15 View Post
im STILL trying to decided whether or not to pull the pump on my
06
Well, not that you care, because in a later post you stated you've already done it, but:
WARNING: Federal law makes it illegal for ANYONE to tamper with, disconnect, remove or otherwise render inoperative ANY emissions-related control device. A violation may make you liable for up to a $2,500 fine.
The system ONLY works for about 90 seconds max when first started on a cold engine, and it's only for emissions purposes. It does nothing to increase/decrease horsepower. Do you really think removing 10 lbs of equipment from under your hood is going to improve the performance of your car that much? Really? To me, it's not worth the hassle or risk.
TFBHTMFSNE is offline   Reply With Quote
Old 06-10-2009, 02:42 PM   #204
Rene2.5RS
Member#: 4574
2014 Outback 2.5i L
VRP
the same is to be said about going catless but people do it all the time
Rene2.5RS is offline   Reply With Quote
Old 06-10-2009, 03:27 PM   #205
JoeTX
Member#: 83069
2007 STi 302/350
UGM Wingless
Ha! You either have a very dry sarcastic sense of humor or are a troll.
JoeTX is offline   Reply With Quote
Old 06-12-2009, 04:28 PM   #206
TFBHTMFSNE
Member#: 156086
Yes, they do. I've also seen a car being pulled up onto a flatbed by a State Trooper for "illegal equipment". The car was impounded for having an inspection sticker and no cats. Guy was giving the dealer a hard time about his CEL for a P0420 code, and the dealer got tired of his attitude, so they dropped a dime on him.
Old 06-12-2009, 04:29 PM   #207
TFBHTMFSNE
Member#: 156086
Guilty as charged (on the humor part).
Old 06-12-2009, 08:26 PM   #208
08sti813
Member#: 213602
So does anyone know about the 08 STI or will I have to be a test dummy.
08sti813 is offline   Reply With Quote
Old 06-24-2009, 12:29 AM   #209
fast06wrxtr
Member#: 206590
Does anyone need some motivation to do this project? How about getting paid to?
I am in need of a pump and two valves for an '06 WRX
What you get - minus 10 pounds and plus some cash (tbd)
What I get - a weekend of frustration installing the thing.
Parts must be working when removed (no cels association with them)
Please PM me if you're interested
fast06wrxtr is offline   Reply With Quote
Old 06-24-2009, 12:36 AM   #210
Dirtyhobo010
Member#: 144170
02 ej207|6 speed
Dirtyhobo010 is offline   Reply With Quote
Old 06-24-2009, 09:46 AM   #211
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
people have tried the '08 sti. I was recently told that the atmospheric sensor is in the bottom of the pump housing and not the driver's side solenoid body. I need to revisit the wiring diagrams now and inspect the parts from my engine to try to confirm this one way or the other. I still plan on deleting as much of mine as possible.
Frank
Frank A is offline   Reply With Quote
Old 06-24-2009, 01:48 PM   #212
fast06wrxtr
Member#: 206590
Originally Posted by Dirtyhobo010 View Post
Thanks for the tip. I hear there are some differences between the 06 and 07, and what I'm really after are the valves.
I appreciate it!
Old 08-25-2009, 09:36 AM   #213
wrxxx14
Member#: 162351
So what is the final verdict ??? 07 wrx just rip it all out n put the block off plates in??? Or. Leave the one valve hooked up n block off the other. N just get the cel turned off n everything is golden?
wrxxx14 is offline   Reply With Quote
Old 08-30-2009, 04:52 AM   #214
FxD
Member#: 124361
2007 WRX STI
bumping this thread, have a question.
Is it ok to just leave the air pump in and just have the codes flashed out?? i'll be getting a protune map soon and having the tuner disable the codes regarding the airpump.
thanks
FxD is offline   Reply With Quote
Old 09-10-2009, 10:00 AM   #215
fast06wrxtr
Member#: 206590
thanks
I tuned my CEL code out with an AP. There hasen't been any adverse effects after about 10k miles.
Old 09-10-2009, 10:28 AM   #216
Mechie3
Member#: 120152
^^ You have an 06 WRX, he has an 07 STI. The airpump systems are slightly different.
Old 09-10-2009, 10:28 AM   #217
Mechie3
Member#: 120152
Dpftlfail
Old 09-11-2009, 12:45 PM   #218
t00mes
Member#: 204512
2007 STi
I am not sure if this can happen, but can the black sensor at the top of the valve be taken out of the assembly on the 07 STI's? I have it plugged in and reading properly, but I know that it's doing nothing for the car at this point.
It's the assembly that accepts the purple connector not the air pump connector. This is the only piece that needs to stay for the car to properly read pressure.
For reference, its this:
t00mes is offline   Reply With Quote
Old 09-11-2009, 01:56 PM   #219
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Just for those wondering. I recently replaced my motor with a built lower end. While it was out of the car, I used the opportunity to remove the secondary air pump system. I purchased the delete kit from KS Tech and it worked great. I highly recommend it over more expensive alternatives.
I was suprised just how bulky the setup was when it was finally out. The removal cleaned up the engine bay a lot and gave a lot more room on the driver's side for plug acces and other things. I may even put a fuel filter and washer bottle there.
I also had a bunch of codes to turn off from both this and my TGV deletes. I think there were well over 14 total, but I don't recall for sure. My tuner was able to turn these off at the time of my protune and I have not had an issue since.
This is a good cheap modification if you are looking to gain a cleaner look in your engine bay. Doing it with the motor out is also a huge plus.
Old 09-23-2009, 10:55 AM   #220
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Hey, so I want to make sure that I know what I can remove from an 07 wrx:
remove:
air pump
driver's side valve (over starter)
tubing between valves and pump
tubing between valve and passenger's side valve
tubing to driver's side head
keep
passenger side valve. (under manifold)
Block off
passenger side valve input
driver's side head port
???s
are the kstech plates made to fit the driver's side head and passenger side valve?
What if you leave the valves? Do you still need the plates?
Bad Noodle is offline   Reply With Quote
Old 09-23-2009, 11:12 AM   #221
kpluiten
Member#: 120273
06 WRBWRXWGN
That I'm not sure about. I removed both valves. I'm pretty sure that the KS Tech deletes cover the holes in the heads, not the valves.
But, the guy who runs KS Tech is super nice and knowledgable and I'm sure he'd answer your questions if you called him up.
Old 09-23-2009, 12:05 PM   #222
chrisc75
Member#: 183729
07 sti
swp ///95 m3/ 94 supra tt
im debating on doing this to my 07 sti..wat u guy think
chrisc75 is offline   Reply With Quote
Old 09-24-2009, 10:20 AM   #223
KSTech
Member#: 143570
Do you guys think it would be good to have a block-off plate available for this passenger-side valve with the integral sensor?
Our plates definitely only cover the holes in the heads.
KSTech is offline   Reply With Quote
Old 09-24-2009, 12:35 PM   #224
KSTech
Member#: 143570
Originally Posted by juanmedina View Post
One of the stupid [KSTech] plate was off, the holes where not concentric to the bolt holes so I have to fix them. Do you guys remove these two solenoids as well?
It looks like that plate is installed on the pass. solenoid valve, and that is not where it goes. It is designed to go on the hole in the cylinder head, so that's why it didn't fit. It's not "stupid" at all.
I am going to draw up an aluminum cover for that opening in the pass. side valve. It will be about 2 weeks before it is available.
I also think we are overdue for a how-to on this. Will work on that too.
Matt Taylor
matt@kstech.biz
www.kstech.biz
Old 09-24-2009, 12:45 PM   #225
KSTech
Member#: 143570
Can somebody measure the size of the valve's pipe nipple shown in the pic below? It is the one pointing toward you in the pic.
Air pump removal + fail? 07 WRX. Badmunky Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 04-29-2013 08:05 PM
WTB 06-07 Wrx AIR PUMP StageWrx Private 'Wanted' Classifieds 1 03-30-2009 10:44 PM
is it safe if i remove the restrictor on my wrx prlblkwrx02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-24-2007 07:21 PM
Is it safe to switch to summer tires yet? It is March after all... Samirr76 Tri-State Area Forum 38 03-06-2003 09:25 PM
