#1 |
Member#: 131234
SWIC
Vehicle:2007 WRX Wagon White |
Is handbrake turns very bad to our subies?
Wondering if anyone uses handbrakes frequently when autox'ing...
#2 | |
Member#: 24038
South East
Static friction > sliding Last edited by REX8; 06-04-2009 at 06:28 PM. |
#3 |
Member#: 6850
Vehicle:Lots of ESP cars '06 IAG WRX & LT1 Z28s :) |
#4 |
ForumWars Winner!
Member#: 196948
TXIC
Vehicle:2012 WRX SWP TexasRallysport |
Yup, just for ProSolo starts where the car may roll in/out of the lights.
Otherwise-- *facepalm* to the guys who do it on course. |
#5 |
Member#: 43330
E. Canada
Vehicle:1993 Impreza L Titanium grey |
I did some test two years ago in a parking lot (not an event). For ONE airpin on a single cone, the handbrake could save 0.25 sec very easy.
But you have to do it perfectly, have some power (sti at least) and good grip. For any other type of turn it will not be the fastest way around. |
#6 |
Member#: 2446
Vehicle:'04 insert acronyms background |
I used the handbrake at the last DC Prosolo for more than the start line!!!!
Of course, I was going straight at the time and was trying to figure out why the car seemed a bit slow. ![]() ![]() ![]() |
#7 |
Member#: 27647
SCIC
Vehicle:89 Civic-STC 03WRX (ret), 08 Titan-Tow |
#8 |
Member#: 634
TXIC
Vehicle:2000 Impreza 2.5RS Becasue ITS racecar |
If you like your center diff. I would suggest not doing e-brake turns on pavement with the 5 Speeds. I have seen several trannies come to me with problems with the center diffs giving out. Mainly the snap ring on the back of the diff that holds the LSD pack & spider gears in place. It can pop out and then some times lodge themselves in between the setup gears in the tail section of the transfer case. In one case, it destroied the gears and bearings in the tail section along with having to buy a new center diff.
BTW, I rebuild trannies on a regular basis. |
#9 | |
Member#: 60566
SCIC
Vehicle:2002 WRX Unicorn 2001 Legacy L 2005 XT 5sp |
#10 |
Member#: 634
TXIC
If can't duct it...F*** it. lol!
I have done that before. |
#11 | |
Member#: 43330
E. Canada
And what is good is when take a U-turn with the handbrake, all 4 wheel are still rotation at a very slow speed. So you can put the first gear without problem. And it is good to modify the handbrake to be able to release it without holding the button. |
#12 |
Member#: 123330
International
Vehicle:02 CVC, 98 Carmy 747 Philippine Airlines |
Only time I've used handbrake on an Auto-X was to launch the car on an incline. And that was before I got used to heel-toeing.
#13 |
Member#: 109623
Vehicle:*** Touching the Blue*** |
I've done it twice in a local event during test and tune to see how it would work. 1st time screwed me all up,2nd time was
I didn't feel comfortable enough to try it in my runs.![]() |
#14 |
Member#: 144821
Vehicle:1994 LS1 Miata 2002 2.5ts wagon white |
I asked a similar question on dirtyimpreza and got some good input. http://www.dirtyimpreza.com/forums/s...ad.php?t=10225
The general consensus is that you shouldn't do it if it can be avoided. This is more rallyx than autox, but they suggested pendulum turns and left foot braking as an alternative. Of course, if you have an sti, your center diff opens up when you pull it so you can do it all you want with no ill effects, at least for the center diff. If you do it a lot, you will burn through the shoes for your hand brake in no time. |
| Thread Tools | |
| Display Modes | |
| geographical breakup of use of soda, pop, or coke | stuttgart | Off-Topic | 29 | 09-10-2008 01:00 PM |
| Using the handbrake? | TheKryptKeeper | General Community | 39 | 07-10-2006 02:17 PM |
| what used car to buy for use of 1.5 yrs with little depriciation hit? | friedbbq | Off-Topic | 11 | 10-16-2005 06:33 PM |
| What's the use of the B28 in the 04 STi cluster used for? | V6 | Electrical & Lighting | 1 | 08-08-2005 04:12 AM |
| "pr0n": An anagram of "porn," possibly indicating the use of pornography | WRXVT | Off-Topic | 17 | 03-05-2005 03:44 PM |
