Welcome to the North American Subaru Impreza Owners Club Saturday September 24, 2016
Old 06-04-2009, 06:06 PM   #1
hklatte
Member#: 131234
2007 WRX Wagon
Default Use of Handbrakes?
Is handbrake turns very bad to our subies?
Wondering if anyone uses handbrakes frequently when autox'ing...
hklatte is offline   Reply With Quote
Old 06-04-2009, 06:11 PM   #2
REX8
Member#: 24038
There aren't corners tight enough in autox to warrant even the consideration of using the handbrake. Maybe some ProSolo guys at the start-line...
Static friction > sliding
REX8 is offline   Reply With Quote
Old 06-04-2009, 07:14 PM   #3
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
& 2006 IAG WRX (ForSale!)
That's about it for me.
CamaroFS34 is offline   Reply With Quote
Old 06-04-2009, 10:06 PM   #4
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
Yup, just for ProSolo starts where the car may roll in/out of the lights.
Otherwise-- *facepalm* to the guys who do it on course.
JamesWilson2 is offline   Reply With Quote
Old 06-05-2009, 08:22 AM   #5
Sylvain b
Member#: 43330
1993 Impreza L
Titanium grey
Default ...
I did some test two years ago in a parking lot (not an event). For ONE airpin on a single cone, the handbrake could save 0.25 sec very easy.
But you have to do it perfectly, have some power (sti at least) and good grip.
For any other type of turn it will not be the fastest way around.
Sylvain b is offline   Reply With Quote
Old 06-05-2009, 08:30 AM   #6
maxQ
Member#: 2446
'11 Alfa Cloverleaf
grise
I used the handbrake at the last DC Prosolo for more than the start line!!!!
Of course, I was going straight at the time and was trying to figure out why the car seemed a bit slow.
maxQ is offline   Reply With Quote
Old 06-05-2009, 01:37 PM   #7
PKer
Member#: 27647
06 MX-5-STR 03WRX
(ret), 08 Titan-Tow
Been there...man it sucks
PKer is offline   Reply With Quote
Old 06-05-2009, 01:46 PM   #8
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
If you like your center diff. I would suggest not doing e-brake turns on pavement with the 5 Speeds. I have seen several trannies come to me with problems with the center diffs giving out. Mainly the snap ring on the back of the diff that holds the LSD pack & spider gears in place. It can pop out and then some times lodge themselves in between the setup gears in the tail section of the transfer case. In one case, it destroied the gears and bearings in the tail section along with having to buy a new center diff.
BTW, I rebuild trannies on a regular basis.
Patrick L is offline   Reply With Quote
Old 06-05-2009, 01:57 PM   #9
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
Duct tape the button down FTW.
mccanixx is offline   Reply With Quote
Old 06-05-2009, 02:02 PM   #10
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
If can't duct it...F*** it. lol!
I have done that before.
Old 06-05-2009, 02:03 PM   #11
Sylvain b
Member#: 43330
1993 Impreza L
Titanium grey
Default ...
DCCD are supposed to be ok!?
And what is good is when take a U-turn with the handbrake, all 4 wheel are still rotation at a very slow speed. So you can put the first gear without problem.
And it is good to modify the handbrake to be able to release it without holding the button.
Old 06-05-2009, 02:05 PM   #12
pete_falcone
Member#: 123330
16 ZoomZoom CeX-3
15 ZoomZoom3-Regina
Only time I've used handbrake on an Auto-X was to launch the car on an incline. And that was before I got used to heel-toeing.
pete_falcone is offline   Reply With Quote
Old 06-06-2009, 06:25 PM   #13
Mr.Krinkle
Member#: 109623
'04 G35 track bitch
'06 Mazda3 hatch
I've done it twice in a local event during test and tune to see how it would work. 1st time screwed me all up,2nd time was I didn't feel comfortable enough to try it in my runs.
Mr.Krinkle is offline   Reply With Quote
Old 06-07-2009, 12:54 PM   #14
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
I asked a similar question on dirtyimpreza and got some good input. http://www.dirtyimpreza.com/forums/s...ad.php?t=10225
The general consensus is that you shouldn't do it if it can be avoided. This is more rallyx than autox, but they suggested pendulum turns and left foot braking as an alternative. Of course, if you have an sti, your center diff opens up when you pull it so you can do it all you want with no ill effects, at least for the center diff. If you do it a lot, you will burn through the shoes for your hand brake in no time.
573 is offline   Reply With Quote
geographical breakup of use of soda, pop, or coke stuttgart Off-Topic 29 09-10-2008 01:00 PM
Using the handbrake? TheKryptKeeper General Community 39 07-10-2006 02:17 PM
what used car to buy for use of 1.5 yrs with little depriciation hit? friedbbq Off-Topic 11 10-16-2005 06:33 PM
What's the use of the B28 in the 04 STi cluster used for? V6 Electrical & Lighting 1 08-08-2005 04:12 AM
"pr0n": An anagram of "porn," possibly indicating the use of pornography WRXVT Off-Topic 17 03-05-2005 03:44 PM
